Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 12-11-2007, 03:30 AM   #1
craneop
Question Edge EZ stack with Xzillaraider?
Just stacked the Quad with my EZ. truck ran for 1 day awesome. now i get the P0237 code. i have unplugged the Quad and ran just the EZ,no codes and truck ran fine. i have also unplugged the EZ and ran just the Quad, no codes and the truck ran fine. i have had the EZ for 5months with no problems. just got this code when trying to stack together. all connections seem to be okay. any ideas? thanks.
craneop is offline   Reply With Quote
Old 12-11-2007, 05:55 AM   #2
GFB
GFB's Avatar
Make sure the MAP plugs are secure when they're stacked. Do you get excessive smoke when accelerating from a stop or during low throttle conditions while stacked and getting this code? If the truck is running ok and isn't smoking like it would if the MAP was unplugged then it's probably ok, just a gremlin. You could try cleaning the MAP and its contacts but I'm not sure if that would help.
__________________
2001.5, 4x4, NV4500, Adrenaline/Pulse, Super B, stage 5 jammers, walbro, 4" to 5" miters, 2" Skyjacker, 315 BFGs, valair 13" OFe, tunes by Alpine and JL.
GFB is offline   Reply With Quote
Old 12-13-2007, 05:36 PM   #3
RedRaiders
RedRaiders's Avatar
I have the same stack and mine throws a P0236 and P0237? my truck tends to miss sometimes as well?
RedRaiders is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
