Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 2nd Gen. Dodge Ram - No Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-17-2009, 10:58 AM   #1
jivemother
fuel gauge
working on a 99 ctd 2500 4x4 170,000 miles . fuel gauge does not work stays on E all the time kinda did float around but now nothin . sound like the sending unit . were should i start ? thanks
__________________
2003 2500 4x4 reg cab,
4 inch exs, turbo back , Goerend Transmission, Power puck,Predator stack,Silencer Ring whats that, gutted air tube,boost fooler,pluged waste gate
73 dodge dart swinger 340
custom rigid chopper 110 c.i. 6-speed 250 rear tire
07 Gsxr-1000
jivemother is offline   Reply With Quote
Old 11-17-2009, 04:26 PM   #2
jivemother
bump
Old 11-17-2009, 04:58 PM   #3
illEatUrDuramax
illEatUrDuramax's Avatar
sounds like a sending unit to me. lift your bed and check it, its easy to take apart. either the float fell apart or the circuit board went out. its really an easy fix. i think i paid like 50 bucks for a new one
__________________
2001 2500 SLT, 4x4, NV5600, 3:55's, straight piped stock exhaust for now, silencer ring = glove box, 117K
SOLD - 1996 2500 SLT, 4x4, NV4500, HX-40 downpipe to 4in exhaust, #100 plate, 370's, KDP Tabbed, silencer ring in glove box.
illEatUrDuramax is offline   Reply With Quote
Old 11-17-2009, 05:00 PM   #4
jivemother
ya thats what i was thinking , but i read some were that some one had same problem and it ended up being the guage cluster in the dash ..
Old 11-17-2009, 05:18 PM   #5
illEatUrDuramax
i heard about that too. hopefully someone will chime in and help. about a month back i had to clean the filter in the tank because it was clogged and left me stranded. had to get towed home. anyways i cleaned it and connected everything, well i guess one of the wires wernt connected tight and my fuel gauge stopped working again. i ended up saying screw it, i just use my trip meter now. so like you said, if it was working but now its not, it could also be a loose connection. sometimes when i fill up it will start working and go to full, but as soon as i get on the road, it stops again
i would start with the sending unit first. just loosen the bolts and have a few buddies tilt the bed sideways and shove a long piece of 2x4 under the bed to hold it up
Old 11-17-2009, 07:00 PM   #6
Tate
Tate's Avatar
Check the plug going into the module. Mine have an intermittant connection problem everyonce and a while where it goes to empty, or about 1/16th tank, even though I may have just filled it up. Disconnect the plug and clean it real well with contact cleaner.
__________________
'98 3500 4x2 Quad Cab, 24v, 5 spd, 3.55s, No Plate, 4k GSK, 23° Timing, DDP Comp Injectors, Silver Bullet, Big Stick Cam, FASS, BD Short Shifter, SBC DD, Fluidampr
Alcoa Magnums, GM Brake Cylinders, HID Headlights, DSS
'98 2500 4x4 Reg Cab, 12v, 5 spd, 3.55s, 0 plate, 3k GSK, 15° Timing, SBC DD, F1 370's, 64/71/0.80 Turbo, Fluidampr
Alcoa H2's, Lorado Tonneau Cover, HID Headlights, Espar D5, EMS Hub Conversion
Tate is offline   Reply With Quote
Old 11-18-2009, 08:24 AM   #7
blackimpala
Not sure about this but on older cars you could ground the lead going to the sender and the gauge would go to full. This would tell you if the gauge was good.
Floyd
__________________
96 4X4 Auto, Gauges, Full time power windows, headlight relays, By-pass filter, KDP Done, Lukes Link, GM Wheel cylinders, removed fuel heater.
I need no stinking chips.
For those who fought for it Freedom has a taste the protected will never know.
blackimpala is offline   Reply With Quote
Old 11-18-2009, 10:55 AM   #8
littlebuddie
Unless the problem is evident once you pull the sender out of the tank, you can check the condition of the sender by using an ohm meter. 20/200 ohms is the range for these senders. 20 being the 'full tank' end of resistance, 200 on the 'empty' side. It's a good indicator in your process of elimination. Pulling the tank is not a waste of time because you can clean the thing out - and they do get a bit gooey after time.
__________________
1999 Ram 2500 Quad Cab 4X4 Shortbed Cummins 24 Valve, 5 speed manual, NV4500HD, NV241HD, model 60 and 80 Dana Diffs - All Stock.
littlebuddie is offline   Reply With Quote
Old 11-18-2009, 04:53 PM   #9
jivemother
hopefully get into this weekend on monday i ll lit u all know wha ti find out thanks
Old 11-24-2009, 04:19 PM   #10
jivemother
well got it fixed up pulled the bed off , pulled the sending unit out . replaced the arm and float and new level unit . was like 50 bucks from dealer . works good now , thanks for the help
Old 11-24-2009, 06:14 PM   #11
littlebuddie
Glad you got that fixed!
Out of curiosity, which part number did you get? My '99 had an odd-ball sending unit used only for a couple of years in the 2nd Gen. I had to use part #4897669AB. Just wondered if all '99's were the same.
Old 11-24-2009, 06:17 PM   #12
jivemother
half to loook, had same problem the first one was rong , it had no wires cooming out of it had push on connecters, mine had long wires had to take the plug apart to change it . lit me look and get back to ya wont be till after holiday thow of for the next 5 days lol
Old 11-25-2009, 01:35 PM   #13
littlebuddie
Thx, Happy Thanksgiving!
Old 11-30-2009, 02:59 PM   #14
jivemother
well this 99 i had to use part# 4897669ab
the first one i got was wrong part# 4897670ab
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
