Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Generation Ram - Non Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 02-07-2010, 10:55 PM   #1
quicksilvr
DRW to SRW
Can it be done? I don't own one, but I've been thinking about buying one b/c they are easy to find with a 6 speed. Those bed sides look like they're just stuck on over a regular bed, maybe I'm just dreaming but I figured I'd ask. I'm guessing axles are the same and it would just need different wheels.
Thanks, Eric
__________________
04.5 48RE Regular Cab
quicksilvr is offline   Reply With Quote
Old 02-08-2010, 01:33 AM   #2
quicksilvr
Well I stayed up late and read a lot, looks like it can be done. I'd love to hear from people that have done it.
I did discover there is notched section in the bed after removal of the fenders, I wonder if a Bushwacker extenda flare would cover this plus provide extended coverage for the rear wheel sticking out farther. I think if it did, I would add a spacer and flare to the front and the truck would look pretty mean. I'm thinking the only labor intensive part would be filling the holes left behind from the fenders.
Old 02-08-2010, 01:36 AM   #3
quicksilvr
Old 02-08-2010, 04:37 AM   #4
nwflyoda
nwflyoda's Avatar
Send a message via AIM to nwflyoda
the rear axle is different between the drw and srw trucks. i believe the drw axle is about 4"s wider.
__________________
05 2500 qc, sb, 4x4, g56, 3.73, mp8, afe stg 2 pg7, 4" dynomax bullet muffler to 5" turnouts, ranch hand bumper, HBS 2" leveling kit, prodigy controller, b&w goose neck, 295 HP/540 TQ feb 08 (stock)
nwflyoda is online now   Reply With Quote
Old 02-08-2010, 02:53 PM   #5
quicksilvr
The rear housing is the same, the rear has a spacer on the hub after the rotor, if you remove it one will have source SRW axle shafts. See picture above it's not that big of a difference.
Old 02-08-2010, 03:06 PM   #6
ripping r
ripping r's Avatar
if you can find some one close. that want's to make theres a dually you could swap. i would like to make mine a dually. but have not found anyone close to do swap with.
__________________
06 flame red 4 door swb qc g56 4x4 cummins
ride-rite air bags,2''leveling kit,line-x,rear mag-hytec
empty weight 7,050 pounds.
ripping r is offline   Reply With Quote
Old 02-08-2010, 10:51 PM   #7
nwflyoda
nwflyoda's Avatar
Quote:
i believe you'll also have to move the rotor from the back of the hub to the front. i believe the drw rotors have the studs pressed through them into the hubs and the srw don't.
Quote:
i'm in the same boat here. i'd like to convert mine to one as well but there isn't anyone close that wants to do the swap. so i'm just content w/ keeping mine a srw.
Old 02-09-2010, 01:36 AM   #8
quicksilvr
Well if I wind up with a DRW truck in the next few months I'll be wanting to swap. The rotors are in the same location on both setups no modification is necessary to bolt on a single, the wheel will just stick out a bit compared to the front, see photo above.
Old 02-09-2010, 05:11 AM   #9
nwflyoda
nwflyoda's Avatar
i can't view the photos. i thought that to replace/turn the rear rotors on the drw trucks you had to remove the hub to do so. i guess i may be wrong. i know the brake caliper and axle shaft and wheel bearings are different part numbers for that of a srw truck.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
