Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > General Diesel Discussion > Cummins Conversions
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 07-25-2009, 05:14 PM   #1
GPSflyer
F-350 Cummins
Well, I figured I should post some pics of my F350 up here in the conversion section. This truck rolled thru a local auction last week, and I had to have it!
Its got a 2005 5.9 Cummins CR engine hooked to the Ford 6 speed.
The truck has 120K on it, the engine has less than 5k miles on it. All of the factory gauges work as they should including the tach, and its got diprocol piller guages for EGT, boost, and fuel PSI. The OBDII port under the dash even works correctly, it shows the truck to be a 2005 dodge when you plug a scantool into it. It has a FordCummins.com adapter and motor mounts.
It runs and drives awesome, now I just need to strip all of the crap off of the body, like the chrome, and sidesteps, then put some Cummins badges on it!
__________________
2001 QC Dually 4x4 Auto - 19.5"s, Blue Chip FMS & Juice/Attitude, J-hook, 4" Exhaust, Holley Blue, S&B CAI, Built 47re w/ billet converter
2001 F350 - Cummins conversion, 2005 CR Cummins, ZF6 6 speed
GPSflyer is offline   Reply With Quote
Old 07-25-2009, 05:19 PM   #2
STate
STate's Avatar
AWESOME! JUST AWESOME!!!!! I want one!
__________________
'98 2500 12V CC LB 4X4
Laramie SLT, NV4500, 3.54s, LS Dif, Black/silver
KDP killed, AFE CAI, Bridgestone AT 285/75/16 E
Luverne steps, Leer Browning ed. shell, Defiant Steering Box Support, Luk Pro Gold Clutch, PacBrake
http://www.dieseltruckresource.com/p...m/98_12v_3.JPG
SOLD '04.5 2500 QC SB 4X4
STate is online now   Reply With Quote
Old 08-17-2009, 07:57 AM   #3
Exekiel69
Exekiel69's Avatar
Very nice, how does a truck like this one end at an auction? No disrespect but can I ask how much it went for?
__________________
1993 f350 CC getrag 5spd 4x2 drw 89 CTD conversion, IC, 3200 spring, 5" Stacks.
Exekiel69 is offline   Reply With Quote
Old 08-17-2009, 12:36 PM   #4
BRUISER
BRUISER's Avatar
Send a message via AIM to BRUISER Send a message via Yahoo to BRUISER
Quote:
that was the exact thing I was thinking...
__________________
Ken C
'85 W350 CC - 5 Speed..
Parts replaced so far: Engine, Tranny..oh heck the entire drivetrain...
My Build Thread
166H.P./435 TQ. Durham 2/07
191H.P./448 TQ. Durham 11/07
"Truck of the Month" Oct 2008
BRUISER is offline   Reply With Quote
Old 08-20-2009, 05:12 PM   #5
Dieseljunkie
Dieseljunkie's Avatar
Send a message via AIM to Dieseljunkie
Thats slick, and it sounds like the conversion was done right!
Scott
__________________
2004.5 2500 Quad Cab Molten red with silver lower stripe, long bed, 4x4,315/70/17 Firestone Destination A/T's, Mopar under the rail bedliner, rubber bed mat,Updated in tank lift pump after my first kill. Isspro boost,EGT, and Fuel pressure gauges, Muffler MIA, Silencer Ring MIA,AMSOILthroughout, including a EA Drop in air filter.
Kills: 1 LP 08/04/05. 22,467 Miles, Center Carrier Bearing in rear driveshaft 02/24/10. 62,480
Dieseljunkie is offline   Reply With Quote
Old 08-24-2009, 03:59 PM   #6
GPSflyer
Supposedly the owner lost his business, and all of his vehicles were being auctioned. The other serious bidder on the truck was the mechanic that built it. It sold for far less than a stock 7.3 stroke F350 would have sold for.
This week I had a buddy who works at chrysler hook a DRB scantool up to the truck, and let me check it out. It was pretty interesting, it gave me a vin #, and a mileage of 8,900 miles on the engine. We carfaxed the VIN number of the engine, and it shows it was a 2005 dodge ram sold new out of texas, and totaled 5 months later. So that explains where the engine came from.
I just drove from Colorado Springs, to Detroit and back over the last week. I averaged 17.5 MPG. Thats a little less than I was hoping for, but its a 4.10 equipped truck. Im going to look into some taller tires for it, to try and get the RPM's down a bit.
Old 08-24-2009, 04:34 PM   #7
haloman
haloman's Avatar
That is awesome!
__________________
Daniel
My Trucks-
01.5 2500 CTD 2wd 6spd QC/SB Green SLT Loud Audio, Low Fuel Press. Light, 6k Flashtech HIDS
91.5' CTD Sold
Dads Trucks-
93' W350 Reg Cab DRW 4x4 CTD 5spd flatbed 4" stack
04' 3500 Reg Cab DRW 4x4 CTD 6spd
87' D150 318 Auto
KYDTR#41 Chapter President
Contact me on how to join
KYDTR #41 Forum So. Ill and In. Welcome Click Here
haloman is offline   Reply With Quote
Old 09-16-2009, 02:47 PM   #8
GPSflyer
Well, I finally got some work done to the truck. I spent a whole day finishing up the wiring, and fixing alot of wiring that was semi sketchy. I figured out the wiring for the intake grid heaters, now they work just like they're supposed to, they even use the factory glowplug light on the dash! I installed my Racor bypass oil filter on on the inner fenderwell, Im kinda weird about clean oil. I also put an aluminum expansion tank in, as the truck still had that big goofy plastic one that sits over the radiator/shroud on the powerstrokes. Since the fan on the cummins sits up higher, there was no way to correctly mount the plastic expansion tank, so it had to go away. The truck didn't have a windshield washer tank for some reason, I think they just forgot to put it back, so I got a universal one and tucked it down on the inner fender. At this point, the only things that don't work, are the A/C, which is just getting lines made, and cruise. Scott at destroked.com is working on a solution to that problem, so I'll wait until he figures it out. In the long run, if the only thing on the truck that doesn't function like factory is cruise, I can live with that.
I also installed a Bully Dog PMT. I was going to go with a smarty, but the PMT has a great gauge setup, and is adjustable on the fly. So far Im really impressed with it, I can roll onto the throttle in 3rd, at a 20mph roll, and it will blow the tires off. (2 of them, no limited slip...)
This being my first commonrail, im pretty impressed with the power, and how quiet it is. Man, my 01 24v will wake the dead!
Anyway, heres some crappy pics I took with my cell, one of these days I'll find my camera and take some better ones.
Old 09-16-2009, 03:34 PM   #9
dieselfreak21
dieselfreak21's Avatar
If you could find a way to put FORD in place of the dodge you could really have some fun with people and tell them they just have to special order at the dealer!!!. Good lookin ride.
__________________
2003 2500 SLT Quad Cab 4X4 Long Box SO 5 SPEED
Grand Rock Stack Kit w/ 6" miters, AFE Magnum Force w/ Torque Tub, TST PowermaxCR, GDP 392, SBC DD 3600#, Upgraded input shaft, Ride Rite Air Bags, B&W TOB, B&W Companion 5th Wheel. II rebuilt injectors with 60 HP tips.
Recent Additions:
99 2500 4x4 SLT Extended Cab, long box, 5 speed, K&N, Muffler MIA, 321k and counting
96 Freightliner M11 Cummins, 310hp, and Eaton 10 Speed, Single Axle, Cab Over.
32' Cardinal 5th wheel.
dieselfreak21 is offline   Reply With Quote
Old 09-16-2009, 04:37 PM   #10
PapeCAT
PapeCAT's Avatar
Send a message via AIM to PapeCAT Send a message via Yahoo to PapeCAT
YEah, can you remove that plastic cover? I think it only covers the front 2/3 area of the valve cover anyway.
__________________
1989 D250 GETRAG/3.07
1972 W200 Crew Cab Adventurer Cummins/HE351CW Non IC/Getrag/Brownie D60F/D70 4:10 on 37" HMMWV tires
1993 W250 Power Ram LE Getrag/3.54
PapeCAT is online now   Reply With Quote
Old 09-16-2009, 05:42 PM   #11
GPSflyer
Quote:
Yeah, I had it off when I installed the oil return for the bypass, but it looks kinda weird with it off. Theres big tall bosses for the plastic cover bolts, and theres a crankcase breather under there too.
One of these days when cash permits, I'd like to get one of these...
Old 10-17-2009, 05:04 PM   #12
TxDiesel007
TxDiesel007's Avatar
Send a message via MSN to TxDiesel007 Send a message via Yahoo to TxDiesel007
nice.. just plain nice
id trade the 3500 in my sig for that rig.... that is an awesome find.. congrats
__________________
05 2500 QCSB 4X4
05 3500 QCLB 4x4
TxDiesel007 is offline   Reply With Quote
Old 10-17-2009, 06:45 PM   #13
rich
rich's Avatar
nice truck just not to crazy on where they located the air filter
__________________
SIX IN A ROW BUILT TO TOW,CUZ WELL WE ALL KNOW , HAVING A V-8 AIN'T THAT GREAT Dodge trucks that havent made life expectancy
96 3500,-175k 98.5 3500 -164k ,98.5 3500-275k, 01 3500-140k, 03 3500 -155k, 07 3500-68k waiting for possible P-Pump conversion and now I'm killing the 06,3500-116k as of 10-01-09 and counting and yes i make my trucks earn a living buy towing professionally
rich is offline   Reply With Quote
Old 10-25-2009, 03:34 AM   #14
GPSflyer
Quote:
Yeah, it makes it tough to fill my new windshield washer tank too. I'm going to try and make another setup that fits better, and has a spash shield around it.
Well Ive been driving the heck out of this thing the last few weeks, so far so good. We had a few days last week where it really got cold here. I got to test out the grid heaters, and they work perfect. They even dim the headlights on and off like a dodge!
I did have a little scare the other day at a stoplight, I had the truck in gear, with the clutch pushed in, and the clutch master cylinder broke, and the truck tried to attack the little car in front of me.... luckily I had my other foot on the brake. I did some research on the ford forums, and I guess the superduty clutch hydraulics are a known weak point. So I ended up changing it all, the master, slave, and all of the lines.
I put Cummins stickers on the back window, and fenders, and Ive been stopped about a dozen times now. Either by people who know about conversions, or people who think Im an idiot because I don't know fords came with powerstrokes...
When comparing this truck to my '01 Dodge 3500, I have to say it rides smoother, but doesn't handle nearly as well. The interior is a little more comfortable for me, as Im really tall. Its still a little hard to get used to it, since Ive been driving second-gen dodges for a long time. I did notice the small back doors on the cab make a little more noise than my dodge. Im probably going to try and adjust the latches a little to see if I can tighten them up.
Overall its a pretty cool truck, and if nothing else, its a good conversation piece!
Old 10-25-2009, 05:36 PM   #15
rich
rich's Avatar
any time they try to tell you that ford came with a powerstroke tell that yours came with the cummins when ford owned cummins that ought to really mess with their mind
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
