Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 05-22-2007, 01:50 AM   #1
kenny1987
kenny1987's Avatar
Angry gas mileage question
i have a 2002 dodge 3500 with a edge comp chip and my mpg suck and i was told it was going to improve. any suggestions on how to bet better?
kenny1987 is offline   Reply With Quote
Old 05-22-2007, 01:53 AM   #2
LonestarCTD
LonestarCTD's Avatar
What kind of mileage are you getting right now?? city? hwy?
__________________
2001.5 2500 4x4, 5spd, LSD, 4.10 rear, 315/75R16 Cooper Discoverer S/T's on stock Alcoa wheels, Silencer ring MIA, Muffler MIA, Walbro GSL392 (non-Glacier custom setup), BHAF, Rhino-lined
"You can have my Cummins Turbo Diesel....when you pry my dead fingers off the steering wheel!!!"
LonestarCTD is offline   Reply With Quote
Old 05-22-2007, 01:57 AM   #3
kenny1987
kenny1987's Avatar
wel i am getting about 14 on both and i have the silincer ring out of the turbo and a straight pipe and the OEM AFE filter and i run the chip on 60hp. I hae 3.55 gears in it i was told when i baught it but when i drive 70 the tach is on 2 grand so i think they are 4.10 but dont know
Old 05-22-2007, 04:08 AM   #4
kenny1987
kenny1987's Avatar
Ok I Guess There Arent Many Answers To This I Am Going To Put A Afe Stage 2 Intake And A 4 " Straight And After Some Overtime I Am Going To Put A Kevlar Clutch In! Should I Put Injectors In Also Will That Help My Millage At All? I Pull Alot Of Horse Trailers To Rodeos Will All This Extras Hurt My Truck (like Blow My Motor)
Old 05-22-2007, 05:36 AM   #5
pick
pick's Avatar
I'm running a pretty close set up to what you are thinking about. with the exception of the Injectors & edge. 6-speed, 3.54 gears, afe stage II, 4" turbo back, w/285's and get around 17 mpg mixed driving.
__________________
2001.5 HO- 2500 4x4 SLT
AFE Stage II
4" MBRP
SBC
gauges
Hide-a-way gooseneck
pick is offline   Reply With Quote
Old 05-22-2007, 08:56 AM   #6
Mopar1973man
Mopar1973man's Avatar
Quote:
I'm getting quite good MPG number with mine and I'm running on 4x4 with a light foot or using cruise control.
http://www.frontiernet.net/~mopar197...el%20graph.jpg <- Fuel records graph...
I got my Edge Comp installed at 92K miles and notice the graph starts heading up...
My secret is running 4x4. Keep my boost below 5 PSI if possible and also keep the pyro below 650*F if possible. Cruise control set a lower speeds helps a bunch. Like if speed limit is 65 MPH set it for 60 MPH if traffic allows. Speeds over 55 MPH with increase boost and pyro fast!
Keep you tires aired up. 50-60 PSI.
If you got a lift kit and/or larger tires this will eat a big hole in the MPG number. You got more wind drag and lose HP/TQ to turning those tires.
If you see smoke to fueling to hard. Back off. Black smoke is unburned fuel!
__________________
2002 Dodge Cummins - Way too many mod to list.
Mopar1973man is offline   Reply With Quote
Old 05-22-2007, 09:05 AM   #7
scottsjeeprolet
scottsjeeprolet's Avatar
I have 4.10 gears and do about 2400-2500rpm @ 70. So you have 3.55 gears.
__________________
1999 3500 4X4 DRW, QC, LB, Auto, 4.10 posi rear, 235 85R16 Dunlop RV, S&B Intake, Adrenaline w/Pulse, ISSPRO guages, AirDog 100, BD VB & TCI Maximizer TC, B&M Super trans cooler, ATS Co-Pilot, HX 35/40, F1 Mach 3's for tailgaters to enjoy
Scotte
Maryland DTR Chapter #33
Wanna join? PM me for details.
Find out what's going on in MD Chapter #33 Forums
scottsjeeprolet is offline   Reply With Quote
Old 05-22-2007, 09:59 AM   #8
BIGROD
BIGROD's Avatar
Some of these trucks don't seam to get the fuel mileage that others git. My city mileage sucks, I don't ever drive far enough to get the truck warmed up. Now hwy mileage is a different story. On flat ground and a good warm day I can knock down 19 at 80 MPH.
Check you thermostat and make sure you have a 190 degree in there. A 180 thermostat can drop your mileage down a easy 2 mpg.
Rodney
__________________
Replacement
2006 Dodge Ram 3500 Quad Cab Dually
4X2 6 Speed Bone Stock
Totaled Out 12/30/08
2000 Dodge Ram 2500 Quad Cab LB 4X2 Auto
BHAF, 4" SS Exhaust, Rancho RSX's, Vulcan Draw Straw & all 1/2" lines, HPFP,
Isspro Gauges, Boost/EGT/Trans/FP, Don M Mach 1.6, Super Chip D Box
Pullrite Super 5th 20.5k
2003 Terry EX 31.5G 2 slides
BIGROD is offline   Reply With Quote
Old 05-22-2007, 07:25 PM   #9
saab9k
Guest
I got 3.54 gears in M80 rear, 2000 rpm at 70, checked with my gps, speed is right.
Old 05-22-2007, 07:29 PM   #10
crobtex
crobtex's Avatar
Mine has gone from about 20 overall to barely 17 since the introduction of ULSD.
__________________
SUPPORT OUR TROOPS !
1999 Ram 2500, SLT Laramie, Quad Cab, LWB, 4X4, 5 Spd, Camper/Trailer Tow Pkg, LS/RE, Westin step bars, Ram molded splash guards (front and rear),diamond pattern bed caps and toolbox, Isspro EV boost, pyro and FP pillar mount. FASS II on 6/5/05. Rancho RS9000's on 8/23/05. RV275's on 12/11/05. AirRites on 3/5/06. MBRP 4" on 3/14/06. DSS on 4/8/06. Smarty on 10/12/06. New front rotors and axle seals: 8/08 Jammer 3's on 9/6/08, South Bend Con O on 1/30/09
304/718 on 4/1/06.
crobtex is offline   Reply With Quote
Old 05-22-2007, 08:01 PM   #11
Bootshound
Bootshound's Avatar
I always understood that diesels get the best mileage when they're operating at their peak torque. Would the mods you have move your peak torque up the rpm range or lower in your rpm range? I can get 19 mpg on the highway if I hang around 55 mph (1500 rpm) but it sure seems slow! I'm expecting better numbers as the engine gets broken in - I've only got 7K on this truck so far!
__________________
Bone stock 2006 dodge ram 2500 w/Cummins 5.9L TD
Rhino liner in bed and lower body panels
Bootshound is offline   Reply With Quote
Old 05-22-2007, 08:07 PM   #12
old 300
old 300's Avatar
My 2500 has 3.55's and at 2000 she runs about 70 also. A friend has 4.10's and I think he runs over 2000 @ a bit over 60. As for gas mileage every foot is different and its hard to get an overall #. I live in Canada and our gallon is = to 4.546 litres where a U.S. gallonis = to 3.78 litres I think. On my computer over head it says US 20-21 jigging not highway not city( 50mph) and 23-24 US highway average. A US gallon is 4/5th's a Canadian so if you take the 24 x 5=120/4=30 mpg/Canadian. Now don't call me crazy but I drive holding my foot off the go peddle. I don't even hear the turbo spooling. I baby my truck toooo much. I'm sure if I were to get at her it would be a different story. As for winter driving with winter fuel that is a whole different story. The comp shows 12mpg US = 15 mpg Canadian.
__________________
2001.5 auto QC 4X4 3.55's and lots of babying.
Just remember " We are free to do what we want as long as we do what we are told. " Too many laws. Where did we go wrong?
old 300 is offline   Reply With Quote
Old 05-23-2007, 02:58 AM   #13
kenny1987
kenny1987's Avatar
well guys i have to say thanks my truck does put some smoke out switching gears so i am going to turn my chip down and try that. but will a better intake and a 4" help and ther is a thing called the cell tech or something it is suppost to help with mpg have any of yall herd of it?
Old 05-24-2007, 02:01 PM   #14
Diesel-Dan
Diesel-Dan's Avatar
Forgive me in my stereotype but here is what i see:
20 Year old (Texas Man) with a 3500 Dodge diesel with a Comp Box. I would be willing to bet your foot is in it with the box turned up past the first setting. How much smoke you blowing? Yeah...though so! I'm just kidding around.....(Case in Point: BigBlue) Dont get twisted at me...because you and only you know how you drive your truck......
I only say all this because i was a 20 year old "Texas Man" about 9 years ago and i know how i drove my 300 Inline 6 Ford...i swore it was a 460! AND i know how Texans like to show off their trucks! haha....
You have 3.73 (Or 3.54...cant remember what i got) gears if you are at 2K at 70. My suggestion is to make an effort on driving like you want mileage. Dont run the gears out and quit using the upper 4 setting on the Comp box (OR just stick the thing in the glove box....). That first setting is pretty much an EZ. This will give you the timing you need to try to get some MPGs out of your engine. Keep the thing under 2K as much as you can.
Remember you have a DRW Truck.....you got a lot of drag going on here. My truck is a SRW and i only get about 17.5-18 on a good day. I don't baby it all the time, but i dont drive with my foot on the floor either. If you thinking your going to get 25 MPG out of your rig......might as well sell it now.....
These engine's are fun....but the more you blast on them.....the more fuel you will use......
__________________
Dan MacDonald
2006 Dodge 2500 Lone Star Edition-- Suncoast Billet, Bank$ exhaust & Intake, leveling kit, 20" wheels and 35" mud's
'02 Jetta TDI 5 Speed "Mini Me" -- Two Hamsters and a Ceiling Fan!
Diesel-Dan is offline   Reply With Quote
Old 05-24-2007, 05:43 PM   #15
old 300
old 300's Avatar
Was on the highway last night and looked closer at the tach. It was 1 mark below 2000 so I guess its 1875 @ 70 mph. I thought it was 2000 @ 70, I have the 3.55's
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
