Thread Tools | Search this Thread | Display Modes |
#1 | ||
First Impressions of PS62-14
__________________
When all else fails step on it!! 2000QC, 4X4, 3 on the tree,Allison 5speed, 99 heavy duty inverted T steering, Borgeson steering box. BulletProof Track Bar, 4" exhaust Don M's 1.5's, Smarty, PS62-12 w/AFE intake, DT Radius arms (wow),Buckstop ft bumper and Rickson 19.5 wheels and tires, big brakes, Amsoil remote bypass filter system. Soon; custom rear storage bumper, traction bars,DM midpack springs, 351ve w/Fleece controller and bigger injectors, and a cooling system filter. |
#2 |
You definately need more boost. With smary and injectors I can hit 40psi. I also don't think that you've got enough fuel to spool a 14. I'm thinking a 12 mighta been a better charger for you. I'm also thinking that a small box like an EZ or smarty will help you out. They advance the timing and the timing really helps EGT's. I lost 200* of egt's just by adding timing to a stock truck.
#3 |
The truck has a catcher ( same as smarty on #9)
I tow heavy 13,000, so thats why I have the 14 which the recommended. I'm planning on adding a TST in the near future, but was told that this set up could work fine. |
#4 |
I'd say you need more boost then.
With smarty on 7 and 155hp sticks and 40psi of boost I can tickle 1250-1300* at 100mph. |
#5 |
I was told that the waist gate is set at 40 and that I should expect lower boost numbers than the stock set up. Is this correct?
Mark |
#6 |
Registered
should have went with the 12 with the auto?
adjust the screw in the boost elbow. see if you can screw it in farther |
#7 |
I was leaning toward the 12, Its what I originally wanted, but II kept telling me to get the 14.
What about my temps? |
#8 |
Lower boost at cruise but not at WOT.
#9 |
Was your boost higher? or about the same? What about temps?
#10 |
My boost was much higher than factory and temps were much lower.
#11 |
I'll go check the elbow on the waist gate.
Mark |
#12 |
i have the super phat shaft. turned the screw on the elbow in with my setup can spike 55 and hold 40-45 till fuel cut. i think my temps are cooler everywhere except crusing on the highway. before the injectors. i had less boost than i had with the stock turbo. but felt like more power
__________________
99 balanced engine 665cc pump 5ks 24* mach7s fuel boss 66/74/14/ht4b twins tcs conveter garmon vb billet in out 95 913 pump 6 plate 17* western plow |
#13 |
II wanted me to buy the super and it seems that would have been a mistake, but what I cant figure out is that the told me my temps should be no hotter than a 1000*, its the same as stock.
#14 |
They wanted you to buy the Super b/c it has some extra exhaust housing work to help with spool up, i think and its more $$$.
__________________
2001.5 2500 QC ,LWB 2wd OPIES billet input ,53 Block, Diesel pro cam P7100 Full cut dvs 6x.016 inectors HTT 62/71/13SS over a S475:) |
#15 |
Second day
Truck runs 200* hotter than stock! Empty!! Called II, They had me check the shaft and clamp off the waste gate hose. They said that this turbo should produce close to 40 lbs of boost on a stock truck and with my mods all I can see is a fast spike to 30 and a slow rise to 33 as the temps climb to 1400*. I'm afraid to hook up the 6000 lb trailer and leave. I'm beginning to think that someone does not know what they're talking about. Any one have any suggestions? Please One person pm'd me and told me he went through these same issues, he said I should of got a 57-12 because of the trucks gearing and low stall converter. Mark |
| Display Modes | |
