Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 10-10-2005, 01:24 PM   #1
jd4030
Fuel left after fuel light comes on
Does anyone know approximately how much fuel is left after the fuel light comes on? I'm guessing about 6-8 gallons.
__________________
2002 Laramie SLT 2500, Quad Cab, 4*4, Auto, 4:10's, Limited Slip, 45k miles, Stock
jd4030 is offline   Reply With Quote
Old 10-10-2005, 01:46 PM   #2
tmleadr03
I figure about 10. My truck as 34 gallons and if I hit up the station right at the gas light I can get in about 25 gallons.
__________________
2003 Jetta TDi Manual
tmleadr03 is offline   Reply With Quote
Old 10-10-2005, 01:47 PM   #3
phox_mulder
phox_mulder's Avatar
I've ran mine down to the light only twice, and each time was only able to squeeze 28-29 gallons in,
34 gallon tank makes that 5-6 gallons.
Been said numerous times, but it's bad mojo to let it get that low.
VP44 is relying on nice cool fuel to keep itself cooled and lubed, once you get that low the fuel is no longer cool, but quite hot.
phox
__________________
2002.5 Dodge Ram 2500 4X4 SOLD
2009 Jeep Wrangler Unlimited X 4x4.
Detonator Yellow in color
Bone stock for now, at least for a couple months
2008 Harley Davidson FLHR Road King.
Black Pearl in color
12 inch apes, stainless cables, Vance & Hines pipes, garage door opener, combo speedo/tach
phox_mulder is offline   Reply With Quote
Old 10-10-2005, 06:12 PM   #4
jay05torque
my 05 had 4 galloons left, we were running back from out west, and gas supply was not good in the area!
jay05torque is offline   Reply With Quote
Old 10-10-2005, 08:18 PM   #5
Huff nPuff
You don't want to find out
Quote:
Letting it get that low could cost you an injection pump.
__________________
A 2001 auto 4x4 quad cab,Tim Barbers twins & aTim Barber DTT trans, Fueled with a set Dons Mach 6s and an Edge drag comp with a custom built fuel system 12.11sec @111mph w/636.1HP& 1200ft lbs of tq so far on #2 only.
Huff nPuff is offline   Reply With Quote
Old 10-10-2005, 08:29 PM   #6
oestreich84
oestreich84's Avatar
I think I got the short end of the stick. I only have a 28 gallon tank. I usually fill up at 1/4 tank and it takes about 20 gallons. Was the 34 gallon tank an option?
__________________
SOLD 98.5 2500 regular cab, long box, 24 valve, 5 speed, 3:54 rear, 5 inch straight pipe,autometer cobalt series boost and pyro gauges, isspro fuel pressure gauge, Fram boost intake, jammer 3's , edge comp with MAP unplugged, Holley Blue inline fuel pump, 285/75/16 Mastercraft Courser CT's, high flow banjos, Now sadly driving a 92 ranger with a 4.0 and 5 speed.
oestreich84 is offline   Reply With Quote
Old 10-10-2005, 08:57 PM   #7
Dr. Evil
Dr. Evil's Avatar
phox
Good advice....I rarely let mine get under a 1/4 tank
__________________
DTR Truck of the Month Winner - March 2007
Dr. Evil is offline   Reply With Quote
Old 10-10-2005, 09:21 PM   #8
tmleadr03
I was under the impression it came with the long bed extended cab truck. You had to get the long bed short cab to get the 35g tank.
Old 10-10-2005, 09:35 PM   #9
drew03
drew03's Avatar
i heard 15 somewhere. i dont know where i heard that at.?
__________________
03 2500 6 spd 4x4 quad cab short bed 285/70/17 4" straight pipe with 5" stainless steel tip. fass 150
IAFF Local 176
drew03 is offline   Reply With Quote
Old 10-11-2005, 12:38 AM   #10
CJ
CJ's Avatar
My understanding is that the extended cab short bed came with 34 gal tank and extended cab long bed/regular cab long bed came with 35 gal tank......could be wrong
That being said I have never been able to put more than 27 gal in mine CJ
__________________
2002 3/4 4x4 HO 6spd 4"exhaust BHAF Boost/EGT/FP
va5 Jammer III'S Six States Dist Stage II AFS Big Dog Fuel System
CJ is offline   Reply With Quote
Old 10-11-2005, 01:08 AM   #11
newriverSpecon
newriverSpecon's Avatar
Hmm,
I understand the premise guys but mine is functional and from all indication on the pump is original. I think it may have some issues but they seem to have subsided. That said I have put 32 once and usually (depends on my plan for the weekend and the next week) fill between the light and the bottom of the E. It is between 26 and 30 gal.
It did bite me once. My guesstimate was off by about 15 mile and I hit an incline. I got to sit on the side of the freeway for three hours after work one morning. I could not for the life of me get it to prime the Jet-A a co-worked brought to me. My dad drug me to the shop and we cranked on it for a while and it lit.
Randy
BTW, long beds 35 short beds 34. Gas short bed 26.
__________________
'99 2500 4x2 5 speed 3.54 OPEN 235/85R16 Michelin LTX M/S, 174,000 miles, Topper, Autometer Ultra-lite Boost, Pyro, BHAF w/insulated box, muffler gone. Van Aaken, Holley Black, custom -8 lines and filter (factory mess gone),13" Con FE, BB pilot bearing, Red Tops, Trans Filter
'97 2500 4X4 5 speed original clutch (it will slip, Con O in work), 3.54LSD,135,000 miles, QC LWB, Banks Power Pack, Maxxis Mudders 315/75R16, Thuren track bar, KDP MIA, Timing @ 16.5, 5th gear gone for now.
newriverSpecon is offline   Reply With Quote
Old 10-11-2005, 11:31 AM   #12
eights88
eights88's Avatar
I though I real in owners manual its 10% left in tank?
3-4 gal
__________________
06 mega cab Larimie 2500 4x4 Auto 3.73 gears K&N filter Gauges 5" cat back with 7" tip all MBRP superchips/flashpaq missing silencer ring new set of tires 285/75/17 nitto terra grabbers. 27bh jayco jay flight tt.
Old truck 2003 quad cab ctd ho black k&n filter mt 33x12.5x17 tires on stock rims auto short bed
DTR Megacab Club #65
eights88 is offline   Reply With Quote
Old 10-11-2005, 11:46 AM   #13
Flashdancr
Flashdancr's Avatar
About 8 gal. left with the 35-gal tank.
I would imagine more people will let their trucks get down lower on fuel before filling up in hopes that the prices have gone down. I have been maybe it’s not such a good idea. Failed to think about the cooling aspect.
__________________
95 Dodge Diesel 1 Ton Dually, Dixie Custom Truck, Red & Gold. Turned up and runnin' sweet! January 2005 TOM winner.
"Silly Boys Trucks are for Girls!"
Flashdancr is offline   Reply With Quote
Old 10-11-2005, 11:50 AM   #14
RowJ
RowJ's Avatar
Only do it on mine on long trips....takes 25-26 gallons.
Oestreich84 - Mine only takes 22 gal at 1/4 tank. Takes a long time to got down from there. I believe all second Gen trucks are either 34 or 35 gal.
RJ
__________________
02, 2500, QCLB, 4x4, Auto, 3.55 Power-Lok LSD - DTT/Billet - Smarty- Mach 4's - BD Twins - O-Ring/Studs -Snow's H2O/Meth - FASS - F-1 Cam/Valve Springs - HTT Manifold - Road Armored - 5" pipe - TC Lockup Switch - 3rd Gen Brakes, Wheels & Trackbar - Fluidampr - DSS - 33" Pro Comp Xtreme A/T's
RowJ is offline   Reply With Quote
Old 10-11-2005, 11:57 AM   #15
CTD NUT
CTD NUT's Avatar
Quote:
Both of my CTD's have the 35 gallon tank.....the light on my 98.5 comes on when there is exactly 10 gallons left in the tank which is 1.25 gallons more than a 1/4 tank.
__________________
03 3500 QC DRW 4x4 6spd HO-4" PRXB w/04.5 down pipe, MBRP 304 Duals, Smarty Revo 4.19A, Commander/X2 Race, Flux 1's, Icebox, home brewed intake horn, ported HE351, Turbosmart, South Bend Con-OFE clutch, leveled, 5100's, Dynatrac Freespin hubs, Accuride 19.5's, DSS
98.5 3500 QC 4x4 24v 5spd-SOLD
94 2500 4x4-SOLD
CJ Juggy-Goes really fast, goes really slow, lots of smiles per mile
CHAPTER PRESIDENT ONDTR #39 contact me to join
"Madness takes it's toll....please have exact change ready"
CTD NUT is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
