Thread Tools | Display Modes |
#31 |
Dandy
__________________
Forget standard procedure Y2K ISB 4x4 47RE by Mcmopar Ron Paul 2012 |
#32 |
__________________
99 QC 611hp/1141lbft with Cracked HTT manifold Big Thanks To: Peter @ Southbend Clutch http://www.youtube.com/watch?v=XmQhCXQbedg |
#33 |
#34 |
any idea why you lost power on the comp redline stack
it didnt look like it fueled to 4000 or did you not have the rev limit set that high |
#35 |
I ran it to 4k rpm, but for some reason, the dyno stopped recording? I think the settings were wrong on that run. I ran Redline 92%, Drag comp 5x5.
#36 |
well from the graphs it looks like with the redline/comp stack stretched the power out farther in the rpm range. the comp and adr fell on its face around 3500 where the red line was coming down sl;ightly but was holding more power and torque over all
#37 |
I love the new (Sept, 2009) tunes. ADR 3000 works great for me on the road.
And I'm no longer running the Smarty stacked on the Adrenaline. Without Smarty truck idles smoother and cruise control is ultra smooth on PL05. I also found the truck dynos higher w/o Smarty. BTW - Any dynoing I've done with Adrenaline has produced more hp on PL08 than PL10. Could be a Mach 6 thing?? RJ
__________________
02, 2500, QCLB, 4x4, Auto, 3.55 Power-Lok LSD - DTT/Billet - Smarty/Pulsed Adrenaline - Mach 6's - BD Twins - Snow's H2O/Meth - FASS - F-1 Cam/Valve Springs - HTT Manifold - LazarSmith Bars - TC Lockup Switch - RAD - 3rd Gen Brakes - Fluidampr - DSS - 315/70/17 Pro Comp Xtreme A/T's Best Dyno - 628 HP/1266 ft-Lbs. Best 1/4 Mile - 12.72/105.94 - (7460 lbs) |
#38 |
I wasn't going for big numbers above redline this time. I was wanting to see if I could pop 600hp. The Adrenaline run, I let out of the fuel at 3200 & slowly brought it back to idle. The drag comp run was brought up to 3000rpm & slowly brought back to idle.
#39 | |
Quote:
#40 |
I heard some cr put down 613 with 1 box and a stock cp3 with 140k on it.
__________________
04.5 Crew Dually- AFE intake, AFE bladerunner intake horn, Southbend DD 3600, Smarty TNT-R, 100 hp Industrial injectors, Silver Bullet 66-74-14, ATS Exhaust Manifold, Silverline 4", Fass 150, Pacbrake, EEP's Coolant pressur relief kit, Hamilton 110# springs, ARP studs --- 10-30-09 mustang dyno 613 hp / 1230 tq |
#41 |
#42 |
Graphs look nice Jamie. Looks like the Adr. edged out Edge, congrats on the cracking 600.
__________________
99 2500 SB/QC 4x4: 1/8-7.1@88mph 1/4=12.1@109 on #2 only. http://www.youtube.com/watch?v=fF8ePxWlf3w |
#43 | |
Quote:
![]() http://www.youtube.com/user/cummins7.../0/P3Q4h04l1II |
#44 |
wow thats awesome to know a 64 can hit 600hp. i def hope im close to that when i finish my build. Nice truck and nice numbers man.
__________________
2001 shorty 5speed manual, 5 in exhaust w/ 6 in tip, Isspro Gauges, Airdog 100, Valair full ceramic, Edge Comp, TST PM3... Next: 150hp sticks and a 62 or 64 single turbo. |
#45 |
Thanks man.
| Thread Tools | |
| Display Modes | |
