Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 12-09-2007, 08:30 AM   #1
charger7022
charger7022's Avatar
Does my Tow Package charge trailer battery
I just bought a travel trailer and the guy at the dealer told me the battery in the trailer will charge off of the truck if its set up for it. I was wondering if the factory wiring on and 05 will charge my battery? i know the pin in the center of the 7 pin harness in a power but will it charge or do i have o do something diffrent?
__________________
05 2500 CTD 4x4 quad short bed SLT,upgraded tanny with billet single disc, red eagle clutches,upgraded solonoids. Bully Dog power pup, 5 in magnaflow. home made intake, no silencer ring 1995 jeep cherokee with 8.5 in lift 34 10.50 15 swampers on trailer waiting for MUD
charger7022 is offline   Reply With Quote
Old 12-09-2007, 08:45 AM   #2
hickeyman
hickeyman's Avatar
Your trailer batteries will be getting a charge from your truck.
__________________
2005 4X4 QC LWB 2500,48re,Goerend T/C & V/B,ATS Arc Flow,AFE stage 1 Pro Guard 7 with Torque Tube,BD Intercooler,Edge Hot juice/Attitude,HTT 62/65/13 ss,magniflow muffler, Fass 150 pump,5ohp DDP sticks,Mag-Hytec pans,SRT 10 Hood,Nasta Stainless Grille Guard,Nasta Stainless Nerf Bars,Rhino Lined,4" Superlift,35" Toyo MT,Leer 100xl canopy.
hickeyman is offline   Reply With Quote
Old 12-09-2007, 08:54 AM   #3
charger7022
would you know what the amp rating would be ??
Old 12-09-2007, 09:27 AM   #4
Big Horn 06
Big Horn 06's Avatar
I don't know how much, but I do know on my last trip, the trailer batteries went low (heater wouldn't start, fridge changed modes and water pump was weak) and all I did was plug it into the truck, didn't even start the truck and we were able to use the trailer 12v electronics for the rest of the trip and it didn't affect the truck at all.
__________________
'06 2500 2wd Big Horn Quad Cab short bed 4.10 auto AFE Torque Tube, Silent Might muffler, Nitto Dura Grapplers, Bilsteins, GDP intake manifold, Home Depot $11 air box mod and tube, some chrome goodies and SMARTY!! All paid for and MINE!!!
'66 Olds 442, Royal Mist, literally saved from the crusher, EFI 400 Olds V8, yadda yadda yadda..........
2002 Nomad 250 LT travel trailer
Big Horn 06 is offline   Reply With Quote
Old 12-09-2007, 11:23 AM   #5
C Schomer
C Schomer's Avatar
I've never checked the fuse size but the wire is small so the amps won't be very high. Having some voltage drop from the truck to the rv is probably good so the rv batteries won't be constantly charging at ~14.5 on a long trip. Craig
__________________
03 QC dually, 4wd - all on the rear, HO 6sp, 4.10 LS, Phat Shaft 62/65/14 w/4", TST/PMCR, GDP 391 Walbro, 2µ, Oilguard Bypass. In-line PXRB, Firestone bags, Rancho 9000s and onboard air/in-cab controls. Batteries behind the cab. Two BHAFs. Shortened frame and custom hauler bed. 98 Sunnybrook 30RLFS 5er. Olde Too Soon - Schmart Too Late!
C Schomer is offline   Reply With Quote
Old 12-09-2007, 11:49 AM   #6
Woodchuck61
Woodchuck61's Avatar
The 12v trailer pin is hot all the time and has a 15 or 20 amp fuse (I think it has a dedicated fuse). If there is a voltage differential the low batteries will drain the charged ones till they reach a balance point. Under normal running conditions the alternator will be the highest voltage and charge everything hooked up to it. When you park I recommend disconnecting the trailer plug to prevent draining the trucks starting batteries. A lot of RVs have generators and that can be used for recharging or restart the truck and then plug the trailer pin back in.
Woodchuck61 is offline   Reply With Quote
Old 12-09-2007, 12:32 PM   #7
torquefan
torquefan's Avatar
Quote:
It's not the center pin. That one's for reverse lights on a 7-pin connector. The power terminal on the truck connector is at the top right.
__________________
1996 Ram 2500 Club Cab, 4x4, 5 speed, KDP tabbed, Prodigy, Silverstars with relay kit, BD 4" cat back, Autometer gauges.
torquefan is offline   Reply With Quote
Old 12-09-2007, 12:33 PM   #8
swansong04
swansong04's Avatar
Quote:
i have a split RV plug so i can charge the battery in my camper and run it's clearance light and the i also runs the clearance lites and charges the little battery for my enclosed trialer... it works just fine ..
__________________
04.5 3500 SLT/QC/SWB/4X4 Patriot blue/bright silver 315/70/70 good year mtrs JUICE WITH ATTITUDE pioneer deh-p9400bh with sirius satellite radio ,phantom gauges , AIRAID BHAF hid conversion kit for the fog lights pacbrake brake PRXB exhaust brake and (pacbrake lock- up controller beta tester) DTT 89 % V/B T/C !! date of mfg. June 12th 2004
451.4 hp bd dyno days
2009 Yamaha Rhino 700
2011 Toyota 4runner limited
A FRIEND HELPS YOU MOVE !
A GOOD FRIEND HELPS YOU MOVE A BODY
swansong04 is offline   Reply With Quote
Old 12-09-2007, 03:40 PM   #9
Casey Balvert
Casey Balvert's Avatar
It will charge the battery but very slowly. It will on a very long trip. There is just a lot of voltage drop from your alternator to the trailer battery due to the size of the wires they use. As indicated above, you can use the truck's system to power 12 volt stuff in the trailer but you run the risk of running down the truck's battery to the point it won't start. As well, your truck's battery was never designed for deep cycle use. Casey
__________________
2003 DRW, QC, Black Laramie Sport, 2WD, HO/6 Speed, 4.10, "No Drill" Pullrite 25.5 Super 5th, J&J Stainless, Brakesmart, Jacobs EB, MBRP Pro 304 SS Exhaust, Timbrens, Tire Sentry, Line-X.
2004 Mountain Aire Fifth Wheel, tandem duals with XPS Ribs, solar, inverter, RotoChoks.
Casey Balvert is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
