Thread Tools | Search this Thread | Display Modes |
#1 | ||
fuel pressure problem
#2 |
Stock pumps will do that when they start to fail. I went through several of them and had new ones do that within a few thousand miles. If you can afford it I'd suggest going to a different lift pump setup. I'm very happy with Walbro. Read the posts on lift pumps and you can decide what is best for you. Good luck
__________________
bear 02 QCSB, 5 sp, 4x4, 4" mbrp, di procol, Van Aaken, Howards cool down timer, Vulcan fittings, Walbro 392, M1.6. |
#3 |
My last one done that. It is still on there, but the fuel line to my FASS goes right around it.
__________________
SUPPORT OUR TROOPS ! 1999 Ram 2500, SLT Laramie, Quad Cab, LWB, 4X4, 5 Spd, Camper/Trailer Tow Pkg, LS/RE, Westin step bars, Ram molded splash guards (front and rear),diamond pattern bed caps and toolbox, Isspro EV boost, pyro and FP pillar mount. FASS II on 6/5/05. Rancho RS9000's on 8/23/05. RV275's on 12/11/05. AirRites on 3/5/06. MBRP 4" on 3/14/06. DSS on 4/8/06. Smarty on 10/12/06. New front rotors and axle seals: 8/08 Jammer 3's on 9/6/08, South Bend Con O on 1/30/09 304/718 on 4/1/06. |
#4 |
Yep! Thats a good solution.
| Display Modes | |
