Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 02-26-2005, 09:18 AM   #1
Hrstrader
Hrstrader's Avatar
Exhaust brake
What do you all think about these? D-Celerator®, Diesel Exhaust Brake
__________________
04 QC Drw. Edge and power pup stacker, MIA muffler and silencer ring. Outlook monitor.
Will buy horses or cows.
Hrstrader is offline   Reply With Quote
Old 02-26-2005, 10:55 AM   #2
RCW
They are OK, just be sure to read the procedure on decarboning and lubricating the valve on that particular unit. Unlike the better (and more expensive) units that mount to the turbo outlet, these clamp down in the tailpipe just ahead of the cat. That makes them run cooler which tends to carbon the butterfly bushings and then they stick the valve.
If you can swing the cost difference, look to www.bd-power.com for their unit that replaces the elbow from the turbo. It will be much more trouble free.
__________________
Cruising the byways of middle age on a HD VRSCSE Screamin' Eagle.
RCW is offline   Reply With Quote
Old 02-26-2005, 10:58 AM   #3
RankRam
Checkout PacBrake!
__________________
06 3500 SRW 48RE Mega Cab Laramie 35/12.5/17 Toyo M/T's, Scotty 5. Cool Blue Hose, Pac-Brake, A.R.E. Z Series Shell, DP Optix gauges, Edge Juice WAM. (KORE! Thanks Dirt Eater!)
Sold 05 3500 CTD 600 4X4 LWB Q/C NV5600, A.R.E. Z Series Shell, Pac-Brake, Z Series Shell And Hot/Juice/Attitude.
Goodbye 48RE 03 CTD!
99 CTD with E-Brake
RankRam is offline   Reply With Quote
Old 02-26-2005, 11:18 AM   #4
mattymac
Quote:
Originally posted by RankRam
Checkout PacBrake!
Ill second that!
__________________
04.5 325/600, 4dsb, 4x4, larimie, Silver, 6spd, 4.10LSD, TST PMCR/Edge EZ, II SPS 66, magnaflow exh, K&N FIPK, SBC con fe, autometer ultra lites, EGT/boost/fuel pressure/trans temp, Pacbrake,Fastcoolers, Fuel tank vent kit. SMARTY In the mail!
mattymac is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
