Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 2nd Gen. Dodge Ram - No Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 09-04-2007, 05:50 PM   #1
ol red
Fuel Gauge
i WOULD LIKE TO KNOW WHICH WIRE IS THE GROUND ON MY FUEL TANK SENDOR ON MY 98 DODGE. I PUT 3 GROUNDS ON MY TRUCK THIS PAST WEEKEND AND SO FAR THE FUEL DUZZER DOES NOT RING ALL THE DARN TIME . BUT THE FUEL GAUGE STAYS ON EMPTY ALL THE TIME NOW. SO I WAS THINKING IF I COULD GROUND THE FUEL SENDER BETTER IT MIGHT WORK. I WOULD LIKE A LITTLE HELP THANKS SCOTT.
__________________
1990 dodge 3/4 ton 4x4 automatic727 3 speed non ic with 459 K on it 4 inch exhaust with 5 inch stacks.POD'S. Pump timed all the way to head.fuel screw turned in till runaway then back off 1/2 turn. 3200 gov spring new Gillet diesel compressor housing an 60mm wheel.New 3 inch cross over pipe.And yes all gauges.Pull cable KILL. BHAF an outterwear. flat bed galaxy 99 cb radio with a monkey made antenna 10 chicken lights on front bumper. 1998 DODGE 2500 AUTOMATIC 2 WHEEL DRIVE 211000 MILES.
ol red is offline   Reply With Quote
Old 09-04-2007, 10:01 PM   #2
oldblues
oldblues's Avatar
hi
most likely you will have to drop the tank and remove the fuel gage sending unit and repair it or replace it .
pulled mine out and took 3 min to repair it !
just make sure all 3 little contacts tuch reastat thinger .
mine is rock steady now !
__________________
98 ,12 v, auto, quad, 4x4, 3.55 g r, 313,000 , ssi bracket,06 track bar ,air lift air springs 5000lb, ranchero adj shocks,10plate,16.1*timing,kdp tabed ,urathane sway bar mounts, transgo TFOD-deisel ,atf+4 wallmart,apc headlight wire harness 509104,flosser 9104,xpc sway bar end links sk7280, egt,boost,tran temp gauges ,raybestos 37337 rear wheel cyl. automatic lockup mystery switch, rotella 5 w 40 syn, MKO 4" exhaust,heater water shut off,3000 gsk, big trany cooler w/fan , many new stock parts!
oldblues is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
