#1 |
Does anyone have a Smarty?
I went to the dealership and they didn't think my truck could get 3 cyl high idle, once he tried it wouldn't work. Just got errors that it wasn't connected for ignition wasn't on.
Anyway, does anyone have a Smarty for my generation truck that I could load a program and unload to get the high idle? Thanks!
__________________
Scott Patriot Blue 2000 3/4 ton NV4500, 285/75R16 BFG AT's, MBRP 5" exhaust, 2" leveling kit, ATS ARC-FLOW, ISSPRO's (boost, EGT, FP), BD Intercooler boots, GDP GFS392, AFE Stage 2, EDGE Comp, DDP Stage 4's, HTT 62/71/14, SB DD Clutch New VP at 120k For Alaska: Oil pan Heater,Trickle Charger, Block Heater, Moose Bumper 18FEB08: 521HP & 1110 ft-lb |
#2 |
The dealer up here SUCKS!
Like I said before this sub-forum is usually pretty dead but it's worth a shot. You migh check out the guys over at simard automotive. (451-9529) I hear good things about them and they apparently have one or two over there that are deisel savvy. I've never used them personally (1st Genner and fix my own broken junk )but I know a few guys that have. |
#3 |
Yeah, there's only a few up here active on the forum, didn't think I saw any with a Smarty, figured it's worth a try. I might just buy a dowel rod and trim it to the right length. Double as a tire thumper
#4 |
I have a hand throttle cable attached to the pedal lever for high idle in the cold.
#5 |
#6 |
I'll get some when it's light out. I parked outside due to laziness last night.
![]() ![]() It's just generic cable with a friction lock on it. Press the pdeal where you want it and lock the cable in place. They are availible at Napa and the like pretty cheap. |
#7 |
Thanks, I think I'm gonna get on that....
#8 | ||
Quote:
Here they are. Just a small bracket attached to the dash brace to hold the handle. And the cable attaches to the throttle pedal lever. Pretty simple. HTH.
__________________
-40* keeps the wimps away but I WANT A (BIGGER) GARAGE! 92 CTD Club Cab 5spd. Banks 14cm w/g turbo, 3.5" exhaust, pyro/boost/oil pressure/coolant temp/trans temp gauges, 190s, 3200 spring, pump tweeked, Hot-wired KSB, K&N, add-a-leafs and airbags. 225K & still rollin' Proud Member- Alaska Correctional Officer's Assciociation. "Walking Alaska's Toughest Beat" Quote:
#9 |
Thanks! Oh, yours pulls out to lock right? I was picturing in my head it pushing for some reason, makes more sense now.
#10 | |
Quote:
It pulls on the upper half of the throttle pedal lever above the pivot. I had one on a '93 that went all the way to the lever on the fuel pump. That one adjusted by turning an knob in or out. Just depends on how you want to set it up.... |
#11 | |
Quote:
Maybe I'll shop before I go there. |
#12 | |
Quote:
#13 | |
Quote:
The guys at Napa are usually helpful as well only problem is they are the $8/hr kind of guys ans need a bit of directing occasionally. ![]() |
#14 |
nothing like the unique experience of having some parts guru act as though they are doing you a favour by selling something to you.
Guys, if you need odd parts and so on , Go talk to Jim Sullivan at Tracer International/Alaska Generator. I have dealt with him quite a bit, and he is a standup guy to do business with. Mostly heavy equipment stuff, but he can get pretty much anything you want.
__________________
01 2500 Q/C 4x4, factory order HO w/5spd, 4 wheel discs, Pacbrake, 285 Cooper STT's on 058 Eagle Alloys. Ultra 5th wheel hitch. Glacier Diesel GFS-392 LP 01 F550 XLT 4x4, Jokestroke, 6 speed, heila knuckleboom, boxes and deck, low mount 5th wheel. No mods, no power, no fuel economy, kinda like a ford.... HAHA Never judge someone until you've walked a mile in their shoes. Then, when you do judge them, you're a mile away... and you have their shoes |
#15 | |
Quote:
| Thread Tools | |
| Display Modes | |
