Thread Tools | Search this Thread | Display Modes |
#1 | ||
Dually bed project
__________________
"My name is Jim, but most people call me.... Jim" - Blazing Saddles - - '90 D350 "Rust Bucket Hunter" - - Giles' 12mm VE - Airdog II 165 - XDP sump - Bradley's Diesel 5x.013s (68-70lpm) - Powerstroke I/C - Fluidampr - HTT Super 40/35 'gated 14cm - 4" exh. - '01 NV5600 - SB Con OFE Clutch - D70 3.54 - 263HP / 610ft. lbs. (Aug. '10: prior to Giles VE, AirDog, XDP sump, 5x.012s and Powerstroke I/C) Updated numbers: TBD Up and Cummins - Paint - |
#2 |
Looking better all the time. One change I wanted to explore but could never afford the downtime was to see if 1990 Ford dually drums would fit...My nephew had a '90 F350 DRW and it had finned aluminum/steel lined drums that were outboard-mounted; it would have made brake maintenance easier if it would have worked.
__________________
06 3500 DRW QC 2WD G56 Big Horn; bright silver w/ cab-high Skaug body, Valair DD, SuperChips 3805, K&N, Magnaflow. Nothing Runs Like A Deere...With A RAM in Hot Pursuit! Gone to a new owner whose dreams have yet to implode as did mine: 1991.5 D350 DRW, all stock and pushed hard for 538,000 miles. |
#3 |
Maybe in the near future I could find a Dana 70 out of a wrecked 2nd gen and grab the hubs and drums from it. Or the entire assembly if it's cheap. That makes me wonder... Is there any chance our inboard drums could become outboard drums by means of spacing the backing plate outward using the same dimension as the hub-to-drum flange? I'm trying to find detailed pictures of both, a Dana 70 with inboard and outboard drums to compare differences.
#4 |
366 Spring Chicken
Your buying all the parts inside anyway. If you do it right you won't need to get in there for a few years.
__________________
89 W250, powerstroke i/c, 3 turns smoke screw, 1/2 turn starwheel, full power screw 4 or 5 turns, autometer phantom boost and pryo, 4 k isspro tach, 727 tranny, 3.07 gears, factory l/s rear, S300 turbo, stans exaust, wish list, T/C, sticks. 93 w250 extended cab, rag, 6X16's, GDS 60mm, full set isspro gauges. 92 W250 with NV4500, stock engine. |
#5 |
I'm gonna miss the "Champagne Room"!!
__________________
#6 |
How bout a Custom aux fuel tank / tool box combo for that space
, Looks like fun, keep us posted!!!
__________________
'92 D-350 LE dually Auto, single cab, flat bed, straight exhaust, LED gauge cluster refresh, White faced gauges, Denny 2 fuel pin, 3200 spring |
#7 |
Tore down the rear axle wheel ends on the donor truck and installed new bearings, bearing races, upgraded to double spindle nuts, seals, shoes, springs, wheel cylinders and emergency brake cables. Replaced it all while it was open; especially with in-board drums.
Driver side. ![]() ![]() ![]() Passenger side. ![]() Separated the drums from the hubs for them to be machined. ![]() ![]() New outer bearing races. ![]() ![]() New inner bearing races. ![]() Inner bearing race driver and punch/handle which came with the kit
#8 |
Continued...
![]() Inner bearings packed and wheel seal installed. ![]() ![]() Wheel seal driver. Utilizes the same punch/handle as the inner and outer race drivers in the kit. ![]() Driver side brakes (forgot to get a shot of the NEW parts installed. They look identical only shiny and new). ![]() ![]() Driver side spindle nuts installed. ![]() Passenger side brakes finished. ![]() ![]()
#9 |
Continued...
Wire-tied the new parking brake cables for extra precaution. ![]() Driver side axle bolted in. ![]() ![]() ![]() Passenger side spindle nuts installed. ![]() Passenger axle bolted in. ![]() ![]() Popped off the differential cover and performed change the fluid. No limited slip here but it will eventually get a locker: ![]() Differential cover sealed, bolted in place and filled it up with 3.5qts. of 80w-90 gear oil: ![]() Back on her own 4 feet!
#10 |
I have a question. I notice the tailgate has marker lights. Could you snap a pic of how/where the wiring is from the gate to the bed? Is there a connector somewhere so you can easily remove the tailgate?
__________________
91 D350 366, screwed, homebrewed afc, sec gen lift pump, regulator, 1/2" lines, 2nd gen intercooler, 3" tubes, electric controlled 351vgt, 4" ex, ported head and manifold, goerand converter 518, 3.07s |
#11 |
The clearance light wiring runs through the center of the left tailgate hinge. The wires are terminated with bullet style connectors to facillitate easy removal of the tailgate.
__________________
Of course it smokes, it's a diesel, Einstein!! |
#12 |
Are you supposed to pack the rear wheel bearings with grease??
I thought those bearings got lubed with gear oil from the diff?
__________________
93 w-250 under construction. Rebuilt A518, KDP killed,fuel pin rotated deep side, star wheel 1.5 turns,1 ton rear brake upgrade,LP piston lift pump,big fuel supply line,4" Diamond Eye, new body...more to come |
#13 |
According to Quad 4x4's instructions, yes.
#14 |
The bearings do get lubed with the gear oil but throwing grease in there shouldn't hurt a thing. Just insurance that your bearings are good to go.
__________________
1992 w250, 4" custom lift rear drop shackles, 2.5 sky jacker fronts, 2" custom frt drop hangers. Rear discs, dual steer stab 2nd gen intercooler. 4.10 gears, 1/8 bump 366 spring 47rh Denny II Custom BHAF Custom Duals, Gauges, Airdog 150... More to Come Soon! (Derek's old truck) |
#15 |
I see you took advantage of my drilled e-brake arms. Couldn't tell ya how many times I got tired of resetting the cable ends in those cockamamie factory clips!
| Display Modes | |
