#1 |
Dose any one have noisy brakes?
Dose any one have noisy brakes? I called around for aftermarket brake pads but NAPA only had semi metallic pad and they said they would still squeal. I took the off (rear squeal only) and they were glazed so I sanded them down and noise gone but prolly not for long?
Danm exhaust brake works too good!!!!
__________________
2008 Dodge 5500 Quad Cab Laramie 4X4, inferno red, U connenct, 6 spd auto 4:88, heavy duty front springs, 220 amp, 11' Crysteel Dump 5 ton hoist with fold down sides 1997 Dodge 2500 SLT Laramie CTD 5.9 12 valve, 5 speed manual, 4x4, CC long box |
#2 |
Mine have not started "Yet" and yes I do love the Ol E-brake it stays on all of the time.. Do you have the "clunk clunk" shocks? mine do it when it is below 30 need to get them replaced before I have to get congressional approval for warranty work to be done....
__________________
08-Sterling Bullet 5500 4x4 6.7 Cummins,188.5,Quad Cab,White,Custom Built Flat-Bed,6sp Aisan,4.88's ,P-3,PTO/Snow Plow Prep. 05-3500 4X4.5.9, Jake Brake, Imp. Blue.Big Horn, Long Box Quad Cab, G56 SRW.3.73 LS.Custom Built Bed Rack/Weatherguard Tool Chest.Line-X OTRBL B&W T.O.B.,P-3 W/Valley "V30137" In Bed Harness. 01-Cat/EP 4x4 Forklift, 4.2L Perkins 32' 16.5K GN 42' 24K GN-el/hyd disc brakes |
#3 |
Just keep em clean. sand them down every 20 000 km
__________________
2001 suburban 2002 Dodge Ram 2500 SLT Laramie 4X4 stock engine other than k & n filter dodge mudlfaps billet grill inserts bug deflector window visors *SOLD* 1989 VW Golf N/A Diesel 52 hp of fury *SOLD* |
#4 |
Yeah, mine squeal at a certain pressure everytime (started a few thousand miles ago). If I press the peddle a little harder, it goes away.
I only have 13,500 miles on the truck so far and can't believe that the pads would be worn out already. Must be dirty rotors or something.
__________________
1997 12 valve 5-speed Ext. cab long bed - sold :-( 1999 Grand Marquis 2003 VW Jetta TDI 5-speed 2004 Kubota BX23 TLB 2008 4500 G56 Reg. Cab 4X4 ST 84" Cab-axle. |
#5 |
before driving yourselves insane, try taking the brake calipers off, and putting some disc brake quiet, or other silicone brake grease on the contact points between the pad backing plate and the calipers/pistons.
Also, make sure that the slides are functioning properly. This has helped on a lot of stuff that I have worked on over the years. And yeah, pad squeal makes me slightly nuts as well.
__________________
01 2500 Q/C 4x4, factory order HO w/5spd, 4 wheel discs, Pacbrake, 285 Cooper STT's on 058 Eagle Alloys. Ultra 5th wheel hitch. Glacier Diesel GFS-392 LP 01 F550 XLT 4x4, Jokestroke, 6 speed, heila knuckleboom, boxes and deck, low mount 5th wheel. No mods, no power, no fuel economy, kinda like a ford.... HAHA Never judge someone until you've walked a mile in their shoes. Then, when you do judge them, you're a mile away... and you have their shoes |
#6 |
both my ram 5500 and chry 300C have a squeling right rear brake.
__________________
2008 RAM 5500 Cab/Chassis, 4x4, 6.7 CTD, 6-sp automatic tranny, 4.88 axles, quad cab, partial bed, stainless steel fenders on rear duellies, 20,000lb hitch plate from Buyers Products with 20,000 lb. pintel hitch and a Dodge hitch receiver attached 2005 Chrysler 300C AWD - my wife lets me drive it once in awhile 2006 ASV-RCV multi-terrain track loader. (my SUV) |
#7 |
Just add brake pressure to make it quit. My last two 1 ton Rams did the same thing and neither ever had much brake wear.
__________________
2008 5500 Dodge Ram Quad drw, 4.88 gears, Aisin 6 speed with double overdrive in 5th and 6th. 18,750 pounds GVWR with a truck weight of 10,550. 2008 Carriage Cameo 35FD3 with a MorRide pin box HitchCrafter, 32 K Double Pivot Holland/Brinkley Air Ride hitch +The Super Wife! EscapeesRV Club |
| Thread Tools | |
| Display Modes | |
