#31 |
My favorite part is that he starts whining about his truck being in limp mode and whining how it's not safe to drive on the highway in limp mode. DUH!!! Limp mode is designed to limp you off the highway so you can stop and see what's wrong. Not so you can stay pedal to the floor. I also love how he's clogging up the left hand lane and is just intentionally abusing his truck. Now I understand that he's upset that his really expensive truck isn't performing the way it should but that's no reason to intentionally abuse it. Jeez this guy's an idiot. Oh yeah. I love the fact that the code wasn't even involving the engine temp. Just the rail pressure.
#32 |
He rode in the left lane because that was the only way he could get a look at that dodge that way towing at highway speed
__________________
Paddle Faster I hear banjo music 2003 Dodge Ram qc 4x4 DRW sixspeed Flatbed, SMARTY, Power puck, quad Commander, AFE Pro Dry, South Bend Con FE, Raptor 100 SAC # 102 I think. . |
#33 |
I think the most fitting end to this shmucks video would be for that CDT to be heavily bombed and to puff out a huge cloud of black and pull 20 lengths real fast on him on the hill. I love doing that.
__________________
2003 3500DRW QC Laramie 4X4 NV5600 4" Superlift~Rumble Bee Scoop~FASS 150~Dr.P/Smarty Stack~SBC OFE~Performax Gauges~BD Brake~AFE II~DTT Intake~Audio Addicted __________________________________________ Sold 1998.4 12V LB/QC 2500 4X4 AT PDR Twins Helix II 913 modded pump __________________________ Sold 1998.5 24v LB/QC 2500 4X4 AT PDR Twins Comp-Hot __________________________ Wifes car 04 Jetta TDI Sport ___________________________ GAS IS FOR WASHIN PARTS |
#34 |
To me the video just illustrates that even a company with the resources of General Motors cannot expect to jump into the development and production of diesel engines and directly compete with the likes of Cummins, Detroit Diesel, and Cat that have been doing it for decades.
The experiences of the "old pros" still means something. Ryan
__________________
'05 2500 Quad Cab SB, 48re, CTD, 3.73s, 2WD. '06 Dodge Charger R/T (Wife's Ride). '85 Chevrolet Corvette, Richmond (ROD) 6Spd, QA1 Adjustable Shocks, Crossbar, Descreened, AIR Delete, Cut Lid. |
#35 |
I agree, not one of the best drivers in the world. Anyone that has been around the big trucks knows that they will derate under certain conditions to protect the engine. I think that was a good real world test however, here's one for JD Powers to stick in there pipe huh? I'm not 100% sure but I think the LLY was available up to a few years ago, or maybe when they changed to this new 360hp one or something, not sure though, not GM's number 1 fan.......or 1,000,000,000,000,000 fan.........
GO DODGE CUMMINS!!!!!
__________________
02' something 4x4 5 speed BHAF w/outerwears , American Eagle wheels, Arrowcraft dually conversion, Diablo Sport Power Puck, Dipricol, Fuel Pressure, boost, Pyro, AMSOIL 15W40 plus filter One of Uncle Sam's Misguided Children |
#36 |
late 04 to mid 05 i beleve my dad has an lly 05 dmax hasnt had a problem with it yet but with the injectors
__________________
99 ext cab short bed,4.5 inch lift, 33x14.50 super swamper ssrs on weld scorpio v 16.5x12 rims, edge drag comp wire tapped, 4 in stainless straight pipe, bd pressure loc, ats dd pan,ats full pillar, 3 disc billet hub torque converter, loc up switch, coustom built trans by Donnie French of escalon trans,hts billet shafts, htt's 62/14 turbo, mach 4's,12mm arp head studs, fass 150/150 w/pickup tube assy. black 2006 drz-400sm |
#37 |
Lead - Follow - Or get out off the WAY!!!!!!
__________________
2005 2500 Gray Laramie Quad Cab 48re 4X4 LWB 3.73 Current setup: Overhead Isspro gauges: Transmission, Pre-turbo EGT, Boost, True Flow air filter, Quadzilla Std. Box 30-60-100, Silencer ring MIA, Fuel tank vent mod. ARE topper, 70 gallon L-shaped fuel tank, Official weight 8060 LB Weight w/out fuel tank 7390 Sold: 2000 Ram Extra Cab 2500 4x4, Auto, 53 block, 176,000 miles |
#38 |
this is an instant classic, If I were this fella I would have done the following...
1) Backed off when everything started to overheat 2) Quickly stopped taping and destroyed the video to prevent future embarassment ![]() 3) Traded that duramax in for a Dodge Cummins But I am not that guy and I've skipped those first three steps and bought a Dodge Cummins! ![]()
__________________
The Lord gave me a: 1998 Dodge Ram 2500 12v 5-speed 4x4 QCSB 3.54 gears - 370 Marine Injectors, S300G Turbo, Custom Fuel Plate, 4" straight pipe, GM 1 ton wheel cylinders... sold...1997 Dodge Ram 2500 4x4 Auto CCLB / 1993 Dodge Ram W250 4x4 Auto CCLB / 2002 Dodge Ram 2500 4x4 6-Speed QCLB Founder INDTR #29 |
#39 |
I just plain feel sorry for those who bought a 50k truck that would not keep up with a 10 yr old product!!
Scary thing is that the dodge was probably running the ac with the cruise on and the 47re probably never shifted out of overdrive. I never noticed any tell tale puff of smoke as if it did. After driving the Duramax and the Ford of the same year (2005) I'm so glad that I bought a Dodge Cummins!! BTW very cool video!! No matter the reason! Rick
__________________
2005 Dodge Ram 3500 4x4 QC, SRW, SWB, 4.10's,48re, Bright White, All factory options exc pedals GPS and the phone thing. Shaved badges. Quad racebox, Quad intake, Pml Trans pan, Custom valve body, Stewart Warner guages, Aeroturbine exhaust w/5"tip, Rancho 9000 shocks,80w Hella fog lights, 80/100w Hella headlights, Stebel electric horn, 285 70-17 BFG All Terrains, Factory style mud flaps. Northern California Chapter #21 |
#40 |
gotta love them LLY's
#41 |
__________________
"99", 265K on Original VP44 Before it Died. 280K miles And Running Strong! Full Goerend Bros Tranny & 3 Disc TC Smarty, Junk FASS HVLP95, ATS 3 piece exhaust manifold, 4" Exhaust, Fuel-Boost-EGT's, Optima Red Tops, K&N, 285's on stock rims, GMC 1 ton rear brake cylinder, Remote starter, KDP checked. |
#42 |
DTR's Cow Boss
Got "nearley nail" should have had your hazzards why did he not pull the truck on? so the wind would not be blowin flat again the truck
ummmm the sound he was hear was the rev limiter ![]()
__________________
Diamond Eye 4'' Exhaust,Jake Brake,SouthBend Con OFE, FASS DDRP I want too saddle my horse in the darkness ride out in the morning dew I wanna breath some air that's never been breathed I want too drink the wine of freedom and toast the good ones we knew Relax Reflect Wild Woolly Hard Too Curry |
#43 | |
Quote:
#44 |
I thought it was funny when he burped, then answered his phone and called the dodge "crappy!"
__________________
"The Beast" 1978 V-Dub MK1 Wabbit Diesel, 4spd, Pump Tweaked, 87k Original Miles ***R.I.P 2002 CTD 4x4 Hand-shaker 374hp/915tq*** U.S. Navy Seabee Veteran We Build, We Fight, We Drink More Beer! |
#45 |
| Thread Tools | |
| Display Modes | |
