Engine torque specs?
Old 02-19-2010, 10:17 PM
dstad's Avatar
Can some body please tell me what the torque specs are for the engine. Ect: Harmonic ballancer, bellhousing, converter, adapter plate.
I kinda need these tonight. Any help is greatly appricated
__________________
Old 02-20-2010, 12:06 AM
Pod Boy (on hiatus)
SOOT4BRAINS's Avatar
Air fuel control banjo screw (in pump)............................9 ft lbs
Air fuel control fitting ( in head)....................................6 ft lbs
Alternator ground cable mounting to block.....................18 ft lbs
Alternator mounting to water pump inlet........................30 ft lbs
Alternator pulley............................................ ...........60 ft lbs
Alternator support (upper)..........................................1 8 ft lbs
Battery cable ( negative) mounting to block...................57 ft lbs
Belt tensioner mounting.......................................... ...32 ft lbs
Block heater mounting.......................................... .....9ft lbs
Cab heater hose clamp............................................. .35 in lbs
Cab heater tubing clamp mounting...............................18 ft lbs
Camshaft thrust plate............................................. ..18 ft lbs
Clutch cover mounting to flywheel..............................17 ft lbs
Connecting rod (alternately tighten in 3 steps)
Step 1................................................. .............26 ft lbs
Step 2................................................. .............51 ft lbs
Step 3................................................. .............73 ft lbs
Cooling fan mounting to fan clutch.............................15 ft lbs
Crossover clamp (air)............................................. ...44 in lbs
Cylinder head mounting bolts
1. All bolts............................................. ...........66 ft lbs
2. long bolts............................................. ........89 ft lbs
3. tighten all bolts............................................. additional 90 degrees
Exhaust manifold.......................................... ..........32 ft lbs
Exhaust outlet pipe-v band clamp..............................72 in lbs
Exhaust pipe clamp mounting....................................20 ft lbs
Exhaust pipe steady rest mounting to trans.................50 ft lbs
Fan clutch mounting / fan hub (left hand threads)........42 ft lbs
Fan hub bracket mounting.......................................18 ft lbs
Fan hub bearing retaining cap screw..........................57 ft lbs
Fan pulley to fan hub..............................................7 ft lbs
Fan pulley crankshaft........................................ ......7 ft lbs
Fan shroud mounting nuts.......................................95 inch lbs
Flywheel bolts............................................. .........101 ft lbs
Flywheel housing adapter........................................44 ft lbs
Front engine mount isolator mounting to mount...........80 ft lbs
Front engine mount through bolt..............................30 ft lbs
Front engine mount to block....................................44 ft lbs
Front oil filler pipe-access cover..............................hand tighten
Fuel banjo screw (in fuel pump)...............................24 ft lbs
Fuel banjo screw (in head).....................................18 ft lbs
Fuel banjo screw (in injector)..................................6 ft lbs
Fuel filter............................................ ................half turn after contact
Fuel heater assembly mounting...............................24 ft lbs
Fuel heater ground mounting to intake manifold..........9 ft lbs
Fuel link fitting (high pressure)................................18 ft lbs
Fuel low pressure supple........................................18 ft lbs
Fuel pump drive gear (with pump unlocked)...............48 ft lbs
Fuel pump lock (bosch).........................................22 ft lbs
Fuel pump mounting mount....................................18 ft lbs
Fuel pump solenoid.......................................... .....32 ft lbs
Fuel pump support bracket....................................18 ft lbs
Fuel pump unlock (bosch).....................................10 ft lbs
Fuel vent screw (in banjo).....................................6 ft lbs
Gear cover............................................. ............18 ft lbs
Gear housing - to - block......................................18 ft lbs
Injector retaining nuts.........................................44 ft lbs
Intake manifold cover..........................................18 ft lbs
Intercooler attaching bolts...................................17 in lbs
Intercooler duct clamp nuts..................................72 in lbs
Lift pump mounting.......................................... ...18 ft lbs
Lifting bracket (rear)...........................................5 7 ft lbs
Main bearing cap bolts
Step 1................................................. ........45 ft lbs
Step 2................................................. ........88 ft lbs
Step 3................................................. ........129 ft lbs
Oil cooler assembly.......................................... ...18 ft lbs
Oil fill tube bracket........................................... ..32 ft lbs
Oil filter............................................ ................3/4 turn after contact
Oil pan drain plug.............................................. .60 ft lbs
Oil pan mounting.......................................... ......18 ft lbs
Oil pressure regulating plug..................................60 ft lbs
Oil pressure sender / switch................................12 ft lbs
Oil pump mounting.......................................... ...18 ft lbs
Oil suction tube (flange).....................................18 ft lbs
Oil suction tube brace........................................18 ft lbs
Power steering pump to vacuum pump mounting......18 ft lbs
Radiator hose clamp - upper................................35 in lbs
Radiator mounting nuts.......................................95 in lbs
Rear seal mounting.......................................... ...7 ft lbs
Refrigerant compressor lines - flange mounting.......15 ft lbs
Refrigerant compressor mounting.........................35 ft lbs
Rocker lever nut............................................... 18 ft lbs
Rocker support........................................... ......18 ft lbs
Starter mounting.......................................... .....32 ft lbs
Starter battery (positive) cable nut......................16 ft lbs
Starter solenoid nut...........................................44 in lbs
Tappet cover / fuel drain line supports..................18 ft lbs
Thermistor........................................ ...............18 ft lbs
Thermostat housing........................................... 18 ft lbs
Throttle bracket mounting to mounting bracket.......18 ft lbs
Throttle rod mounting to throttle lever nut.............7.5 ft lbs
Timing pin flange mounting...................................44 in lbs
Torque converter access cover plate mounting.......35 in lbs
Transfer case linkage bracket mounting / trans.......30 ft lbs
Transfer case mounting to transmission.................35 ft lbs
Trans cooler tubing mounting to oil pan flange........18 ft lbs
Trans kickdown cable bracket mounting / trans.......50 ft lbs
Trans mount mounting to trans (manual)...............50 ft lbs
Trans mount through bolt mounting (manual)..........50 ft lbs
Transmission mounting to engine..........................30 ft lbs
Transmission oil cooler line connection..................40 ft lbs
Transmission oil cooler line flange.........................50 in lbs
Transmission oil to air cooler hose clamps...............18 in lbs
Transmission to clutch housing mounting...............35 ft lbs
Transmission torque converter mounting................35 ft lbs
Turbine housing........................................... ......8 ft lbs
Turbo compressor housing clamp..........................75 in lbs
Turbo mounting nut...........................................24 ft lbs
Turbo oil drain tube...........................................18 ft lbs
Turbo oil supply (both ends)...............................11 ft lbs
Vacuum pump mounting.....................................7 ft lbs
Vacuum pump to gear housing mounting................57 ft lbs
valve cover............................................. .........18 ft lbs
Vibration damper mounting..................................92 ft lbs
Water hose clamps............................................ 35 in lbs
Water inlet connection.......................................3 2 ft lbs
Water pump mounting........................................18 ft lbs
Water temperature sensor..................................37 ft lbs
Let me know if I missed something else you need.... Not sure what else you need but that's the entire engine section. I think my ( . ) key is getting worn out though.....
Aaron
Old 02-20-2010, 12:12 AM
dstad's Avatar
Sir u deserve a klondike bar lol Thank u verry much.
Old 02-20-2010, 12:17 AM
JustRamIt91's Avatar
subscribed :-)
Old 02-20-2010, 12:25 AM
Pod Boy (on hiatus)
You are welcome! Now I need to go to the store and get a klondike bar it sounds really good...
Aaron
Old 02-20-2010, 12:28 AM
ebteckx's Avatar
Uhhh... SsTickYYYY
Old 02-20-2010, 01:05 AM
69cuda's Avatar
yes, definitely this would be good as a sticky.
Old 02-20-2010, 07:07 AM
KD93's Avatar
Got my vote too!!! I was thinking of asking if anyone had these spec's just yesterday, but was afraid to ask. Glad you asked for me dstad, and thanks for all the writing soot4brains!
Old 02-20-2010, 02:04 PM
I can take a hint.
Old 02-20-2010, 06:26 PM
KD93's Avatar
I can take a hint.
Thanks Dave!
Old 02-21-2010, 01:36 PM
Desert-dog357's Avatar
Fantastic ! Thank you much indeed !
And yes a sticky would very nice.
Old 02-21-2010, 08:12 PM
speed75's Avatar
Wow!!! Answers
Old 03-30-2010, 05:36 PM
KD93's Avatar
__________________
Wanna, did this ever make it to the sticky? I just went looking for it and couldn't find it. Although, it wouldn't be the first time
Old 03-30-2010, 08:30 PM
HappyCamper's Avatar
Yep he musta... look in the engine section, last entry
Old 03-30-2010, 08:35 PM
KD93's Avatar
I knew I must have missed it, but couldn't for the life of me find it. I'm too young to need glasses!
Thanks HappyCamper!
Quick Reply: Engine torque specs?
