Thread Tools | Search this Thread | Display Modes |
#1 | ||
Fuel tank
__________________
93 W250 LE, Extended Cab, Auto, 3.54LS 195,000Mi, Original Owner ISSPRO Tran Temp, Pryo, Boost & Tach, f1 EDMs, Twins, aFe, Trans by DTT -89%, Borgeson, Full 4" Exhaust |
#2 |
Re:Fuel tank
JBOLT I do alot of interstate driving, normally 75 mph have a 92 cc longbox 4x4 your fuel numbers are what my truck does pretty much. My range is just a tad over 400 miles and our fill ups are about the same too just a fyi.
#3 |
Re:Fuel tank
JBolt,<br>You are not alone. My 92 W250 does exactly the same thing. Kinda worried me at first but after 2 or 3 fills i got the hang of it.
__________________
It's not dangerous, it's just not safe! 2007.5 3500! Dually! Megacab! 6spd STD! 4X4! 2009 Dutchmen 27B Sport! DTR Megacab Club Member #315 |
#4 |
Re:Fuel tank
hehehe-<br><br>I've been driving it for almost ten years. Don't know why it's bothering me now.
<br><br>Oh wait... I know... IT'S DTR's FAULT! ;D (see the "I Hate This Site" thread in the "Other" forum)
#5 |
Re:Fuel tank
My 90 is pretty funky like that. I've been told that you can only expect to get 26 gallons in a 30 because of the foam.<br><br>Brian
__________________
1990 250 4x4 CTD AT regular cab 8 1/2 ft. Western plow. |
#6 |
Re:Fuel tank
My gauge must be broke! ;D It reads fairly linear. Roughly 100 miles per 1/4 tank, unloaded. If anything, it seems to go a little further on the second half. Takes about 24 gal. to refill after the low fuel light comes on. I have put as much as 28 gals. in on a refill, and have never run out (so far).
__________________
'79 Chevy K30 Silverado crew cab, SRW, 1st gen Cummins, 5 spd., NP205, Dana 60 front, 14 bolt rear, 4.10 gears, K&N '93 W250 Club Cab LE (sold) |
#7 |
Re:Fuel tank
I've noticed the same situation and thought about it. My guess is that as the tank gets lower, there is less fuel to cool the returning fuel. This returning fuel is warming the fuel in the tank causing it to expand. After it sits a while, the gauge also reads lower than when I left it. Yes, I checked for leaks just to be sure. Sound reasonable?
__________________
MIDTR 90 W350, flat bed, xtra leaf all around, Jasper 3spd auto, 16cm housing, tampered pump, Isspro pyro/boost, piller pod, BHAF, 93 radiator mod, Superwinch lockouts, Moog, 2nd D70. The number you have dialed, 9-1-1, has been changed... to an unlisted number. Freedom is everybody's job! |
| Display Modes | |
