Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen Engine and Drivetrain -> 2003-2007
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 10-20-2006, 12:50 AM   #1
tx4x4er
Front end popping when in 4wd
I had to go pull a guy out of the mud tonight and when I put my truck in 4wd and started to pull him out the front end started to pop really loud. I have an 06 Mega cab.. It's went away when I took it out of 4wd.. any ideas On what it could be?
tx4x4er is offline   Reply With Quote
Old 10-20-2006, 01:55 AM   #2
XLR8R
XLR8R's Avatar
Did you have the steering wheel turned in either direction?
__________________
Lazar
Sleeps a flock of Rams & a Goat
GUN-HAPPY Crew Chief
XLR8R is offline   Reply With Quote
Old 10-20-2006, 06:19 AM   #3
Jus Cruisin
Jus Cruisin's Avatar
What was your truck on, pavement? If so it is the drivetrain "winding up" and then releasing because it isn't able to slip easily.
__________________
2008 Dodge 1500 Inferno Red Laramie Q/C 4X2 - sold - replaced with a "4 letter word" F250 diesel 4X4 8" lift
2006 Dodge 3500 Silver SLT Q/C Auto Dually 6X6 CTD Thunder Road added leather, chrome handles, grill and spears, tint, Thunder Road emblems -TRADED
Other toys:
2008 Roush 428R Mustang - black
2008 Corvette convertible - triple black
2008 Kawasaki ZX-14
1999 Valkyrie Interstate Sold
Jus Cruisin is offline   Reply With Quote
Old 10-20-2006, 12:22 PM   #4
tx4x4er
I was on a paved road. He drove off in to a feild and got stuck. I was backing up strate and pulling him sideways. I just got home from the dealer and they told me I did't have enough gear oil in the front diff and that the gears are shot and that I need new ones This truck only has 6,300 miles on it and they said it was due to my wheels and lift that the 22.5"s put to much stress on the front end . So I am sure this is going to be a long battle with my local dealership.
Old 10-20-2006, 12:28 PM   #5
XLR8R
XLR8R's Avatar
I'm sure the hop was from 4WD on dry pavement.
I think the dealer is BSing you.
The front diff ring & pinion turn full-time; fill it up with fluid and don't worry about it if it doesn't make noise and still pulls your buddy's truck out of the field!
Old 10-20-2006, 04:31 PM   #6
marc03
Lift and tires made the diff fluid low??? Hmmmm... A new one on me.
__________________
2003 3500 QC 4x4 H.O. 305/555 6Spd *sold*
2004.5 2500 QC 4X4 325/600 Auto
(Pioneer Avic d3 w/ Ipod, Alpine:type-r 6 1/2's 6x9's and 10" ,mrp-f250 & mrp-m450 amps), MBRP muffler & tip, Volant CAI & outerware, 4" superlift, bilstein 5100's, 18x9 KMC Hoss Black, ProComp extreme at's 35/13.5/18, Truxedo tonneau, edge juice w/ attitude, attitude/single gauge pillar, Isspro trans temp gauge,Line-x bed/rockers,mopar (tow hooks,fog & cab lights), Hella 500 lights,N-Fab nerfs,stull billet grille
marc03 is offline   Reply With Quote
Old 10-21-2006, 02:19 PM   #7
Pull U 2
Guest
I get a similar noise in mine. Only in 4x4 on pavement or dirt/sand. It sounds like something is binding but if that's the case it should do it in 2wd drive also. I've had the front end apart and checked everything. Axles, gears, bearings.....I'm lost. I've had this problem for a year now and just can't figure it out. The dealer went through everything also and ended up replacing the transfer case in Jan thinking that was the problem, which it wasn't, noise was still there. I wasn't too worried about it because 4x4 worked fine except for the noise until this past weekend. On the highway in 2wd doing about 80 my transfer case exploded, and I mean exploded! It blew out a 6" piece off the top of the case and cracked both halves of the case that was left. Truck is fixed already under warranty by a way cool dealer but now it's got me worried. tx4x4er, if you find anything else please post it! Not meaning to hi-jack the thread but if anyone has any ideas please post them.
Old 10-21-2006, 07:51 PM   #8
tx4x4er
I will have them check my t-case Monday just to make sure it's not that.Thanks for the help. I just love how they said it was my wheels and lift
Old 10-21-2006, 08:48 PM   #9
1sttruck
Big tires, 4x4, pavement, and towing will all put a lot of stress on the drivetrain, and the weakest link will see damage first. The front axle is the weakest link, but it could also be the transfer case. If I were a dealer and someone came in with damaged axles and they had big tires, I'd push back on warranty too. GM uses the same axles and I recall a comment by a GM owner that they don't honor warranty with anything but stock size tires.
__________________
03 2500 ST QC 4x4 SB 5sp SO 3.73, ARE Canopy, RhinoLiner, UltiMat dash cover, 2 bucket seats in bed
1sttruck is offline   Reply With Quote
Old 10-21-2006, 09:25 PM   #10
pooperscooper
pooperscooper's Avatar
Quote:
I would like to know why you think that the front axle is the weakspot? maybe u joints, but the ring and the housing are by no means weak. also, i am not so sure about the GM comment. i have a buddy with a duramax with 8inch fabtech and 37's and the dealer did the lift and gladly will do the warranty work. He blew out is rear ring @ 2500 miles after the lift, no questions asked. this maybe just the dealer, but who knows.
__________________
2006 Dodge Ram CTD, SWB, 4x4, 6 speed MT.
6" Lift with 37x13.5x20 Kuhmo M/T's on MKW m19's
Bushwacker Pocket Flares
SMARTY!!!! #3 (awaiting SBC DD)
MBRP replacement muffler
Silencer ring, MIA
High Idle enabled
DSS Stabilizer
Pricol Optix Gauges (Rail Pressure, Boost, Preturbo egt, Postturbo EGT)
Wanna be a future member of the Twins club...now accepting donations!!
pooperscooper is offline   Reply With Quote
Old 10-22-2006, 12:16 PM   #11
1sttruck
The u joints are designed to take high sustained and impact loads. When engaged the front axle is obviously weaker than the rear axle, and the transfer case is weaker than the rear axle. The question whether the transfer case is weaker than the front axle, and which will suffer damage first. Note that damage doesn't neccessarily mean break, as scoring gears will count as damage.
http://www.thedieselpage.com/feature...-editorial.htm
What you need to know before upsizing tires on your Chevy/GMC 2500HD
Written June 2005
While some owners feel anything less than 35's are too small, the 265/75R16 has always been a popular tire size for a heavy-duty 3/4-ton pickup when considering both function and appearance. However, all of GM's 3/4-ton pickups are factory equipped with smallish 245/75R16 tires, and GM has gone so far as to deny drivetrain warranty coverage if your truck is equipped with anything other than 245's. That's just plain dumb.
Update 5/20/06: The following email message was received from a fellow member, regarding tire sizes:
"I recently replaced the OEM tires on my 2003 GMC Sierra Duramax/Allison. Costco installed Michelin X-Radial LT 265/75R16 tires. They referenced 84-03 Mast Guide as fitment approval. It appears that GM approves the 265's as an alternate for the 245's. Have you heard anything else with regard to a policy change for GM? Regards, reparkerjr"
Old 10-22-2006, 01:44 PM   #12
XLR8R
XLR8R's Avatar
Rolf at Sky's The Limit told me that the transfer case chains are usually what goes first internally.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
