Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen Engine and Drivetrain -> 2003-2007
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 01-10-2009, 08:05 PM   #1
04ctd
04ctd's Avatar
How to: DIY Transmission low speed shudder fix
we talked about it being a TSB over here:
http://www.dieseltruckresource.com/d...d.php?t=226127
and basically, if you are out of warranty, it's gonna be a BUCKET of money.
if you have the dealer adjust your tranny bands, it's gonna be...a BUCKET of money.
if you have the dealer do your tranny fluid and filter...you guessed it.
so you may as well put in a drain plug while you are in there.
you can see my major spillage I had in one shot.
i thought last time, that huge tin serving pan caught it all.
TSB 21-009-07
Models: 2004 - 2007 (D1/DH/DR) Ram Truck (2500/3500)
Overview:
This bulletin involves the replacement of the governor pressure solenoid valve
in the transmission valve body.
Symptom/Condition:
The customer may experience a 1-2 shift transmission hunt during light throttle application. This
condition may be due to a governor pressure solenoid valve.
Diagnosis:
If the customer experiences the above condition perform the Repair Procedure.
Parts Required: Qty. Part No. Description
1 04617210 Valve, Governor Pressure Solenoid
4 05013457AA ATF+4 Automatic Transmission Fluid
AR 02464324AC Gasket, Transmission Oil Pon (Note: Original pan
gasket is reusable and should not require replacement).
50 images here:
draining the water from the fuel filter (notice i caught the pint of diesel and spilled the gallon of ATF),
greasing the fuel filter o-ring, and the SQUISH of the grease showing you got the cap on the filter tight.
here's the pan removed, I put the jack back about the middle of the door, so i had room to work
the screws are REALLY long.
slide the red LOCK back, then push the tab in to disconnect, and there is a white tab on the solenoid itself
push on the snout of the solenoid to push the whole assembly off the block
MSRP is ~$120 or so, dealer cost is around $80 or so.
R2D2's uncle?
you gotta put the solenoid in the retainer plate to install it, and get the arm of the retaining plate over the black thingie on the end - the retaining plate holds the solenoid and the black thingie (that had the wires on it)
"help" section in advance. this was ~$6.
ATF-4 is $6 a quart.
so if you can catch & re-use your fluid (I did this repair a month after I did the fluid & filter) you can save ~$35 worth of fluid.
the magnet comes off the pan to clean it.
I put the drain in the only corner that looked like it would not hit anything.
I should have put it more to the center, it ended up being curved up too much, and i had to shape it a bunch with a hammer & anvil to get a good flat mating surface, then i ground all the rough edges off.
i tightened it TOO MUCH and squished the plastic washer out (a CD Spindle washer could be used to replace it)
I think a flat metal washer above the plastic would have distributed the clamping forces better, on the inside & outside. (i thought of that AFTER i had the sealant on there)
i THINK this is the pesky loose coolant hose that leaks red coolant that looks like ATF.
You have included 11 images in your message. You are limited to using 10 images so please go back and correct the problem and then continue again.
__________________
1 Timothy 3:16
2006 Mega 4x2 3500 SRW
04ctd is offline   Reply With Quote
Old 02-02-2009, 09:59 PM   #2
04ctd
04ctd's Avatar
this looks like a better fix, and about the same price
http://www.transmissioncenter.net/dodge.htm
do a Control F (find) for 9-25-2008, and it will find this para:
This kit was specifically designed to handle higher base pressure in high performance applications and to improve the reliability of the governor solenoid in normal use. In performance units the pressure can flood the Dodge solenoid and cause a no shift condition at full throttle. This is the fix. Fits all rear wheel drive RE model transmissions. Added 9-25-2008. Cost $149.00
I put the stock part back in mine......
and I still get a little tiny stutter ever once a while
Old 03-25-2009, 05:06 AM   #3
fl dodge
i was talking to PATC yesterday they said it was a direct bolt in,you can check it out its a long page about 3/4 down.
__________________
2004.5 silver quad cab,48re,banks ram air/super scoop,quad.x2/commander,hell bent 2"leveling kit.
fl dodge is offline   Reply With Quote
Old 05-24-2009, 11:54 PM   #4
choppers555
choppers555's Avatar
Good info so that did the trick huh?
__________________
2007 dodge 2500 4x4 cummins, 6" lift BDS suspension, 37" Nitto Mud Grapplers, Bully Dog, ATS transmission stage 4, EGT gauge, trans temp, 3.73 gears, Bestop electronic side step. Banks super scoop Ram air.
Dave Dunbar dyno November 7th 2009
398.99 Hp 780 Torque
choppers555 is offline   Reply With Quote
Old 05-25-2009, 09:14 PM   #5
04ctd
04ctd's Avatar
Quote:
yes, but most guys report problems with the OEM part, and recommend the aftermarket solution.
in some threads, guys have had several of the OEM parts put in (under warranty by dealer), and the problem persisted.
Old 07-06-2009, 02:58 PM   #6
chopper9451
chopper9451's Avatar
so i have this problem going on and im scedualed to take it in tomorrow morning. Im still under basic warranty so i hope they cover the repair being i have a lift and tires... also, im going to un-download my tripledog tonight. hope that stuff doesnt effect my warranty
__________________
'07 2500 5.9CTD, Quadcab, Long Box, Auto, Black W/ metalic flake 4x4
- Muffler/CAT MIA
- Manual t-case shift
- Bullydog Tripple Dog Downloader
- DIY 6" Intake
- 8" Custom Long Arm Lift
- 37x13.5x20 Toyo M/T
- 20x10 Chrome Rockstar's
- BMW M5 HID Projectors
- HID yellow Fogs
- Silencer Ring MIA
- Bilstein 7100 Remote Res Shocks
2005 Harley Davidson FXST (customized)
chopper9451 is offline   Reply With Quote
Old 07-24-2009, 06:16 PM   #7
lane22
the tip for shift problem was a good one.
lane22 is offline   Reply With Quote
Old 08-14-2009, 05:07 AM   #8
Dodgefan01
Dodgefan01's Avatar
It took me SO long to get this resolved. I have had her in numerous times for this "shutter".
Finally the dealer replaced VB after performing the TSB and my prob is gone. Just FYI for those that the TSB has not fixed..
__________________
2006 DODGE RAM CTD TRX
Mods? What Mods?!
Dodgefan01 is offline   Reply With Quote
Old 09-14-2009, 09:27 AM   #9
gofastman
Send a message via Yahoo to gofastman
Oh guess what, this has not happened yet....It is not 10/1/2009. So if you are all really good this will not be a problem come 10/1/2009. Look at the date on his pics.
__________________
Gofastman,
03 3500HD Silver QuadCab SRW 2WD.
305hp, Dynomite Diesel Injectors 100hp, Edge Box, 6spd, AFE Fltr, 40 Gal Aux. tank, Vent kit for faster fill up, Autometer Gauges, Oil, Tranny, Rear Temps, EGT, Boost, Tone Ring Mod, Fan Switch, 5" exhaust (turbo back)
Lost silencer ring, 5ver Hitch, Class V Wt Dist. Sys. B&W Tow & Stow, XM Sat Radio, Cobra CB
641715 miles as of Feb 23, 2010
gofastman is offline   Reply With Quote
Old 09-14-2009, 03:35 PM   #10
04ctd
04ctd's Avatar
hee hee...it's hard to get GOOD help...
FWIW, i took my other car into a tranny shop,
and he said they no longer use the OEM part,
they use one similar to the second post.
Old 09-19-2009, 04:36 PM   #11
choppers555
giving it a shot tommorrow
Old 11-17-2009, 10:04 PM   #12
p0wd3rp1l0t
where can i get that drain plug kit?
__________________
06 2500 5.9L SLT BHE QC
p0wd3rp1l0t is offline   Reply With Quote
Old 11-18-2009, 02:23 PM   #13
04ctd
04ctd's Avatar
I think it was in the "HELP" section at advance.
just don't "gorilla fist" when you put it on, the washers will crush out
Old 12-22-2009, 08:09 PM   #14
bohdey
i just performed this to my '06 mega. i repl. the solenoid and pressure sensor and filter. it fixed the shutter, but my tranny is still shifting out of 2nd at 2500 rpm, too high. i talked to trans. shop and they think maybe bands. i think modified valve body should work.
bohdey is offline   Reply With Quote
Old 12-29-2009, 10:17 AM   #15
bohdey
band adj.
had my band adjusted on outside of tranny and it shifts like new. evidently these really should be adj. every 30K or so according to trans. shop. adjustment was free.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
