etc light problem
Old May 16, 2012 | 02:58 PM
blowingcole's Avatar
etc light problem
hey everone i have a 2007 6.7 2500. staright exhaust dpf egr delete i put this stuff on to get rid of some miner problems i was having but before i put this stuff on i was having the etc light coming on randomly loosing throttle response no matter where i had the peadal it would excel really slowly then just all of a sudden back to a idle but really hard like there was alot of torque involved then it mite clear up or it mite not if not turn truck off then back on and the light goes away mite happen three mile down road or a week later. i think its a eletric problem dodge keeps changing my gas pedal the have no clue. no programer because i have a friend that wont void my warranty he works at the dealer ship. do yall think the programmer will solve this issue?
Old May 16, 2012 | 03:01 PM
also im thinking of getting a programmer i like the xrt from h&s. I dont wanna spend over 800 bucks tho the wife will kill me what yall think about the programmers out there.
Old May 16, 2012 | 04:00 PM
jhenson's Avatar
Maybe the admins will move this thread to the 4th gen section where there are numerous folks who might be able to help you. You might also try to re-post in the 4th gen section as well.
Old May 17, 2012 | 05:47 AM
Blake Clark's Avatar
Well, my bet would be that the slider nozzle on the turbo is junked up and the variable part of the turbo is not so variable any more. My lil brothers truck used to do something similar.
If you have a buddy at the dealer, Id get him to look into it if you still are under warranty. He may be able to get you some help. Is it Acadiana Dodge? I know a person or two over there.
A better assessment I could make by seeing what it actually does in person.
How many miles you got on that truck?
oh, and, Welcome to the DTR!
Old May 17, 2012 | 01:54 PM
92 my warranty just went out. i brought it yesterday. is that turbo slider hard to change and yeah u could see it in person the only thing is it dosent do it every time. wierd !
Old May 17, 2012 | 09:48 PM
Well the slider nozzle is integral to the turbo, so short of rebuilding the turbo is the only way to change it. But, changing it is probably not needed. It is just sooted up and not functioning properly. If that is indeed the problem.
Hard to say.
Re-reading your post it could be a number of things. Any other symtoms. Rough idle? Missing? Anything like that? Or does it just seem that its bogged down, then when it wants to go, it just goes.
Old May 18, 2012 | 08:29 AM
etc
no runs great when etc light is not on no idle problems runs fine. im buying the xrt today should be here monday or tuesday. i wonder what they charge to clean turbo ?
Old May 23, 2012 | 09:48 AM
Beast2B's Avatar
am i missing something? is the truck deleted with no programmer? sims? how about having the actual codes or code history read to see what specific trouble is causing the ETC light?
Old May 31, 2012 | 06:43 AM
The code you sent me was P2121 - Accelerator Pedal Position Sensor 1 Performance
I didnt think that the newer trucks had a APPS, just a Throttle Position Sensor.
Maybe someone who is familiar with it can chime in.
Im gonna move this over to the 3rd gen section too.
Old Jun 1, 2012 | 10:10 AM
Ok, found that on the 6.7's the APPS is actually on the accelerator pedal.
Old Jun 1, 2012 | 10:19 AM
etc
so i guess its inside the pedal the prgrammer is letting me delete it but it still coming back after a little while i wonder if they make a after market pedal. u in town this week ?
Old Jun 1, 2012 | 10:20 AM
If you look at the pedal you should see the sensor mounted on the side of it.
Wont be home til Sat afternoon.
Old Mar 1, 2013 | 03:11 PM
DodgeWorks's Avatar
Has anyone figured this out yet 'cause the wife's 07 does same thing. Have replaced the throttle pedal to no avail also made **** sure no air leaks around sensors on AFE CAI.
blowingcole
Mar 13, 2013 08:49 AM
wsuskier
Jun 24, 2011 08:45 AM
Dodge_6.7
May 28, 2011 01:22 AM
99gt
Mar 24, 2010 09:13 PM
big jimmy
Jul 17, 2006 11:54 PM
