Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 2nd Gen. Dodge Ram - No Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 04-18-2009, 11:41 AM   #1
jcarrillo
jcarrillo's Avatar
Fuel Tank Sending Unit
My 02 has gotten in the habit of running out of fuel with just over 1/4 of a tank and I have also been having problems with the fuel pump so I decided to install a heavy duty gear rotor pump and a new fuel tank sending unit. I called dodge and they told me they only sell it with the pump and it is $432.00. I explained to the parts guy that I only wanted to have the sending unit and I didn't want to pay $400 plus for just a sending unit. Does anybody here have just the sending unit less the pump or know how I can fix mine.Any help here would be greatly appreciated.
__________________
Oilfield diesel mech. in S.Texas.
'02 3500 drw 4x4 SLT Laramie: Inj. pump @205k miles. 8.3L ISC sply pmp,Vulcan draw straw, 1/2" fuel line, big line kit, Big Hoss tnr,strt exhst, s. ring mia, k&n air fltr, pure power oil fltr, fuel pres, bst, pyro, and trans temp guages, mag-hytec pan, cstm bilt g/n hitch.
'05 3500 srw 2wdr. SLT: k&n air fltr, s. rng mia, hider g/n hitch. 50hp DDP nzzls comin.
" Never argue with an idiot, he'll drag you down to his level and win through experience"
jcarrillo is offline   Reply With Quote
Old 04-18-2009, 12:12 PM   #2
GFB
GFB's Avatar
I just fill up when I hit 400 miles. It's a lot cheaper and easier than dropping the tank lol.
__________________
2001.5, 4x4, NV4500, Adrenaline/Pulse, Super B, stage 5 jammers, walbro, 4" to 5" miters, 2" Skyjacker, 315 BFGs, valair 13" OFe, tunes by Alpine and JL.
GFB is offline   Reply With Quote
Old 04-18-2009, 12:28 PM   #3
jcarrillo
jcarrillo's Avatar
Well I bought a new vulcan performance draw straw and have to pull the bed to install that and the aftermarket pump so i'm going to do it any way. I also pull a trailer and that changes your milage depending how heavy a load your pulling.
Old 04-18-2009, 07:30 PM   #4
infidel
On the 12 valve the sending unit only is Dodge p/n 4797738, $54
Far as I know the same sender was used on all years.
You can also buy a reman entire tank module from the dealer for $125.
__________________
Bill
'95 2500 4x4 auto
'95 3500 5 speed flatbed hauler
stock for one day
infidel is offline   Reply With Quote
Old 04-19-2009, 10:26 AM   #5
jcarrillo
jcarrillo's Avatar
Thanks, found a place called tristarradiator online that rebuilds sending units and they have parts including the variable resisters by themselves. I e-mailed them and if they have the one for my truck at a resonable price I am going to try that. I'll let yall know how it goes. I'm sure mine is'nt the only one doing this.
Old 04-21-2009, 03:28 PM   #6
kawi600
kawi600's Avatar
Quote:
hope you got the draw straw that replaces the bung on the sending unit and not the one that you make holes for, etc.
The straight tube one will let you run out at 1/4 tank since theres no baffling and air gets in.
The other type that replaces the bung on top is great, but I used a section of hose to the stock pick-up instead of the whole straw. The bottom of the picup unit is a float and a couple valves and it might not work well with just a straw in the bottom of the sender.
__________________
95 Ram 2500 220k mi, DTT auto w/ 4 disc converter, PS62/12, 4" exhaust, AFE filter, rebuilt 215 pump, TST AFC kit, #10 plate, 181 DV's, 7x.010 275BAR 148* Injectors, GS3K, 18*timing, Hamilton 210/181 cam, springs, pushrods. Hamilton 12v head, 625 studs, orings, snow water/meth
Dont blame me, I supported Ron Paul
Toute nation a le gouvernement qu’elle mérite
kawi600 is offline   Reply With Quote
Old 04-22-2009, 12:49 PM   #7
jcarrillo
jcarrillo's Avatar
I havent pulled it apart yet since I have'nt got all my parts. The kit I bought from vulcan though has the bung that looks like it goes in a grommet and it came with a hard tube and a hose. I figured I would see how I was going to put it together once I had it apart. Still trying to figure out how I am going to fix my sending unit. So far no dice.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
