Go Back   Dodge Diesel - Diesel Truck Resource Forums > Other / Non Diesel Related > Other
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 08-14-2007, 09:41 AM   #1
JD730
Ford 289/C4 flex plate question.
I've been working on my neighbors '49 Willys Jeester with a 1966 289/C4 in it for a while now. The body is at the body shop getting painted.
We where going to try and start it on Sunday, spent the morning prepping it as it is a new engine.
I get it wired enough to run it and pre-oiled. I hook the starter up and go to crank it and I hear the starter run. Its not engaging the ring gear, looks like the pinion gear on the starter is too small in diameter.
Started looking at what starter he ordered and what its supposed to fit, its supposed to work with 157 and 164 tooth ring gears. We both count 168 teeth on the ring gear, both of them, the one that was in there before when i separated the engine and trans for rebuilding and the new one that was put in there.
Please don't tell me no such thing exists because we both counted it and it is the original flexplate, has FoMoCo stamped right in it.
Any ford 289 guru's out there that have a thought on this dilemma.
As it stands right now a new starter is on the way that should have the correct pinion gear on it, we'll see. Wish we had the stock one, but we don't.
Thanks,
Mike
__________________
Mike
That's not a leak, its the external lubrication system.
The "Rattle Box"
93 W250 Silver Club Cab, 47RH rebuilt by me with Goerend goodies, HTB2 62/12, hydroboost brakes, plus a few other things, 424/1039, 1/4 mile 14.00@94.3mph
2000 2500, 4x4, 6 speed, 12 valve, Homemade WH1C/HX55W twins
96 2500, Club Cab, AT
93 W250 Green Club Cab, AT
92 Club Cab, AT
07 2500, Quad Cab, 5.9L, Auto (Dad's new ride)
John Deere Two Cylinders, too many to list.
JD730 is offline   Reply With Quote
Old 08-14-2007, 11:01 AM   #2
JD730
Update: the installed flex plate is 157 teeth, neighbor just called to tell me that. He's going to count the other one again, maybe we both made mistakes counting it yesterday.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
