fuel cutting out
so the deal is everytime i get on it like at over 55 it will cut out a few seconds after i punch it so i will let off slow down to about 40 then the truck majically turns back on and all is good and then it will do it again a while later i beleive it is a fuel filter but idk
__________________
91 d-250 3200rpm massive pump tweeks non ic 34psi limited slip no one tire fire derik only the best pro sport gauges boost and egt |
Fuel filter is a good first step. If that doesn't cure it, a new lift pump is not a bad idea.
__________________
Dave 386 HP/774 TQ on #2 only, 408 HP/844 TQ w/ water/meth - needs more air! "Butterscotch" - '82 Mercedes 300TD KDP body count: 72 |
The 93's are pretty bullet proof, but check the wire that controls the fuel pump shutdown if it is not a filter issue.
__________________
Cruising the byways of middle age on a HD VRSCSE Screamin' Eagle. |
i put a new filter in it and so far all is good
__________________
| Thread Tools | |
| Display Modes | |
