Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > Big Rigs
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 08-04-2009, 09:01 PM   #1
DodgeDiesel1978
Does Anybody Really Know What Turbos Were Used in These Old Cummins Engines?
Hi,
Could anyone please direct me to any websites out there which have detailed information regarding the turbochargers used on the old Cummins 743 and 855 cubic inch diesel engines we all know and love?
Specifically, I would like to know not only the turbocharger models but also what engine models and control parts lists associated with them. For example: turbo model: Holset H1C - used on: Cummins NTC-300 - engine CPL: 529
Also, when attempting to retrofit a 1983 or later model Holset turbocharger (Big Cam III forward) onto an older 743 or 855 cubic inch Cummins diesel engine (if equipped with a Jake brake also), be aware you must also replace or alter the Jake brake model currently on it to the one the newer turbocharger supports. These steps are necessary because failure to heed them may result in noticeable piston-to-valve contact due to the more intense boost rise of the 1983-up Holset turbos.
Thank you,
Ben Edge (DodgeDiesel1978)
DodgeDiesel1978 is offline   Reply With Quote
Old 08-29-2009, 03:34 PM   #2
wb6epp
Hi: The old Pete I drove 1968 had a Holset T-590 on it, but most of the others seem to be the Holset T50 turbo which was a smaller one. Our fleet was mostly Cummins 335 & 350's also had a couple of V-8's though I didn't drive them. Our service manager always modified our trucks, so i don't know what was stock.
__________________
97 Dodge 3500 SLT duelly, 128,K, bone stock at present.
wb6epp is offline   Reply With Quote
Old 09-04-2009, 11:16 PM   #3
92roughstock
Lot of the farm trucks I've driven had VT50s in them, 290-350 range; 19702 vintages.
__________________
1993 W250 xcab, built auto, near stock engine. Gauges and upgrades coming soon
I'll keep my money, my liberty, and my guns. You can have the change.
92roughstock is offline   Reply With Quote
Old 09-05-2009, 12:05 PM   #4
Mr. MOPAR NY
Hi Guys, I'm kinda new here, but it looks like a great site. FYI-I currently have 3 Cummins trucks...'91 D-350 LE Dually @180,000mi (Carolina, no Winters), '92 W-250 LE 4X4 A/T 255,000+ mi (rusty now), and '07 RAM 3500 SLT 4X4 6.7 6spd stick, Flatbed...I had a '99 2500 SLT Larame Quad Cab 4X4 totally loaded-w/Leather and 'No Other Options Available' she had 'em all, and I let 'er get away...The only things I did to my '92 in 255K are change 2 water pumps, and the fuel shutoff soleniod, it still has the orginal starter, Alternator, Automatic transmission, tie rod ends...but after 17 NY winters it's getting rusty...
Mr. MOPAR NY is offline   Reply With Quote
Old 11-15-2009, 08:44 PM   #5
nwroten
The guys at Diesel Injection of Pittsburgh (Pittsburghpower.com) would know for sure.
__________________
2004.5 2500 QC 4x4. Power by Poole twins, ATS exh. manifold, PPE dual fuelers, DDP injectors, springs, pushrods, fluidampr, Suncoast tranny, vb, and shafts with ATS flexplate, 5" exhaust, ARP studs, FASS 95. Thanks Power by Poole.
nwroten is offline   Reply With Quote
Old 12-05-2009, 02:05 AM   #6
Clayten
DTR's Toad Wrangler
Clayten's Avatar
Quote:
Interesting. What turbo did they have? Oh never mind they are a 360 not a 855.
__________________
94 Dodge SLT 2500, 4x4, 5 speed,dual friction clutch, 100 plate,AFC and plate full forward, A pillar boost and Pyro gauges, 4" exhaust, K&N FIPK with outer wear, Pac brake, Frantz Oil cleaner, Firestone air bags, Rancho 9000 shocks, GM rear brake cylinders, rhino lining, home made DSS and a bunch of stuff that I can't remember
Clayten is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
