Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 09-20-2007, 08:37 PM   #1
Ceejmo
Ceejmo's Avatar
Fuel Leak
I have a fuel leak coming from the area with the red arrow. I think this the governor shaft. What are the chances of removing the hex nut, washer and replacing the O-ring without pulling the pump. There's not much room there. Can it be done?
Click the image to open in full size.
It doesn't look like it's coming from either of the fuel lines. It appears to be coming from the hex nut.
_________________________
CJ Elmore
The wife's truck: 1994 F350 Super Cab XLT 7.3 IDI Diesel, was E4OD auto now ZF5 manual
My Truck - 1990 D250 5.9 Cummins, Getrag 5 Speed, Straight Piped, Slightly tweeked pump, tow hooks on the back
My project - 1990 Dodge Ramcharger gonna get a Cummins
Ceejmo is offline   Reply With Quote
Old 09-20-2007, 10:37 PM   #2
rlyons
rlyons's Avatar
The pump has to be pulled and disassembled to reseal the governor shaft seal.
__________________
92 D250 Club Cab 4X2, 5 speed, ASA Modifieds Intake, Jannetty Racing Team Exaust System, Tweaked Pump, 3200 RPM Governor Spring, M&H M3 Fuel Pin and Timing Spacer, HTT Stage III Turbo w/16cm2 , Pyro/Boost/Tach Guages, Power Wagon Injectors, KDP Tabbed, Borgeson Steering Shaft.
rlyons is offline   Reply With Quote
Old 09-21-2007, 04:57 AM   #3
Ceejmo
Ceejmo's Avatar
Quote:
Not the answer I was hoping for. Oh well, I guess I get to pull the injection pump.
Thanks,
__________________
CJ Elmore
Wife's truck: 94 F350 7.3, was E4OD now ZF5 tow hooks on the front
Wife's other truck - 99 Ford Ranger
My Old Truck - 90 D250 5.9 Cummins, G360 5 Speed, tow hooks on the back Became Donor for RC
SOLD project - 1990 Cummins Ramcharger
My Truck - 98 Jeep Cherokee
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
