Thread Tools | Search this Thread | Display Modes |
#1 | ||
EGT how to install
__________________
Dennis Miller 2004 standard cab auto maroon and silver Silencer ring MIA. S&B intake. Isspro gauge cluster. Smarty PoD Boost Fooler "home made boost fitting" 5" Turbo back 2" level kit 1986 Dodge 150 4x4 auto painted john deere green 1990 Dodge 250 4x4 auto cummins diesel Ill keep my freedom, my money, and my guns and you can keep the "Change". Nobama |
#2 |
Step up the bits little by little, vaccum out the shavings along the way, and youll be golden.
Many guys drop the turbo, cover it up, etc. Ive done two now on my truck without issue by just drilling and sucking out the tiny shavings. Obviously take each bit slowly, to minimize the shaving size, but I havent had any problems yet.
__________________
'07 2500 Mega 2wd/G56 Smarty, CAI w/Amsoil, 5" TBE, RER My Gig, Pioneer 6x9s/6.5s, 2-12" Kicker CVTs Drop shackles, Black 20" Hoss' w/ Toyo Proxes 305/50/20s |
#3 |
Yeah I dopped my turbo to install it, and boy that was a chore! Yeah if I were to do it again I would go stacked's way. Just use stepped bits to keep the shavings small and vaccum them and you will be fine. Good Luck.
__________________
2006, 3/4, QC, 4x4, Auto, Debadged, Issopro full piller, AFE blade runner, AFE stage 2 W/ pro guard 7, MBRP 4'' dual cat back w/ cat delete, Silencer ring no more, Leveled: Procomp 2" spacers, Procomp mud terrain 35's, 20% tint all around, Street scene euro grill, Q-zilla boost fooler, Diablo predator 1969 Roadrunner, Mopar or No Car 1980 Mastercraft 19ft Skier Stars and Stripes Edition |
#4 |
It would be that last little push as the bit breaks through that would scare me...I'd be praying to the electrolux gods at that point.
#5 | |
Quote:
Honestly, if you take your time and go slow, dont force it too much, the shavings are minimal. And even still, the shavings are still forced out by the bit turning, and the last push always sent those back out as well. Ive done it on mine, twice, and I know other friends of mine have done it the same way with no issues... |
#6 |
tape over most of the tailpipe, and just before you break through, start it. with goggles on of course. the exhaust pressure will blow the chips out.
#7 |
DTR's 'Go to Guy'
I left a little slit in the shape of an + in the tape too. Worked like a charm!
__________________
2003 2500 4x4 48RE 3.73 Gear - Silencer laying on tool box!, K&N Drop In Air filter, XzillaraiderII Beta Race and Quad Commander, Autometer Phantom oil pressure guage. Nitto 285 Dura Grapplers , Bilstien 5100 shocks, Walbro Lift Pump, Custom 2 micron Fuel Filter VW is gone! Back to driving to Dodge full time! I'll try to be nice, as long as YOU try to be smart! Support DTR by shopping the online store! DTR members get the best pricing - - 304-952-6896 Link to DTR Store |
#8 |
Thanks for the advice guys - I will be doing mine at some point in the near future.
Can anyone show a picture of the exact location where it needs to go? |
#9 | |
Quote:
![]() The one up top measures cylinders 1-3, on the bottom side, 4-6(hottest reading), since the back cylinders run hotter than the front. Id almost mount it in the collector portion like my bottom one, just so you see the hottest reading youre going to have. |
#10 |
I see in the pic where you put the probe, did I put mine in the wrong place which is farther toward the front of the truck? I thought the Commander pics showed it up there? I hope!
__________________
05 3500 CTD Laramie, auto, 4x4, longbed, SRW, tow, heated seats, nerfs, flame red, 3.73, AS, Commander |
#11 | |
Quote:
You know I ran a thermo reader on mine and they were all about 10 degrees of each other, that was at idle, may be different at WOT.
__________________
David Fritzsche 2004.5 Dodge Ram 2500 4 X 4 Quad Cab SLT 5.9 L Cummins HO Diesel 4-Speed Automatic Dynatrac ProSteer Ball Joints SpynTec No Spin Kit De-badged-If Dodge wants me to advertise, they can pay me!!!!!! 1990 Toyota Rockcrawler, too much money but way worth it!!!! Proud owner of 1978 750 Classic Triumph Motorcycle-one owner!!! 05 H-D Heritage Softail Classic Roseville, CA-Gateway to the Sierra Nevadas-RockCrawling Country "Serenity Through Sobriety" |
#12 |
I installed mine last week.
If you install the probe at the 3rd cylinder, use a magnet that will fit through the hole to remove the chips that fall inside. You can also use grease on the bit and the tap. That will hold most of the chips.
__________________
Papaduck 03 Dodge 3500 SLT, HO Cummins, 6 spd, 4x4, SRW, quad cab, short box, gauge on lift pump, oil pressure, boost, rail pressure and EGT, FASS 95 lift pump, Baldwin BF1212 fuel/water sep., Cat 1R0750 fuel filter, steering box stabilizer, 6.7L harmonic balancer 32 ft. 5er Carri-Lite Previous - 97 Dodge 2500 SLT, Cummins, Auto, 4x4, standard cab |
#13 | |
Quote:
You mean the digital infared gun? I may try that sometime to see, but under WOT I have differences in the 100* range, and idle/cruise, 50* |
#14 |
Guest
#15 |
hello,
does the probe have to be before the turbo or can it be after how much change in temerature would there be? thanks again dennis |
| Display Modes | |
