Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 06-20-2005, 11:26 AM   #1
beau55
Front springs
On my 93, should the front leafs have a slight negative arch, or is that just sagging? It is a 4x4 and those are obviously some pretty beefy springs but I would do just about anything to improve the ride, even a little. If they are indeed sagging, seems to me this would 'eat up' what little working range these stiff springs had, like when they were new!
__________________
1993 W250, 179K, A518, NO MUFFLER, Performance Pump (w/ serious advance) and Injectors. Illegal window tinting[whistle]
beau55 is offline   Reply With Quote
Old 06-20-2005, 11:47 AM   #2
mainer
mainer's Avatar
mine dont have a negitive arch on them but they are flat. Change the amount of air in your air shocks to change the ride.
__________________
1998 2500 ext-cab short bed 12v 4x4 126k
6" mitre cuts, 16.5* timing, #0 plate, rack mod, afc mod, 215injectors, 3kgsw, bhaf
goerend bros triple disc, transgo shift kit
home built traction bars, eagle 058's on hankook mt's 295, 20% tint
mainer is offline   Reply With Quote
Old 06-20-2005, 12:16 PM   #3
beau55
I would, but I don't actually air shocks.
Old 06-20-2005, 12:29 PM   #4
mainer
mainer's Avatar
mine came stock with front air shocks, guess I was lucky. LOL
Old 06-20-2005, 01:19 PM   #5
apwatson50
apwatson50's Avatar
OE shocks were not air shocks. My springs did have a negative arch, and I know of 2 other dodges out there with negative arch, because they have sagged. This engine is really really heavy. Now you can see I have the skyjacker 2.5in lift springs ride is much better and they actually have positive arch. There is also about 3 more inches between the bump stop and spring now than there was before.
__________________
92 Black W250 295K, getrag, valair 13" ceramic clutch, dana 80 3.54, HX40, DDP3 injectors, high pressure piston LP, custom IP, M&H M2 fuel pin, PS charge air cooler, 4 in exhaust w/ brake, gauges(and lots of them) Leece Neville power.
89 FUMMINS F350 4x4 crew cab, VE 12V, A518 trans, ford np205 t-case, PS cooler, hybrid HX35, low pressure piston LP
http://s218.photobucket.com/albums/c...Truck%20stuff/
apwatson50 is offline   Reply With Quote
Old 06-20-2005, 01:32 PM   #6
mainer
mainer's Avatar
The plate in the door says that it has air shocks, it gives the amount of air to put in and everything.
Old 06-20-2005, 01:40 PM   #7
apwatson50
apwatson50's Avatar
wow, that must have been a very very special option, thats the only one i've ever heard of!
Old 06-20-2005, 03:07 PM   #8
beau55
I was thinking of putting 2.5 skyjacker springs on the front. Figured it would about bring the front up even with the rear, or maybe a touch higher, which would be ok with me.
How much did you pay for the skyjacker fronts?
Front OEM air shocks..mmmmm
Old 06-20-2005, 03:46 PM   #9
apwatson50
apwatson50's Avatar
I got the set and new bushings, you have to use the skyjacker bushings, for like 350 I think maybe a little less. wasn't too bad.
Old 06-20-2005, 05:36 PM   #10
mainer
mainer's Avatar
I want and looked at the vin tag and I will correct my self, they were not stock. The sticker is above the vin tag.
Old 06-20-2005, 06:28 PM   #11
pwrtripls1
pwrtripls1's Avatar
Air shocks are pretty cheap. I have them all the way around on my Blazer. I run 25psi around town, and 135psi off road. It gives me just over 2" more clearance and takes the big bumps better without bottoming out as much.
I full set on the Cummins might be a good idea.
__________________
--91 D250--5 speed, 3.07s, SBDD 6-puck, Scheid 14mm VE (no KSB), DDP5x16's, custom IC, 3.5" boost tubes, 64/12wg turbo, 19 gallon fuel cell, .040" Mahle Marine Pistons, 60lb springs, hardened pushrods, A1 H11 studs, Ported head, Valve seats and valves cut, 10lb bottle of go juice.
pwrtripls1 is offline   Reply With Quote
Old 06-21-2005, 08:29 AM   #12
Alec
The air shocks were part of the Plow Prep Package. I would guess that is what your truck has, Mainer.
__________________
'91.5 W250, Getrag, 3.54 axles. AFC eccentric @ max, spring @ 0 pre-load, thin washer; 1.9+mm timing; 1/2 turn on fueling screw; cam ground AFC lever; "negative torque" spring removed from governor lever. Hx-35 12cm W/G turbo. Pyro pre-turbo. 4" Exhaust DP-back; BHAF; 2nd gen fuel heater.
Twin-sticked transfer case; 7 leaf front springs.
Also Own: '49 Willys 4x4-63 with 6.2L diesel and NV4500 (wrecked)
Wife's: '10 Jetta Sportwagon TDI
Alec is offline   Reply With Quote
Old 06-21-2005, 10:04 AM   #13
pwrtripls1
pwrtripls1's Avatar
Mine is a plow truck, but doesnt have air shocks.
Old 06-21-2005, 12:17 PM   #14
apwatson50
apwatson50's Avatar
yeah but did it come from the dealer with a plow?
Old 06-21-2005, 06:37 PM   #15
pwrtripls1
pwrtripls1's Avatar
ummm, i dont think it did.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
