Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > Towing and Hauling / RV
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 03-26-2007, 05:02 AM   #16
AlCorr
AlCorr's Avatar
I checked mine this weekend, Model number is on the list but not the serial number. I have a 2003 5er and had a problem with the refrigerator from the time it was new, they keep doing fixes on it until last spring when they replaced it with a new one, works great now.
I wish someone could post pictures of where this crack can develop in the boiler tube. Some of us that are not on the recall would sleep better at night if we new where to look for this crack. Just to see with my own eyes if there is or not a crack.
__________________
04.5, 2500, Flame Red "Dragon", 2/WD, 48RE, 4:10, Quadzilla Commander, Xzillaraider 2 XZT, Rokk timing sensor, Banks High Ram Intake, Mechanical Oil Pressure Gauge, BD Auxiliary Lift Pump, Aero-Turbine 4040L, Navigation Sym, Firestone Air Bag, Hellwig Sway Bar, Spray/Liner, Factory SRT-10 Hood, Mag-Hytec Diff. & Tran. Titanium 5er, Honda EU2000iA
AlCorr is offline   Reply With Quote
Old 03-26-2007, 07:36 AM   #17
crobtex
crobtex's Avatar
Quote:
10-4 on the pictures. My TT is set up in the country and has not moved in over three years. I'd like to be sure it has a problem before I buy new tires and wag it to the dealer for repair.
__________________
SUPPORT OUR TROOPS !
1999 Ram 2500, SLT Laramie, Quad Cab, LWB, 4X4, 5 Spd, Camper/Trailer Tow Pkg, LS/RE, Westin step bars, Ram molded splash guards (front and rear),diamond pattern bed caps and toolbox, Isspro EV boost, pyro and FP pillar mount. FASS II on 6/5/05. Rancho RS9000's on 8/23/05. RV275's on 12/11/05. AirRites on 3/5/06. MBRP 4" on 3/14/06. DSS on 4/8/06. Smarty on 10/12/06. New front rotors and axle seals: 8/08 Jammer 3's on 9/6/08, South Bend Con O on 1/30/09
304/718 on 4/1/06.
crobtex is offline   Reply With Quote
Old 03-27-2007, 06:11 PM   #18
Casey Balvert
Casey Balvert's Avatar
Check rv.net. Look at the Tech Issues forum. They have a sticky at the top. Lots of info AND pictures regarding this.
Casey
__________________
2003 DRW, QC, Black Laramie Sport, 2WD, HO/6 Speed, 4.10, "No Drill" Pullrite 25.5 Super 5th, J&J Stainless, Brakesmart, Jacobs EB, MBRP Pro 304 SS Exhaust, Timbrens, Tire Sentry, Line-X.
2004 Mountain Aire Fifth Wheel, tandem duals with XPS Ribs, solar, inverter, RotoChoks.
Casey Balvert is offline   Reply With Quote
Old 03-28-2007, 12:44 AM   #19
RATTLINRAM
RATTLINRAM's Avatar
Quote:
Casey
I put a Sticky back on this thread and here is the link for the posts on the rv.net website. CLICK HERE
Thanks Casey
__________________
*Dennis D. Tway*_____*1999 2500 SPORT QC*_____*Vice President-DTR Virginia Chapter#7*
2WD*Auto*3.54/LSD*Factory Loaded*Edge EZ*DDII's*BHAF*Wildcat -8AN SS Max Flow fuel system*MBRP 4"*CIPA Tow Mirrors
A-Pillar AutoMeter-EGT-Boost-Trans Temp*In-Dash Westach FuelPressure*55w Halogen B-U lights*Cool-Down Timer
Goerend Bros TC & VB + other goodies installed by VADTR Diesel Guru Tim Barber (Timinva)* 297.8 / 644.0 & 15.52 ET
*78 CJ5 *2002 Keystone 30' COUGAR 286EFS Double-Slide 5er*Harleys=77 FLHC*77 XLCR*79 XLS*
RATTLINRAM is offline   Reply With Quote
Old 04-02-2007, 12:47 AM   #20
duner
i would like to see those pictures but can't find them.
duner is offline   Reply With Quote
Old 04-07-2007, 03:31 PM   #21
Casey Balvert
Look on page 41 of that thread. Other pictures on other pages as well. Shows the problem area. A lot of people including myself are going to an aftermarket heater. The spec calls for 44 ohms resistance and mine was 37 ohms. Putting out too much heat in my opinion. Dometics fix is a band-aid solution at best to prevent a fire but doesn't address the cause of the failures. I hope that by using a properly rated heater, I will be able to avoid a future failure.
Casey
Old 04-08-2007, 10:02 PM   #22
Weg
Casey
Dometic also blames the problem on too much heat. In the time period of the fridges in the recall they went to a higher heating element.
__________________
1994 2500 #0 Plate, Autometer Pyro, Diprocol boost, 4.5" of lift, 315/75/16s, NV4500, 13.25 Southbend FE Clutch, 4x4, 4000rpm GSK, WH1C/HT3B, Studs, 370's
Dometic Recall For RV Refrigerators http://www.dieseltruckresource.com/d...d.php?t=141386 Dometic Recall For RV Refrigerators
Weg is offline   Reply With Quote
Old 04-16-2007, 08:14 PM   #23
Weg
Today is the first day that Authorized Dealerships/Service Centers are allowed to order parts from Dometic. Just thought that I would remind everyone to get it done.
Old 04-16-2007, 09:39 PM   #24
crobtex
crobtex's Avatar
Hmmmm.......mine is an '01 with the dreaded model and serial number, but I haven't recivied a notice.
I use mine at my place in the country, and it hasn't been moved in about 5 years. I guess I'll have to buy tires and pack the wheel bearings before I can take it in.
Old 05-07-2007, 07:13 PM   #25
duner
anyone here of any parts actually being delivered?
Old 05-07-2007, 07:35 PM   #26
P.J
P.J's Avatar
Gosh, I'm lazy. I just got out there and opened ours up on Sunday. Sanitized the fresh water tank and fired up the appliances.
I really need to take a minute and check out my serial #, I know with my luck I have one of the ones........
P.J is offline   Reply With Quote
Old 05-07-2007, 08:05 PM   #27
Weg
Quote:
Yes, Dometic is actively shipping out recall kits, my shop has done over a dozen so far. As long as the authorized service centers call Dometic up and order the kits they get them usually within 2-3 business days.
Old 05-27-2007, 09:16 AM   #28
traindrv
traindrv's Avatar
Just checked mine and it's OK, Thanks for the info.
__________________
2009 3500 CTD 2WD Dooly Quad 6.7 Auto
traindrv is offline   Reply With Quote
Old 06-04-2007, 12:50 AM   #29
TexasCTD
TexasCTD's Avatar
I just bought an 04 Weekend Warrior FS2600 and unfortunately the Dometic Fridge was on the recall list. I took it to my local RV dealer and they performed the recall in about 45 minutes or less. Added some sort of heat shield and sensor. Anyway the fridge worked good before and seems fine now too.
__________________
2004.5 SRW 3500 Black 4x4 SLT CTD QCLB, RanchHand w/ Milemarker 12K, Frontier Rear Bumper, Putnam XDR Class V hitch, Hellwig, Pacbrake air bags, Leveled, PW Flares, Nitto TGs 285/75/17, AFE Stg 2, GDP Walbro 392 w/2 micron, Smarty, TS MP8, Lazarsmith Traction Bars, DTT 48RE w/DTT Triple Disc TC, F1 valve springs and Flux 1.8s (needs more turbo now!)
506/1057 6-13-09, 13.27 at 8390lbs 10-10-09--stock stix, turbo, cp3
2004 WW FS2600 Toyhauler
SAC #73, Goofball #6, T.O.M. Dec. 2008
TexasCTD is offline   Reply With Quote
Old 06-26-2007, 05:55 AM   #30
rebee
Dometic recall
Dometic will not send any notice to customers. You need to contact their customer service Dept. and I believe there is a phone number for the recall.
My unit got a hole burnt into the cooling line. Talked with local dealer, no warranty. Cost of repair close to $800. Five months later wife read about recall. We contacted Dometic got a recall packet, filled it out and sent it back with our recipt and got reinbursed for the total cost.
Be proactive do not wait.
rebee is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
