Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 09-15-2008, 11:13 AM   #1
Bowser50
Bowser50's Avatar
Question Gauge Assisstance
I am looking to order some gauges and I want to go with auto meter ultra lite 2's. I currently have a stock truck but want to keep an Eye on things. I have a manual transmission too so that helps you to help me. I am eyeing a boost and Pyro gauge right now and possibly a dif gauge. as far as the boost gauge goes I do plan on modifying my truck a little bit, bigger turbo, better injectors, intercooler, tuner/programmer. I was wondering would a gauge to 60#'s suffice or would I want one that goes to 100#'s ? and also besides just the boost and Pyro what other gauges could someone suggest that I get that would help. I am new to the diesel performance world and have driveway mechanic skills and honestly don't know too much about tranny's but I do know that with an automatic the temp has great importance as far as valves melting and tranny's frying that's what trans temp gauges help with, so having a manual would there be a reason or a way to put a trans temp gauge on my truck? for the same reasons for a diff gauge possibly? any help would be appreciated.
__________________
Clint
04 Gunmetal QCSB 4x4 2500 5.9L. NV5600, Van Aaken C3.2, Predator stage 2. Stock intake, stock exhaust, muffler delete, glowshift boost, pyro, and fuel pressure, Nitto terra grappler 285/70/17's on H2's.
Bowser50 is offline   Reply With Quote
Old 09-15-2008, 01:19 PM   #2
enafzige
A 60 psi boost gauge will be fine, unless you're shooting for twins and 600+ horsepower.
I have front and rear differential gauges, as well as a gauge on my manual transmission. Unless you just go overboard like me, there's probably no need for these gauges unless you pull very heavy for extended distances.
I've seen trans and rear diff temp hit 220 a couple times, but very rarely.
Probably oil pressure and rail pressure gauges would be much more useful for you. (factory oil pressure gauge is a dummy)
--Eric
enafzige is offline   Reply With Quote
Old 09-15-2008, 01:23 PM   #3
tritont
tritont's Avatar
You might want to take a look at the Isspro Performax gauges. There's a several reasons to go with them. A 60psi boost gauge would be plenty unless you go with twin turbos.
A diff gauge isn't that important unless you're planning on towing really heavy loads. Even then, the axles are pretty stout and can handle a lot. No need for a temp gauge for a manual.
Your main concerns are... EGT, boost, fuel pressure. They're almost a must for every truck. Next would be rail pressure gauge. If you do any modding... it helps in tuning.
tritont is offline   Reply With Quote
Old 09-16-2008, 12:42 AM   #4
Bowser50
Bowser50's Avatar
where would I install the probes for both the fuel pressure and rail pressure gauges?
Old 09-16-2008, 07:03 AM   #5
jrussell
jrussell's Avatar
Quote:
Fuel pressure sensor goes in the line between the fuel filter and CP3. You can buy a "big line kit" that uses rubber hose and comes with a fitting for the sensor.
Rail pressure gauges use the existing factory sensor located on top of the fuel rail. You unplug the stock wiring, plug the gauge in, then plug the stock wiring into the back of the gauge plug. Make sure to use dielectric grease on all the rail sensor plugs or all kinds of wacky stuff can happen later on.
jrussell is offline   Reply With Quote
Old 09-18-2008, 06:19 PM   #6
Bowser50
Bowser50's Avatar
for the "big line kit" where would I pick one of those up at and who makes it? and for the actual fuel pressure gauge do the usually come with all the fittings. What about a fuel pressure warning light? I saw that bully dog makes one would that be just as good as a gauge because really that's all you are watching for anyway is when it drops below a certain pressure. just curious so I can go with just three gauges and a warning light.
Old 09-18-2008, 07:16 PM   #7
87BRGN
87BRGN's Avatar
There are quite a few companies that sell gauge packages that include everything you need for install. Diesel Manor, Geno's Garage, and Vulcan are a few. I personally went with Diesel Manor. I've got a six speed also, so I went with Isspro- boost(60psi),pyro(1500*) and fuel pressure(30psi). in a triple pillar mount. The only thing not included was the bit and tap for the pyro probe.Other than that EVERYTHING is there. Really is a nice kit. Warning lights work, but with what your planning... Your gonna want a gauge. As far as big line kits, Glacier Diesel or Vulcan can hook you up, But you might want to wait till you upgrade the lift pump to see any benefit. Plus some aftermarket lift pumps come with a big line kit.
__________________
Dave
03 HO 3500 QC DRW- NV5600, 4.10s, 4X4, CAI, 4" straight, AirDog 150, Smarty Jr./MP8, ISSPRO:boost,pyro,fuel, Navigation, Line-X, DeeZee Bars, 20% tint, Recon markers, 20k 5th w/25K GN plate, Tekonsha P3,Toyo AT 285/75s
02 Silverado Z71-K&N, STS Turbo, Diablo w/STS tune, 44# injectors, Trans go
87BRGN is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
