Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Sign in using an external account
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 09-18-2011, 02:09 PM   #16
jimbo486
jimbo486's Avatar
The factory clips actually aren't that bad. I broke the driver side trying to figure out just how it's supposed to hook in there. I figured it out and got it right on the passenger side but tied them both to be sure I never have to do it again.
__________________
"My name is Jim, but most people call me.... Jim"
- Blazing Saddles -
- '90 D350 "Rust Bucket Hunter" -
- Giles' 12mm VE - Airdog II 165 - XDP sump - Bradley's Diesel 5x.013s (68-70lpm) - Powerstroke I/C - Fluidampr -
HTT Super 40/35 'gated 14cm - 4" exh. - '01 NV5600 - SB Con OFE Clutch - D70 3.54 -
263HP / 610ft. lbs. (Aug. '10: prior to Giles VE, AirDog, XDP sump, 5x.012s and Powerstroke I/C)
Updated numbers: TBD
Up and Cummins
- Paint -
jimbo486 is offline   Reply With Quote
Old 09-18-2011, 07:37 PM   #17
whereswaldo250
whereswaldo250's Avatar
Jimbo, Looking bud I like what you have done thus far. I could't see too well in the pictures, but when you got new bearings from Quad4x4 did you get Timkin bearings with the kit?
__________________
BLACK 1992 Dodge Cummins Turbo Diesel-4x4-Standard Cab-9 Speed Rag+Gear Vendors-4:10 d70 limited slip w/ 11 leaf springs!!-167,000...and slowly counting. Mods to date: Rebuilt HTT Stage IV H1C/E 14cm w/g-366 spring-3/4 turn on fuel pin-star wheel bottomed-BHAF Outerwears(filter minder)-AD165 w/ sump-Isspro Pyrometer/Boost/Trans/Fuel 4" Exhaust-Trans Coolers-Buckstop Bumpers
1-24-09: 158hp 408tq (Dynojet)
whereswaldo250 is offline   Reply With Quote
Old 09-19-2011, 03:35 AM   #18
jimbo486
jimbo486's Avatar
Yep. Timken bearings, bearing races and National wheel seals.
Old 09-19-2011, 04:35 PM   #19
jimbo486
jimbo486's Avatar
Worked from about 6pm to midnight last night to get this done! There's a big difference in the dimensions between the cab and chassis axle and the pick-up axle. These are only dimensions I found in threads here but they read 55" between the backing plates of the cab and chassis axle and 60" between the backing plates of the pick-up axle. They seem to be close to that. Wow!
Click the image to open in full size.
This sure would have looked awkward if I had left the narrower axle on the '90!
Here are the clearance issues I'd run into if I hadn't done the swap. You can see the inner wheel well is directly above the shoulder of the tire. 500lbs would probably introduce them to each other.
Driver side.
Passenger side.
Old 09-19-2011, 05:37 PM   #20
TRENDZ
Yeah the inner wheel wells need alot of work to get clearance. My bed floor is 48 1/2" between the wheel houses after modification. You definetely went the right route with swapping axles.
These are great pictures for reference. Had I seen this, I most likely would not have modded mine, but I was in to deep by the time I could see this for myself.
__________________
91 D350 366, screwed, homebrewed afc, sec gen lift pump, regulator, 1/2" lines, 2nd gen intercooler, 3" tubes, electric controlled 351vgt, 4" ex, ported head and manifold, goerand converter 518, 3.07s
TRENDZ is offline   Reply With Quote
Old 09-23-2011, 06:59 PM   #21
whereswaldo250
Quote:
Sweet that is really good to know.
Old 09-23-2011, 11:14 PM   #22
tech-eh
tech-eh's Avatar
when i did my conversion it ended up at 48 1/4 from one side to the other had it originally set up at 48 1/2 and it rubbed with a load and bumpy roads just ever so slightly but enough to score the sides of the tires
tech-eh is offline   Reply With Quote
Old 09-24-2011, 01:27 PM   #23
TRENDZ
My truck has 19.5 tires/wheels. There is almost no sidewall bulge, and the wheels are closer together than factory, so I got away with a little more than I should have. Do you have pics of yours?
Old 09-25-2011, 02:14 AM   #24
Bumble76
Bumble76's Avatar
Just out of curriosity, what did you do with the "Champaign Room" I've been looking for one of those and man are they hard to come by.
__________________
91 CTD Non/ic
Tweeked pump
'84 cab
BHAF w/outerwear prefilter
Carter electric fuel pump
Bumble76 is offline   Reply With Quote
Old 09-25-2011, 09:22 AM   #25
AUGIE DOG
AUGIE DOG's Avatar
Jimbo,was the original axle narrower than the axle you put in?I just logged on here so I haven't been following this closely.If the axle was narrower could you have used it and just add fender flares to a stock bed instead of using a dually bed.I thought the chassis type model axle was narrower than a stock truck with bed etc. etc.Just wondering. My rig is a crew cab short bed that I am also installing a dually axle but it would be so much easier to use a chassis axle placing the wheel inside wheel well and just use wide rubber/fiberglass flares. Just wondering!!
__________________
1985 D-350 CREWCAB CONVERSION REVIVED WITH A 1991.5 12 V, McMOPAR BUILT 47RH. BASICALLY STOCK WITH A STRAIGHT PIPE. MODS TO COME! 1 CORINTHIANS 2:9 "No eye has seen,no ear has heard,no mind has conceived what God has prepared for those who love him"
AUGIE DOG is offline   Reply With Quote
Old 09-25-2011, 11:37 AM   #26
jimbo486
jimbo486's Avatar
Quote:
Still got it. PM me if you wanna work something out.
Quote:
Yes, the cab and chassis dually axles are narrower than the pick-up axles. If you look at the last 2 pictures I posted, you can see the clearance issue. TRENDZ did just that with his truck. He kept the narrower axle and used a SRW bed, cut the wheel wells out, added sheet metal and made his own fenders. I think it looks really good! He also had to make the wheel tubs inside the bed deeper to clear the inner tire. If you can find a pick-up dually axle, that'd definitely be the way to go!
Old 09-25-2011, 11:58 AM   #27
gadget.35-06
gadget.35-06's Avatar
Altering the wheel tubs to accomodate a chassis/cab axle will sure put the kybosh to hauling full sheets of plywood or drywall, should the need arise.
__________________
06 3500 DRW QC 2WD G56 Big Horn; bright silver w/ cab-high Skaug body, Valair DD, SuperChips 3805, K&N, Magnaflow.
Nothing Runs Like A Deere...With A RAM in Hot Pursuit!
Gone to a new owner whose dreams have yet to implode as did mine: 1991.5 D350 DRW, all stock and pushed hard for 538,000 miles.
gadget.35-06 is offline   Reply With Quote
Old 09-25-2011, 03:23 PM   #28
TRENDZ
Not so on mine. I have 50'' between the widest part of the tires. Wheel wells are 48 1/2" inside to inside.
Old 10-25-2011, 09:23 AM   #29
jimbo486
jimbo486's Avatar
I've been working out in northern Arizona for the past couple of weeks and ran into another first gen and started BS'ing with the owner. I told him what my latest project was and that I was hoping to find another bed. Turns out, he has one that he was ready to send to the scrapper. It's mine for $100!! The only damage it has is the driver side rear. I'll use a section from the front of this one to fill the space I'll have between the cab and bed.
Click the image to open in full size. Click the image to open in full size.
Old 10-28-2011, 12:52 AM   #30
gadget.35-06
You're gonna need some herding dogs to keep them head o' Rams from strayin'.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
