Go Back   Dodge Diesel - Diesel Truck Resource Forums > 4th Generation Ram - 2010 and Up > RAM 2500-3500 HD Discussion
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-02-2009, 08:52 AM   #31
HOHN
HOHN's Avatar
Quote:
Originally Posted by Ten_Bucks View Post
The correct way to stretch the frame is under the back doors of the cab where the frame is the strongest. That way, you are not stretching the spot that sees the most stress(over the rear axle) and it ends up coming out factory looking. The guys at Precision Bodyline/Longbedmytruck.com stretch the frame right above the rear axle which is the incorrect way to do the stretch.
Scott
Quote:
Originally Posted by capt.Ron View Post
Hmmmm
I wonder, why is the frame the strongest under the rear doors if the most stress is at the rear axles?
I could be wrong but!!!
My view would read just the opposite. When you load a truck the best case cenario is to spread the load over the whole frame. In doing so the most stress would be the farthest point from the rear/front axles. i.e. somewhere under the rear doors thus the reason for the frame being the strongest in that location.
One issue that I'd like to see addressed is the fact that the stress point will now be shifted because of the extended frame. I would hope that when the truck is stretched extra material is applied to not only the area that's cut but also throughout the area of the new stress point.
The point of max stress is usually just ahead of midway between the axles, but will shift rearward as load is added.
Stretching any new frame is a bad idea. They aren't design for bolting OR welding. The weld will ruin the heat treat in the base metal. Botl holes cause stress risers.
There' no margin a newer style hydroformed frame. They are design to be stiff and light, and once you go stretching them, all bets are off.
I'd HIGHLY discourage stretching the frame on any newer pickup that will see any substantial load at all. It's a failure waiting to happen.
A Commercial type of truck has a less sophisticated frame, pretty much just mild steel C channel. They lend themselves well to a stretch.
Save the stretching for your F550 or Topkick or such. Not your Dodge pickup!
JH
__________________
Justin
I like to think I can offer you some points to think about, but I have LITTLE TO NO EXPERIENCE with the vast majority of performance enhancements out there: turbos, fueling boxes, etc. I can comment on how things might be "on paper" but things on paper and in the real world are very different. DO NOT make buying decisions based exclusively on my advice or any internet forum "wisdom". I'll offer you my free advice, and you'll always get your money's worth.
HOHN is offline   Reply With Quote
Old 11-02-2009, 09:56 AM   #32
CoastalDav
CoastalDav's Avatar
Send a message via AIM to CoastalDav
The picture I posted in "Post #16 to this thread" is one of Kendall's stretched Mega Cab Duallies. If your going to stretch as said a couple post ago, thats were to go. Its been said, the web site is no longer up with the info. He still does have a web site.
http://www.1ctfa.com/home.nxg
It does not talk to the stretch. You can use it as a contact source.
Dave
__________________
2006 Dodge 3500 SLT, Cummins, 48RFE, 3:73's, 70 Gallon Transfer Flow Bed Tank with Trax II Monitor System, Racor Marine Centrifigal Water Seperator/10 Micron Filter in the system. Edge Insight w/pyro, Headache Rack, Turbo Wing, Rhino Bed Linner, Nasta Rails, Recon Lights and Strip Lights, Sirius Sat Radio, Net Weight 7,520 lbs with 34 gallons fuel Tagged at 13,500lbs GVW. Towing 35ft Carriage ,Triple Slide 5fer, GVW 14030.
04 Hemi Durango AWD "Grannys Hemi Kid Getter"
CoastalDav is offline   Reply With Quote
Old 11-02-2009, 02:22 PM   #33
Ten_Bucks
Ten_Bucks's Avatar
Send a message via AIM to Ten_Bucks Send a message via MSN to Ten_Bucks Send a message via Yahoo to Ten_Bucks
JH
Try saying that to the shops that got it down to an almost science then get back to me. Those shops have never had any problem with the frame strength after the stretch is done. Besides, no matter which way is chosen, if the OP wants a Mega longbed he will have to have the frame stretched.
Scott
__________________
http://facebook.com/tenbucks76
Ten_Bucks is offline   Reply With Quote
Old 11-02-2009, 06:02 PM   #34
capt.Ron
capt.Ron's Avatar
Scott
No guarantee that I want one bad enough to actually do it.
I would like to be able to have a toolbox and still be able to haul the dirt bikes or a fifth wheel but:
  1. It may not be worth the cost.
  2. I may not find the stretch methods favorable to my strict sense of strength, durability and safety.
I certainly won't do the stretch right after purchase. I've got to see some time proven results from others first.
__________________
96 2500 Goerend brother's tranny #10 plate slightly forward waste gate blocked and K&N drop in.
2009 Challenger (Red)
2009 Yamaha WR 450
98 Dodge Intrepid
99 Yamaha WR400
02 CR450F
01 TTR 125
87 19.5' Astroglass w/96 200 Merc.
1.5 GPF Kohler
capt.Ron is online now   Reply With Quote
Old 11-02-2009, 06:10 PM   #35
Ten_Bucks
Ten_Bucks's Avatar
That is completely understandable but I will say this:
I have talked to both Kadell at KS Conversions and Clint at Innovative Customs about the conversions and they have done well over 100 conversions combined so both shops know what they are doing.
Scott
Old 11-02-2009, 07:34 PM   #36
capt.Ron
capt.Ron's Avatar
Scott
I will certainly ask questions and consider the longbed stretch.
I guess I can sell my leftover shortbed on ebay???
Old 11-02-2009, 09:33 PM   #37
Ten_Bucks
Ten_Bucks's Avatar
The shortbed is exchanged for the longbed in the process. Its part of the process and overall price of the conversion.
Scott
Old 11-02-2009, 09:45 PM   #38
capt.Ron
capt.Ron's Avatar
Scott
That makes the conversion much more expensive.
Reduces my desire to make the move.
Old 11-02-2009, 09:50 PM   #39
Ten_Bucks
Ten_Bucks's Avatar
Well, it is about 6 grand for the conversion from either Innovative Customs or KS Conversions. The process includes exchanging the short bed for a longbed, putting a spray in bed liner in the bed, painting the bed to match your cab's color, then the actual process of stretching the frame and the associated stuff to make the new bed fit. If the customer provides the bed or if the customer doesn't want a spray in bed liner, then the overall price is reduced. The price is also reduced a little bit if the truck the customer provides is painted white because the new longbeds come to the shop painted white. Sellers, Inc. in Indiana does the conversions as well but they insist that unless the customer wants either a flatbed or utility bed, then the pickup bed must be provided by the customer. Their conversion costs less than 3 grand because of that. The customer is also responsible for getting rid of the short bed. Sellers, Inc. also does the frame stretch the same way that Innovative Customs and KS Conversions does it.
Scott
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
