Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 07-31-2006, 09:47 AM   #1
ColoDodge
Fill r up??
Does anyone know why the pump stops when you can still put in about 5 or more gallons. It a real headache to actually fill up at the pumps. My 2000 dodge ram never had a problem with this. Did something change within the fuel tank to cause this. If anyone knows why this happens, or even better how to fix this it would be appreciated. Thanks
ColoDodge is offline   Reply With Quote
Old 07-31-2006, 09:56 AM   #2
SolarYellow05
SolarYellow05's Avatar
Do a search on here for a fuel tank vent mod. There is a company that sells the parts to fix this problem but I don't remember the name of them.
__________________
2005 Ram 2500 QC Solar Yellow G56 4x4 3.73 5" RC Lift 37X13.50-20 Nitto Mud, 20" rockstars, AFE Stg II, 5" MBRP, Quad X2, Smarty, Phantom gauges, II SPS 62, AirDog 150, SBC DD 3600 S
OTHER TOYS:
1977 Chevy K10 : 350, SM-465, NP-205, 6" lift, 38.5" TSLs, 4.88s, eaton posi, custom flat bed.
1994 2500 12v 4x2 REG CAB : Short bed, auto, 20s.....
1988 Suzuki Samurai, 4.3 V6, TH-350, D44s, 37" Xterrains, tube chassis, 104" WB
IAFF Local 865
SolarYellow05 is offline   Reply With Quote
Old 07-31-2006, 10:39 AM   #3
TonyB
www.innertruck.com
Great customer service.
Kit took 2hrs to install (drop tank...install kit...install tank) with a buddy and a motorcycle jack.
Kit increased usable tank volume to ~37 gallons; pre kit, usable volume was ~32 gallons. Best $35 spent!
HTH
Tony
__________________
My diesel Fleet:
2006 3500 QC LB Dually, Cummins, Auto, Jake, Laramie (no kitchen sink), Gauges for Fuel Pressue, oil pressure, Boost, Water temp, trans temp, diff temp, and pyro 19MPG Freeway/14.5 City
2006 VW Jetta TDI, 43MPG / 38 City, 570MPT
1996 VW Passat TDI 44MPG Fwy / 36 City, 700MPT
TonyB is offline   Reply With Quote
Old 07-31-2006, 11:55 AM   #4
4x4not
4x4not's Avatar
The federal government requires an air gap in all tanks, and since Dodge uses these tanks for gasoline too, they needed that big of a gap. Install the vent kit and be done. It is the best $50 and 2 hours spent on the truck....
__________________
05 Ram 2500 CTD610 NV5600 4.10 4x4 QC SWB
. . . . . . . . . . HOT Juice, ConFE, GDP 392 Comp, S&B, Straight Pipe.
. . . . . . . . . . Leveled, Bilsteins, MTZ 315s.
97 TJ Lifted. Locked. Unstocked. The tow toy. Back under the knife!
4x4not is offline   Reply With Quote
Old 07-31-2006, 12:02 PM   #5
Hairtrigger
Think of it like eating, When the pump shuts off the main course is over and time for desert!
__________________
I am one gun away from happy
Hairtrigger is offline   Reply With Quote
Old 07-31-2006, 03:15 PM   #6
tkerrigan
I installed the kit and put in 42 gallons the first fill.
__________________
2004.5 Laramie 3500 6Sp srw 4Wd Lbed Qcab.
tkerrigan is offline   Reply With Quote
Old 07-31-2006, 03:22 PM   #7
Mcmopar
Mcmopar's Avatar
Does it work on the second gen trucks or just the third? Does any one have pictures or the directions?
__________________
1998 QC 4X4 SB 3.54-Antispin 12 Valve. Timed to 16.90*. Dynoed 11/05 - 310/675 Dynoed again 02/07 - 436/957 retimed to 19.5*, and some other pump stuff!! 1/4 mile time of 12.88@104. 11/2007--480/1000.
Trustee, NC DTR#18
"That's Mr. McMosley to you!!"
Mcmopar is offline   Reply With Quote
Old 07-31-2006, 04:02 PM   #8
tkerrigan
If you go underneath and look up and there is a raised area at the rear of the tank, and the vent hose is mounted on the lower part you can move the vent hose to the top of the raised area and pick up that much fuel. It was over 5 gallons on my 04.5.
Old 07-31-2006, 04:04 PM   #9
Mcmopar
Mcmopar's Avatar
Has anyone done this to the second gen trucks?
Old 07-31-2006, 09:45 PM   #10
ColoDodge
Thumbs up Responses
Thanks to everyone for the responses on this issue, especially for the link to innertrucks.com for the part. Hopefully this will be the end of this. Thanks again everyone!!
Old 07-31-2006, 10:37 PM   #11
Patriot2500
Patriot2500's Avatar
I just ordered mine from innertrucks.com as well. How many miles are you guys with the 3rd Gen long beds getting now since the mod?
__________________
Tom
04.5 2500 QC/LB - too much stuff to list
Patriot2500 is offline   Reply With Quote
Old 07-31-2006, 10:43 PM   #12
4x4not
4x4not's Avatar
Well I've got a short bed but I can fit ~38 gallons in mine when almost completely empty (right after I installed the kit). I can get over 600 miles on a tank if I let it get to below E and the Low Fuel light comes on, but I don't usually let it get that low. I normally fill up at ~400 miles and I put in 23 - 25 gallons.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
