Fuel Additives???
Quick question about Fuel Additives in the new 6.7. I've always used lucas fuel additives in all my other dodge trucks ie..5.9L and was wondering if doing so in the new engines could cause any problems with the smog control devices or filters.
Thanks |
I would only run a fuel additive that says its compatible with diesel particulate filters.
__________________
2007.5, 2500, QC, Laramie, 4X4, SB, 68RFE, 3.73, Inferno red, MaxBrake, Edge Insight w/pyro, Firestone Ride-Rite, EZ Change Drain plug, S&B drop in air filter, 250 watt oil pan heater, EGR unplugged. 2008 YZ450FX, matching 756's, Marcel Fournier ice tires, billet fuel screw, DiD narrow x-ring chain, Ironman sprockets, Scotts SS oil filter, Dr. D pipe coming, love the SSS suspension... |
Thanks for your help. I'm not real sure if Lucas has that product yet
Depending where you are, I've had REALLY good luck with Diesel Services Group fuel additive.
__________________
[quote=klx650a2;2605461]Depending where you are, I've had REALLY good luck with Diesel Services Group fuel additive.[/QUOTE
I will not step close to DSG anymore. ![]()
__________________
My work truck, 2003 ram 3500 with service body,nv 5600,373 gears, air aid air filter,espar heater,flux 1 injectors, isspro egt and boost gauges. |
what did you notice? better mpg, etc?
__________________
68 Dodge Charger R/T 95 Ford Mustang Cobra SVT 01 Ram 2500 QC LB, auto, K&N air filter. |
.[/QUOTE
I will not step close to DSG anymore. [/quote]care to elaborate any further???
__________________
2001 Ram 2500, auto, 3.54's, quad cab, boost, fuel, & pyro gauges, Qzilla XZT+, Magnaflow 4", FASS DDRP The Womans Ride...2005 Jeep Liberty Limited CRD, not a Ram, but a sweet ride pride & joy... 2007 Victory Vegas Jackpot Arlen Ness Edition Originally Posted by Gotlift01 ........and if anybody disagrees on that you earn the right to be slapped in the back of the head. |
I use Miligan's canola oil additive in both the 98.5 and 07.5 dodges and 3 farm case tractors. I went through 3 inj pumps on the 98.5, then started using Miligans no more problems. Been 4 yrs since last inj pump. Could it just happened that way or it could be the Miligan's I don't know. Being a lic hd mechanic, we used to sell both Miligan's and Lucas. We tested both in -30 c weather. 1L each left outside for 10 hrs. Brought inside and tried to pour into diesel fuel miligan's poured and instantly mixed into the fuel with stirring. Lucas came out in globs and we had to stir like crazy to mix. You could still see the lucas from the diesel. The miligan's you could not tell. I'd use miligan's. Just my 2 cents.
My owner's manual says not to use additives, and thats good enough for me. My 5.9 didn't need any either.
__________________
2008 3500 CTD Quad Cab LB SRW 6 speed Auto 4X4 3:73 P3 Brake Control White Born 09/07. |
THe new diesel fuel does not have the lubercation factors that the older fuel had. Cummins representatives have told me to make sure I add an addative for lubercation and injector cleaner. I use Diesel Kleen and can tell a difference. Working in the trucking industry and dealing with many Cummins folks weekly, I listen to the factory guys.
Quote:
__________________
Quote:
__________________
2007.5 Ram 3500 SLT 6.7L Megacab, 4x4, 6sp. Auto, Electric Blue, Nav & 6 disc changer, Smarty S67 ME14 (SW3), Revertable EGR Plugging and Exhaust Deletes, S&B intake, Amp Research Steps, Prodigy Brake Controller, Wolf Liner O.T.R. DTR Megacab Club Member #152 |
__________________
2006 Ram 3500 4X4 Larame Mega Cab, Smarty, True Flow intake system, upgraded full flow muffler, 315/70/17 BFGs on H2 wheels RoadWarror front bumper w/lights, custom winch rear bumer, air bags, 45 gallon aux fuel tank, headache rack w/rolling tonneau and more. 1985 GMC K3500 4X4 Cummins CPL600, GM/NV4500, NP205, Gear Vendor, custom bumpers with 12,000lb winches front and rear, 12/35/16.5s, posi front and rear, custom bucket seats. I built this in 1996 and has about 300k miles. |
WE have the 5.9 in an 2005, 103,000 miles. We had a visit last fall from 3 Cummins representatives from the factory in Whitakers,N.C., ISX factory in New York and the other was from the corporate office. They were checking the engine shipping skids for complaince, secuirty and so forth. The representative from the N.C. plant, which is where rthe ISB,ISL engines are manufactured, remarked about the new emmissions and diesel fuel. He stated the new fuels weren't as good due to the lack of luberication properities. He asked if I ran an addative and I reponded Diesel Kleen. He then said, never stop! All diesel engines weather automotive, commerical or marine should have a addative now to keep the fuel pump and injectors lubericated and clean.. I also heard this from an owner of a motor home when his fuel system failed after 17,000 miles. Cummins advised him the same to prevent pump failures and injector failures. Also, change the fuel filter every 10,000 miles. I can say, using the addative, the throttle response is smoother and we get an average of 23MPG by the pen, 27 by the truck display around town to work. Towing a 23' CC boat to the coast and back, 16MPG. We have added the Super Chip programed for towing preformance and an K&N air cleaner. We don't dog the truck, keep it serviced every 10,000 miles and use the synethic Shell oil with a Mobile 1 oil filter.
It's interesting that the manual for my '07.5 6.7 CTD specifically states that fuel additives aren't recommended. I do agree with what you guys are saying but still wonder why D/C made that statement.
That being said, I do use Diesel Kleen but ONLY on occasion. I may start using it more regularly now upon reading your suggestions. Still, WHY does D/C recommend against additives in the book? Any ideas?
__________________
2007.5 Dodge Ram 3500/6.7 CTD/SRW/SB/4X4/QC/G56 trans/Big Horn Edition/mineral gray/16k Hijacker manual slider hitch. Bone stock |
| Thread Tools | |
| Display Modes | |
