#1 |
gettin old or senile
I'm trying to time the valve train on a plane old 1988 Chevy smallblock
I line up the cam and crank sprockets dot to dot. That should be Tdc#1. I just read an old post somewhere else that said the engine is actually on TDC#6 and you have to spin it 180 degrees to be on TDC#1. Then set your #1 valves and so forth. Its not like it's my first time. Am I getting senile? Steve
__________________
1995 auto,293,000 miles 4x4, 97 oil changes, BHAF,4" exhaust, borgeson steering shaft, bone stock engine, everything else replaced! |
#2 |
And BTW, How do I get the "Registered User" under my name changed?
Is the rotor pointing to number one cylinder? If so, you are on TDC
__________________
Tow vehicle...2006 Atlantic blue Mega Cab 2500 4x4 6 spd. 3.73's CTD 325/610.. Silencer Ring gone...Amsoil EAA189 filter... Air Box mod... Quadzilla Max Mileage Module... Fuel Tank Vent Mod... Muffler gone Member #3 of DTR Megacab Club Join Here Member #12 of DTR GoofBall Club Join Here Towed.. Jeep CJ7, 304 with Holley Fi, T-18 trans, Dana 300 with 4 to 1 gear set, Dana 44 with Detroits F&R, 35x16.5x15 Boggers with MRT bead Locks, and way too much more to list. |
#3 |
if your cam dots are lined up you are on tdc#1. install the distributor so that the rotor is pointing to #1 like chad said above. You can use a timing light to get 0* by turning the key on in the run position and move the dist backand forth (small amounts) with the timing light trigger pulled, the light will flash. Tighted the dist a bit but still able to rotate but with increased force. start her up and do final timing. drive it like you stole it
__________________
07 Mega, 9" lift, Toyo's, 8" stacks, Billet Clamps, Smarty, Ravelco, Ice Box, HID's, RECON, Ranger 6900 CB, Sterling grill SAC Member #1 Megacab Club # 81 3rd Gen Stack Club #18 Soldiers for Jesus Motorcycle Club (Prospect status Jan, 30th) NMDTR #44 PM me for details |
#4 |
How about old AND senile?
![]() If the distributor rotor is pointing to #1 cylinder and all the dots on the valve train line up, then you have to be on #1. Check and see if both the inlet and exhaust valves on #1 cylinder have clearance (lash) in this position as neither valve should be opening on TDC
__________________
2003 Light Almond 2500 QC SLT, HO, six speed, 4x4, premium cloth, tow package, fold flat floor, 3.73 anti-spin, keyless entry, chrome Mopar nerf bars, rear slider, Rhino liner, immobalizer, Mopar mud flaps, BD short shift, ultrasonic backup system, Scotty 3 airfilter, Diprocal gauges, Jordan Brake, Icom 2/440m. 315 Yokahoma tires, Pacbrake, Carli suspension, on board air, Road Armor bumper, Dynatrac hubs. MM 12k hydraulic winch, Airdog FP-100 |
#5 | |
Quote:
not really. with a small block (or big block) and the oil pump being able to move with a screw driver to index the pump so the distributor engages cam gear, you can be anywhere in the 360 degree circle. It is suggested during assembly that the rotor point towards #1 to make life easier in the future when doing distributor servicing if needed. |
#6 | |
Quote:
#7 |
its all good Stan... I had to think there for a second too but re-read the OP and he had cam/crank gear dots lined up so I figured he had installed new cam or rebuilt motor.
#8 |
If the timing marks on the cam and crank are lined up, the #1 piston is at TDC between compression and power. The distributor is most likely at 0 or 180 out, but could be anywhere if the engine has been apart. If the distributor is in place and you are just doing the cam or timing set, make sure the rotor points to #1 wire. If the old cam was removed with the timing marks not lined up, it is probably best to just pull the distributor and re-install it in the new right place with the timing marks lined up on the cam and the rotor toward #1. Or trial and error the new cam in and out, and turned, until you get the marks all lined up and the rotor lined up.
__________________
John Prepare to stand by! '04 2500 4WD std cab, HO, 48RE, TC, VB, Hytec pan, Dynatrac, '08 steering linkage, track bar, '08 H2s, Toyo 285/70 E, Smarty, Walbro, gauges, Brakesmart, exhaust "out the side", intake tube, billet filter lid, Kilby guard, KYB front, Rancho 9000s rear, Timbrens, PW flares, rear blocks missing, front 1" lift, wheel well liners, debadged, splatted bugs, hood pal. |
#9 |
This engine has been completely rebuilt with no distributor. Crankshaft mark set at 12 oclock and cam mark at 6 oclock lined up, #six cylinder will be at TDC. Rotate crank 360 degrees with crank marks at 12 oclock and cam at 12 oclock you will have #1 @TDC. I always thought the two marks together were TDC#1
#10 |
no need to remove the cam to line up the rotor. long flat head screw driver in the distributor hole to turn the oil pump shaft. less stress on the cam and risk of gouging the cam journals and lobes.
#11 |
The girls at Wal-Mart are impressed that I have 3 theeth...
ok, maybe im reading too much in this.
OP doesn't mention a few things. has teh cam already been used with this motor? do you absolutely without a doubt that the cam gear is on the cam properly? What parts were changed out to make you thing the valve train needs the timing adjusted?
__________________
Divide et impera! |
#12 |
everything was changed out. starting from scratch you take a 1988 four bolt main block put a crankshaft in it and a camshaft with some heads and pushrods and line up the dots what setting are you at? #6@TDC. Spin the crank 360 degrees and then you're at #1 TDC with the cam dot at 12 oclock. I dont give a d#@! about the distrbutor thats the easy part and its not even in yet!
#13 |
i'm just tryin' set the lash first.
#14 |
If it is a stock small block, such as a 350 / 5.7 with hydraulic lifters.
as long as you are using all stock parts, rockers/studs/etc. Turn your adjuster nuts down until 3 threads are showing on the studs. That's it, that's all. drink many beers.
__________________
01 2500 Q/C 4x4, factory order HO w/5spd, 4 wheel discs, Pacbrake, 285 Cooper STT's on 058 Eagle Alloys. Ultra 5th wheel hitch. Glacier Diesel GFS-392 LP 01 F550 XLT 4x4, Jokestroke, 6 speed, heila knuckleboom, boxes and deck, low mount 5th wheel. No mods, no power, no fuel economy, kinda like a ford.... HAHA Never judge someone until you've walked a mile in their shoes. Then, when you do judge them, you're a mile away... and you have their shoes |
| Thread Tools | |
| Display Modes | |
