Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > General Diesel Discussion
Register FAQ DTR Store Members List Mark Forums Read
Closed Thread
Thread Tools Display Modes
Old 01-17-2007, 09:34 AM   #121
HOV
Quote:
Originally Posted by XLR8R View Post
No, you're right: generally speaking, engine compartment ambient temperatures are high enough to cause/aggravate issues like this, but the Rams (3rd gen especially) have an advantage due to the large amount of free space underhood and the ability to direct fresh air in around the radiator, CAC, AC condenser, PS cooler, etc.
My Super BHAF draws air from just under the hood (unless the cowl induction hat is installed), and the differential stays well under 25*F unless I'm on the dyno.
Of course, the Cummins is the King of Cooling...
Good deal. That was one of the things I messed my pants over when I first lifted the hood on my CTD. I was used to the crampy, knuckle-busting, can't-identify-anything engine compartment of the Duramax; when the hood came up and I saw the heavy duty simplicity of the CTD, I knew it was a superior product. Everything was big, easily identifiable, spacious, and obviously industrial-strength.
__________________
2006 Ram 3500/SLT/Megacab/4x4/Auto
DTT 48RE built by Tim Barber
DTT billet flexplate
DTT shift enhanser
Jacobs exhaust brake
Smarty JR
Recon XZT gauges
Geno's muffler delete
AFE Super Stock Pro Dry air filter
Dodgezilla Torque Tube
SAC #160
PO3G #1
HOV is offline
Old 01-17-2007, 10:04 AM   #122
4x4dually
4x4dually's Avatar
Great Video. "Why can't I do what he is doing?" DUH! You have a CHEVY! And get out of the fast lane...you stupid MORON! And let's push our truck to the "over-temp" limit and then just keep it mashed for miles and miles and see if we can't REALLY BLOW SOMETHING UP! I applaud his effort to log his data and make a substantial case to Chevy, but my Gosh. And another thing, I'll be willing to bet that that Big Tex trailer and U-Haul truck weigh more than the other travel trailer and Jeep put together...not that it matters...but I'm sure it does. The Jeep and U-Haul are a wash and that flatbed should weigh more that that camper full of plastic and bed matresses.
Dude, sell that POS Chevy and spend $10,000 on an old DODGE!
4x4dually is offline
Old 01-17-2007, 11:01 AM   #123
duratothemax
Quote:
Originally Posted by HOV View Post
Three reasons I can think of:
1. EGR system returning hot exhaust gasses right back into the intake without cooling it down first
2. Stock air box takes hot air from the engine compartment instead of from an ambient source
3. Poorly designed stack/grill, and radiator not big enough
those dont have anything to do with it, people have run blocker plates, cold airintakes, and stack sealing mods...sort of helped on mild overheaters, didnt help the bad overheaters.
ben
duratothemax is offline
Old 01-17-2007, 11:55 AM   #124
Loco.Breath
Quote:
Originally Posted by hoot View Post
Fine, take the Dodge out of the video and strike all of the Dodge comments the guy made in the video from the record.
What are you left with?
The facts are there whether you believe this particular video or not. No one is denying that there are a batch of overheaters out there. This guy had another engine installed and it still did it. Do you think GM would install another bad engine on purpose? Wouldn't it possibly have been from a different batch? If the heads had casting issues than why doesn't every single LLY overheat?
My guess is yes, something is wrong either in the design or a bad component that puts the truck on the threshold of overheating. Some do because they do things that take it past the threshold. I feel bad for anyone that gets one of those trucks and actually uses it in extreme conditions.
Maybe it's all of GM cushy gadgets and attention to comfort that diverted their attention from the real reason for a diesel.
Like I said, I agree the D-Max should not have been overheating, if stock, and if it did not have any mechanical issues. I'm sure the old Dodge would have pulled that same load right on up the hill without overheating. What I am saying is the whole thing looks staged to me. If I were GM warranty and saw this tape I would ask for weight tickets on the U-Haul truck and trailer. I bet it exceeded the factory tow rating on that truck by a couple of thousand pounds. Just because the Dodge/Cummins combo will go way beyond the factory tow rating day after day without a problem, don't get mad and whine if your truck, whatever brand it is, won't do more than the factory designed it to do. Why do you think most Hotshoter's run Dodge trucks, and we all know they never exceed the factory tow rating.
Correct me if I am wrong, but even the new big bad LBZ, D-Maxes are having overheating issues when pushed past the factory tow ratings. A tow rating which by the way is the lowest of the big 3 automakers.
__________________
2006, Mega Cab 3500 dually, SLT, White, Auto, Bully Dog Triple Dog vs. 2.3.0, Cool Hose Intake, Silencer ring gone, Muffler Delete Pipe
DTR Megacab club member
Loco.Breath is offline
Old 01-17-2007, 12:24 PM   #125
HOV
Quote:
ben
All of those are elements that add t the risk of overheating.
The biggest one was obviously the undersized radiator and poor stack/grill design. That's why RadMod v2 works.
HOV is offline
Old 01-17-2007, 12:36 PM   #126
anni2VADER
ive asked this question on another thread and didnt get a anwser, and i didnt check this thread if anybody asked, but how many gallons of coolant does the DMAX hold?
__________________
05 3500 QC 4X4 LB,4.10s,auto,285 mtrs, ROKKTECH,AIRBOX MOD,AIRRAID DROPIN, ISSPROs,fifthwheel dragger.
anni2VADER is offline
Old 01-17-2007, 01:33 PM   #127
XLR8R
XLR8R's Avatar
I thought duratothemax or somebody posted 6 gallons?
__________________
"Miss Sled" Silver 2005 5500 Quad SLT G56 4WD LB... too many mods to list - designed, built, installed at shop.
"Cheap Hooker" Chestnut Pearl 1998 2500 Quad SLT 49RE 4WD LB twin turbo... same as above
"XLR8R" RED 1965 GTO Ram Air 400, M-21, 3:90 Posi, Tripower, Nitrous... ditto
Gun-Happy
XLR8R is offline
Old 01-17-2007, 04:36 PM   #128
JyRO
Muted User
Finally made it to the end. Read all the replies. Wanted to add a few comments.
1) Neglecting the weight of the towed loads, the Cummins is towing the camper and the Jeep 4 WHEELS DOWN. That's 4 axles he's towing. In my towing experience, as the number of axles towed (or even tires to the ground) increases, the rolling resistance increases linearly. And the rolling resistance is substantial. It looks like the GN trailer has dual wheel assemblies so the rolling resistance may be a wash between the two.
2) I give this guy some respect for doing something about his problem.
3) I also give this guy the benefit of the doubt about riding the left lane. I think he pulled out there in an attempt to run up beside the Dodge so the camera could confirm what kind of truck it was. And he remained in the left lane so we could better judge the distance to the Dodge, and in hopes that he may gain on him later and pass the Dodge. Also, if the speed limit is 80 mph, the traffic must have been very light because I don't remember him getting passed much.
4) The camper had to be at least 8,500 lbs, probably more. The Jeep, what, uh maybe 3,500 lbs. That's 12k towing ... that's a good load in my opinion. The Chevy towing maybe a 5,000 lb trailer with a 6,500 lbs Uhaul? Just guessing. That's like 11,500. To me, those 2 weights are close enough to be called equal.
5) I think the guy kept rugging the DMax to prove his point (that he was overheating and having a hard time staying up with "an ole Dodge"), and because he evidently knew the ECU would protect the engine.
Even for that test, I don't think I would have had the cojones to keep my foot in it. I would've been considering the melting point of aluminum as compared to steel.
But kudos to him and I'm glad he won his case. I'm glad he didn't run up against me during his test, because I run 65 mph when towing, because I'm cheap and try to get 13 mpg or better. Of course I would've have gained or passed him back on some of them grades, cause I run 65 up the hills too.
- JyRO
JyRO is offline
Old 01-17-2007, 04:56 PM   #129
duratothemax
Quote:
no. the LBZ does not overheat and neither does the LB7.
tow rating is not a simple measure of "power". tow rating is a combination of weight distribution, axle ratings, spring rates, tires, wheels, hitch size (the factory dmax bumper hitch sucks), etc.
Old 01-17-2007, 09:56 PM   #130
Loco.Breath
No the LB7 just has 8 bad injectors that cost $200.00+ each that GM says they will replace under warranty. That is until you actually take them a truck that has bad injectors. Our 2003, C2500 D-Max shop truck has been in the shop for the last month with the dealer trying to change everything but the injectors trying to clear up fuel smoke at idle.
As for the tow rating, I deal with things everyday that tow over a million pounds, and I know what all goes into calculating tow ratings. I just find it amusing that the most powerful STOCK new pickup you can buy right now has the lowest towing capacity. So what is the factory hitch, GM's version of a fusable link?
Old 01-17-2007, 10:08 PM   #131
duratothemax
yes, the factory hitch sucks
reese titan v makes a good replacement
Old 01-18-2007, 10:58 AM   #132
Hdmax
Why the heck would it overheat?
Maybe it is a problem from the factory, I don't know. But I am not going to stand behind that moron either. He is trying to sale cooling devices for the Duramax, maybe he placed a piece of cardboard in front of the radiator. ?
There is a lot we can't know from the video, but one thing we all should get from it, he is a moron, plain an simple!
Maybe the U-Haul is loaded, (The GCVW could be 25,000-30,000 lbs, we have no way of knowing.) maybe his tires are half flat, maybe he has weight in the bed of the pickup. After all, his sole purposes is to make the truck look as bad as possible. I do not trust him due to his motives.
__________________
Mike
http://community.webshots.com/user/hdmax2002 Chevy 2500HD duramax Diesel, Allison 5 speed automatic transmission, Crew cab, Short bed, LS trim, Forest Green, 4x4, Limited slip, boost & EGT gauges, 35" tires 2.5" lift, EFILive=500+ rwhp
http://esnips.com/web/bigluke39-MySongs
Hdmax is offline
Old 01-18-2007, 11:21 AM   #133
Raspy
Raspy's Avatar
Meanwhile, back at the Dodge. They're just riding along, enjoying a beautiful day. On vacation and being soothed by that wonderful Cummins roar. Tunes are on. Chatting. Completely oblivious to the screaming, overheated, highway hazzard thrashing away trying to "catch" them. Errrr, the "Superior Product" trying to catch them.
Wetspirit
__________________
John
Prepare to stand by!
'04 2500 4WD std cab, HO, 48RE, TC, VB, Hytec pan, Dynatrac, '08 steering linkage, track bar, '08 H2s, Toyo 285/70 E, Smarty, Walbro, gauges, Brakesmart, exhaust "out the side", intake tube, billet filter lid, Kilby guard, KYB front, Rancho 9000s rear, Timbrens, PW flares, rear blocks missing, front 1" lift, wheel well liners, debadged, splatted bugs, hood pal.
Raspy is online now
Old 01-18-2007, 11:54 AM   #134
TireHauler04
Wetspirit: You got it man..their truck hauls their 12k lbs just fine at 80mph up a 6% grade,so why care that a dead duramax is behind them lol.Seriously funny to see how people can argue about why and what went wrong with the duramax, point IS...it didn't make it that day.
TireHauler04 is offline
Old 01-18-2007, 12:22 PM   #135
Hammily
Hammily's Avatar
Duratothemax was very close with this statement.
"The cooling system IS adequate when everything is in-line and perfect as far as the emmissions components go."
Look at how little I have to change in his sentence to fix the truck!
The cooling system IS adequate when everything is in-line and perfect as far as the CYLINDERS go.
__________________
John
1996 Dodge Ram 4x4 #10 plate, 3GSK, Goerend tranny, Webasto, DiPricol Optix. DDP2's
2000 Ford Excursion 4x4, upgraded to 97 12 valve, #8 plate. Still a work in progress.
Hammily is offline
Closed Thread
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
