#1 |
The Admin that's here for you!
Drag tires ?
Evenin, DTR.
I need to start looking for some drag tires all the way around... what am I looking for? I don't want slicks, without being able to burn them on all 4 corners, they are pretty useless. I guess I'm looking for some street slicks, something that will grab really good, but not need a warm up. I know I spin till about the 30' mark with stock 265's at 30psi... Thanks!
__________________
Mark 04.5 3500 SRW 4X4 Smarty REVO PoD, MP8, HTT 64/71/16ss, Flux 2.5, ARP studs, ATS stage 4 with aftermarket output, Snow stage 3 water/meth, AD 150, Arson II CP3 mod. 37" BFG KM2 MT's on stock rims and ride height. 636/1266 fuel 868/1778 on a little spray David Dunbar's dyno, 7 Nov ![]() 12.46 @109 Coastal Plains, Oct 08 Many thanks to Lary Ellis and the DTR store, ATS, Don M, and Bob W... madhat@dieseltruckresource.com |
#2 |
Bump...
And... I want to either put them on stock rims or H2 Rims.... |
#3 |
Take a look at www.hoosier.com
__________________
05 2w std cab Goerends full billet silver bullet 66 ported head Dons stage 2.5 springs Overkill Header afe stage 2 Hellmans intercooler Gages DTT Int Fluidampner caltracs |
#4 |
madhat, did you end up finding a set you like yet? I have been doing a little looking myself, but have not found anything that really catches me eye.
__________________
Alex Silver 2004.5 Dodge Ram 2500 4 Door Short Box, Afe Stage 2, Silverline Muffler to custom 8" stack, Levelled with Cooper Discover ST 35x12.50R17, Quad Commander, Quad fuel/rp gauge, Smarty TnT Revo, Goerend Tranny with Billet Input and Haisleys Flex Plate, Airdog 150, Htt 62/71/13, DDP 90's 494/1036 stock fuel system, stock turbo, stock stix 588/? with current setup |
#5 |
DTR 1st Sergeant
Mickey Thompson has what you are looking for... I think...
__________________
2004 3500 QCSB Laramie SRW 4x4, CA emissions SO 235hp, 3.73 posi, Peak Performance BB Twins, engine by Diesel Nut, Almost stock DTR "Twins" Club Member #1 11.89 @ 119.2 mph 1/8 mile= 7.76@94.94 mph 900.86 rwhp/1689.76 tq @ Left Coast Diesel 21 AUG 09 TNT member #2 SAC member #9 |
#6 |
I have not...
I'm actually looking for a size recommendation with a link... |
#7 |
I'm on another site that has a Thread for discount tires direct and I'll ask what the closest he can get to 245/70/17 drag radials, or maybe something in 31-32 tall. Does that height work or can you go shorter?
Edit, I see your trap speed and you probably couldn't go lower than 31 and that's pushing it depending on your gear and rev limiter.
__________________
-Hillbilly Deluxe 2007 2500 QC SB Laramie 5.9l 4x4. Lorenz Bilstein 5100 kit, Relentless Valvebody, Thuren Track Bar and XD wheels wrapped in 35x12.50x17 Hankook M/Ts... Muffler Fell Off, otherwise stock for now. GIG'EM AGS! |
#8 |
Yeah, I think a 31 is about it. 265 is great... that's what I ran for that trap speed. I had a lot of slippage on the line, and some boost issues that kept my 60 ft time around 1.9-2.0. I was running them down like mad in the big end, tho!
#9 |
Yeah a link would be awesome. I was wanting to do the same thing you were with the h2 wheels and tires. Is that pretty much the smallest tire we can use, a 245 or 265?
#10 |
Alright I asked, 31-33 height preferably 32. When he gets back to me I'll let you know, they might not be available. I also asked to specify weight ratings on the higher side.
#11 |
Thanks!
#12 |
Yeah no prob, I'm also trying to get some tires for my Honda daily driver. Seems like he is answering questions pretty well it's like 15 pages long now.
#13 |
Awesome! Thanks!
#14 | |
Quote:
They are directional, which does, IMO, give better traction. 31" tires with 11.5" tread width and fairly soft rubber! http://www.tiresdirect.net/TOYO_Prox..._P4843C899.cfm http://toyotires.com/tire/pattern/proxes-st-ii They don't spin with a 20-22 psi launch on my 3.55 rear end. I've seen them run on a 06 with 850 hp and the proxes II only chirped a bit on the 1-2 and 2-3 shift! RJ
__________________
02, 2500, QCLB, 4x4, Auto, 3.55 Power-Lok LSD - DTT/Billet - Smarty/Pulsed Adrenaline - Mach 6's - BD Twins - Snow's H2O/Meth - FASS - F-1 Cam/Valve Springs - HTT Manifold - LazarSmith Bars - TC Lockup Switch - RAD - 3rd Gen Brakes - Fluidampr - DSS - 315/70/17 Pro Comp Xtreme A/T's Best Dyno - 628 HP/1266 ft-Lbs. Best 1/4 Mile - 12.72/105.94 - (7460 lbs) |
#15 |
Those Proxes dont look too bad. Price is not bad on them.
| Thread Tools | |
| Display Modes | |
