Thread Tools | Search this Thread | Display Modes |
#1 | ||
What do I really need for a tranny?
__________________
2006 Dodge Mega Cab, SLT, CTD, 2500, 4x4, 48RE, 3.73's, Toyo MT 295's, ARE Topper, Amsoil EaA189 Drop-In Air Filter, Redline 75-90 Synth Gear oil in front and rear diffs, bottomless stock air box, Tail Gate Easy Lift, Commander, Smarty Jr. |
#2 |
A high torque converter, a upgraded valve body and good rebuild by someone knowledgeable of Diesel would be minimum.
__________________
2008 1/2 3500 dually that is stock except for 2 micro inline filter for fuel. Infero red extended cab, long box made for highway towing. |
#3 |
i think you would be fine with a TQ and valve body also.
__________________
2004.5 Gold SLT Quad Cab 4X4, Leather, Navigation Smarty TNT & Outlook Monitor TS MP-8 II Silver bullet GDP 392 DDP 90's CFM+ Studs Nitrous (100 shot) Dual CP3's TC Lockup Switch DIY Boost Controller K&N intake system Missing Cat Silverline Muffler, 4" Exhaust and 5" Tip Built HTS Trans Autometer C2 Boost, Trans Temp, Oil Press, Fuel Press, Nitrous Press SAC Member# 149 |
#4 |
Call Dusty at HTS. Explain to him how you use your truck. He will hook you up with the right parts. Dusty is great to deal with, VERY knowledgable about trannys. Unlike alot of companys out there he will not try to sell you something you don't need.
__________________
Performance-HTS Tranny, Scarry Larry, MP-8, 5" Exhaust, 7" Black Mitered Stacks, Willy's Whistler, GDP Intake,GDP Comp Fuel System, Outside-8" lift, Thuren Trackbar, 37x13.50 PC Extreme A/T, 20x10 Black Monsters, Amp Steps, Black Headlights, Smoked LED Cab Lights/Taillghts/3rd brakelight, Big Mouth Grill, Debadged Inside-Triple Pod, Isspro Gauges, Sirius Radio, 20% Window Tint SOLD- '04 Dodge 2500 Q/C 4x4 6spd., Lifted with a few go fast goodies |
#5 |
this is true!
#6 |
Or I can give you Dave's number at Ultimate he's closer.....
#7 |
Thought I was going to be fine with the occasional street light racing too not that I do that but when I went to see dusty he was shocked to see I did not loose 3rd gear clutches were burnt pretty good talk to him or better yet get your trans done by him I can't describe how much you loose through the stock trans
__________________
05 2500 4x4 HI-O silver quadzilla xzt/smarty ats manifold/ htb2-62/13ss/ glacier lift pump/ aem intake/ afe-bladerunner/5"mbrp/ HTS trans thanks dusty / auto meter gauges/ mag-hytecDD pans/recon taillights/ level ride/ pro-comp shocks/kmc enduro/wbeadlock 315/70/17 bfg's all-terrain ko"s/ valor multimedia radio back-up camera |
#8 |
Shane,
Did I miss the post where you reported how you liked your new tranny?
#9 |
| Display Modes | |
