#16 |
How long does it take to get used to that kind of weather, (if you weren't born there) and does it play he** with anything mechanical? It must be like a different world up there. What temp is it now? I guess it is something you just accept and deal with? ---like the humidity down here in the Southeast.
__________________
06 3500 SLT,DRW G-56, Q.Cab, Commander, Quad Race, Smarty TNT-R, HTT 62/65/13SS, GDP airhorn, Flux 1's. Formula 1 V.springs, ATS Exh. manifold, ARP Head Studs, Stage 2 Floor it CP3, GDP Walbro w/2mic F.Filter, AEM Workhorse, SouthBend 3250 dd clutch, Opie Bypass, Fluid Dampner, metal rollup tonneau cover, Headache Rack, B&W Turnover Ball, Grover Triple Air Horns, Ranchhand Bumpers, Fr. & Rr., ROCKSTARS, other goodies. |
#17 |
My gauge of temperature has changed already. I used to live in CO, but it was dang cold when we got here 2 months ago. Now anything near 0 or a few above seems like a good day, jeans and a sweatshirt. I feel adjusted but no means experienced I guess, in living here though. I mean knowing all the things you learn after a couple winters here, I still carry a box in the back with food, water, sleeping bag, spare clothes, shovel and chains.
__________________
Scott Patriot Blue 2000 3/4 ton NV4500, 285/75R16 BFG AT's, MBRP 5" exhaust, 2" leveling kit, ATS ARC-FLOW, ISSPRO's (boost, EGT, FP), BD Intercooler boots, GDP GFS392, AFE Stage 2, EDGE Comp, DDP Stage 4's, HTT 62/71/14, SB DD Clutch New VP at 120k For Alaska: Oil pan Heater,Trickle Charger, Block Heater, Moose Bumper 18FEB08: 521HP & 1110 ft-lb |
#18 | |
Quote:
Not sure how that quite happened. Lots of fun though, very pretty here. |
#19 |
Dang, Ice on inside of car. Whew. Jeans and Sweatshirt a little above zero. And here I would be bringing the brass monkeys indoors. Hat's off to ya.
#20 |
When you park inside, roll the windows down to let the moisture out of the vehicle. Once you are outside, leave the window cracked a bit for a few minutes . The tempeture difference from garage to outside is usually pretty significant and causes condensation (fogged windows).
#21 | |
Quote:
now I know. |
#22 |
So....anyone on here happen to live in interior Alaska and own a Smarty? Dealer can't seem to get it to work out
#23 |
If the guys down at Simmard can't help, try Northern Truck Center (Cummins dealer)or The Diesel Doctor. Diesel Doctor is spendy...... And like anything you probly better have a good idea fo what you want to happen so you don't get taken advantage of.
#24 |
I didn't think we had a Cummins dealer, I know where I will get the real parts when I need them. Good to know. Well, next step is print directions off of Genos and bring them in.
#25 |
A little late but norhtern truck wouldn't give me the time of the day to even talk about our motors. I tried ordering filters from them and they wouldn't even try. The diesel doctor are a good group of guys. they do good work and hvae a great knowledge of old and new diesels. I can't trust simmards after they messed up two of my buddies rigs. Not many folks up here know what they are doing with these things.
__________________
2005 3500 SRW QC CTD Laramie 4X4 |
#26 |
Thanks, I tried Gene's again, they said yes, we did the TSB, got it home, tried and tried, no high idle. But good news is I got a locking throttle cable and threw it in, works great. Still want the 3 cyl idle though....
#27 |
I don't trust Genes to even look in the direction of my truck. Too bad on the idle. Probably someone down in the anchorage area that could do it.
| Thread Tools | |
| Display Modes | |
