Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-04-2009, 11:23 AM
13ALPHA's Avatar
13ALPHA 13ALPHA is offline
Disappointed with dealer, no 3cyl. high idle
So took the truck in for a second time to get the 3 cylinder high idle enabled. I gave them the TSB printed out with it to help them this time. I got it back, let it sit all night in 10*f, not plugged in. Went out this morning, started it, sat for 5 minutes, no high idle. It had parking brake on, in neutral, etc, all the conditions listed met. Any ideas? I will give it some more trys though. Choke cable here I come.
__________________
Scott
Patriot Blue 2000 3/4 ton
NV4500, 285/75R16 BFG AT's, MBRP 5" exhaust, 2" leveling kit, ATS ARC-FLOW, ISSPRO's (boost, EGT, FP), BD Intercooler boots, GDP GFS392, AFE Stage 2, EDGE Comp, DDP Stage 4's, HTT 62/71/14, SB DD Clutch
New VP at 120k
For Alaska: Oil pan Heater,Trickle Charger, Block Heater, Moose Bumper
18FEB08: 521HP & 1110 ft-lb
Old 11-04-2009, 12:25 PM
Busboy Busboy is offline
A few guys on here have installed 12v electric solenoids like from older cars with AC. Put it on a sw and you can bump the idle anytime.
__________________
2001 2500 quad 4X4 5 spd Stock except gauges
Old 11-04-2009, 05:03 PM
STATELINE's Avatar
STATELINE STATELINE is offline
I beleive there is more to it than the programming on a manual trans. I know it took more on my 05.
__________________
2001 Ram 2500, auto, 3.54's, quad cab, boost, fuel, & pyro gauges, Qzilla XZT+, Magnaflow 4", FASS DDRP
The Womans Ride...2005 Jeep Liberty Limited CRD, not a Ram, but a sweet ride
pride & joy... 2007 Victory Vegas Jackpot Arlen Ness Edition
Originally Posted by Gotlift01
........and if anybody disagrees on that you earn the right to be slapped in the back of the head.
Old 11-04-2009, 05:22 PM
AggieJustin's Avatar
AggieJustin AggieJustin is offline
Send a message via Yahoo to AggieJustin
Here's the criteria for the factory high-idle
Quote:
Once enabled, idle speed will slowly ramp up from 800 rpm to 1200 rpm when all of the following conditions are met:
1. Intake Manifold Temperature less than 0°C (32°F) and,
2. Coolant Temp is less than 60°C (140°F) and,
3. The Transmission is in Neutral or Park and,
4. The Service Brake pedal is not depressed and,
5. Throttle = 0% and,
6. Vehicle Speed = 0 mph
Additionally, if Intake Manifold Temperature (IMT) is less than -9°C (15°F), and all of the parameters above are met, three of the cylinders will be shut off upon reaching 1200 rpm, creating a slight change in engine sound which is normal. This allows the engine to create increased heat in the cooling system, allowing more rapid engine warm up and cab heating.
Both features will automatically disable when one of the following occurs:
1. The Automatic Transmission is placed in gear (forward or reverse) or,
2. The Service Brake pedal is depressed or,
3. Throttle position is greater than 0% or,
4. Vehicle Speed is greater than 0 mph or,
5. Coolant Temperature is greater than 79°C (175°F).
Engine speed will return to normal operation at 800 rpm. If the engine continues to idle and coolant temperature is at or below 60°C (140°'F), the feature will reenable. In order to operate properly, the Accelerator Pedal Position Sensor (APPS) must stay at idle.
NOTE: ANY TYPE OF AFTERMARKET IDLE SPEED KICKER THAT ACTIVATES THE APPS WILL DISABLE THIS FEATURE.
Use of the 110V block heater will not allow the feature to function after an overnight soak. If the vehicle is left idling, without use of the block heater, 1200 rpm operation will begin when the intake temperature drops below O°C (32°F) and coolant is less than 60°C (140°F).
I'm guessing with a 10* ambient, your coolant temp and intake air temps were both within the ranges. Possibly you have a bad IAT or coolant temp sensor that is showing an inaccurate reading making the ECM think it's warmer than it is. Or an inaccurate reading from the APPS indicating greater than 0% throttle.
__________________
Maroon 2001 2500 QC 4x4 SB SO pumped HO 6-speed
285/75R16 BFG Mud Terrain T/A KO, Smarty, TST Powermax3, KSB1-1, DD2s, Autometer EGT/Boost, Westach Fuel Pressure, Amsoil EaAU4091
Old 11-04-2009, 07:39 PM
graphitecumnz's Avatar
graphitecumnz graphitecumnz is offline
Send a message via Yahoo to graphitecumnz
Quote:
Nope... just get the correct programming and if your sensors are working correctly, it'll work as described.
__________________
2002 2500 H.O. CTD, QC short bed, 4x4 , 3.55 gears, 6" stack, Silencer Ring MIA, FASS, BHAF, Di Pricol Boost gauge, Fuel Pressure gauge and Pyrometer... BFG MT's in 285/75/16 on American Racing Mojave's in 16x8... JVC cd/mp3/wma head unit....Tinted windows...
Dodge Makes it, Cummins Shakes it...
"Politicians never accuse you of 'greed' for wanting other people's money --- only for wanting to keep your own money."
Old 11-04-2009, 08:42 PM
nickg's Avatar
nickg nickg is offline
I had the same issue, dealer screwed it up, even after I gave them the TSB, I wasted 100$.
posted in the local forum chapter, and I met with a guy locally who had a Smarty. I bought him a coffee and a donut (I offered much more but that was all he wanted!!)
he loaded and unloaded a program, and I ended up with hi-idle!!
I already have a manual cable as well (easily hooked up under the dash, no need to hook it up in the engine bay)
__________________
Nick
2001, 2500 Edge J/A Hot unlocked,Magna flow exhaust. Jammer II's. BHAF, Airdog 150,DSS,3rd gen Track Bar. Carli Suspension, 3rd gen Brake upgrade, transgo Shift Kit. Firestone AirBags May 07 297,000kms Jun/09 455,000kms RETIRED Military Mechanic (20yrs)
Old 11-04-2009, 09:35 PM
Dr. Evil's Avatar
Dr. Evil Dr. Evil is offline
Same for me. Thanks Tate.
__________________
It's Dr. Evil - I didnt spend 6 frickin' years in Evil medical school to be called Mr. Evil - Thank you very m-u-c-h!
PROUD DTR Truck of the Month Winner - March 2007
Old 11-04-2009, 11:08 PM
13ALPHA's Avatar
I would love to borrow a Smarty, but there aren't too many members up here, let alone ones with 2nd gens. I will be cleaning my IAT, hope that helps. Adjusted APPS not to long ago, it should be good. And, due to a hard starting issue I replaced the coolant temp sensor. We'll see if it works sometime.
__________________
Scott
New VP at 120k
Old 11-05-2009, 12:07 AM
Dr. Evil's Avatar
So are you wanting the high idle or the 3 cylinder idle? They are 2 different things.
I cant remember what temp the 3 cylinder idle kicks in but its fairly cold. Does anyone know the parameters for that?
__________________
Old 11-05-2009, 12:17 AM
johnh's Avatar
johnh johnh is offline
Send a message via Yahoo to johnh
Quote:
they work together ... high idle first, then if it's cold enough 3 cyl kicks in
__________________
01 3500 ho 2WD;4 inch exhaust bully dog stage 3 inj edge comp(removed hybrid hx 35/40 8/25/04) dyno 419.2 hp 891.8.torque w/stage 2`s on a dyno jet 6/25/03 ,htb2 turbo installed 8/25/04, not a dually any more,conversion done in 04... added home designed propane march 07 (to improve mileage) new vp 44 from industrial injection 3/july/07 181000 miles, removed stage 3 injectors ,reinstalled stage 2 to try to control EGT's better
Old 11-05-2009, 07:56 AM
Burrhead Burrhead is offline
Quote:
Quote:
Could that be the problem why it didn't ramp up?
__________________
99 quad cab long bed 4X4 , auto, 3.55's, Power Puck, 285/75R-16's, muffler removed, rebuilt injector pump @133,000, fuel pressure warning light.
2000 28' Sportsman double slide 5'vr
Old 11-05-2009, 08:32 AM
RowJ's Avatar
RowJ RowJ is offline
Nope!
Believe 'service brake' is the brake pedal, not the emergency or parking brake.
13 Alpha - Sounds like it should have worked for you. I seem to remember it takes a while for it to ramp up to 1200 rpm.... but 5 min should do it?
I would go back to dealer and have them check to be sure it's activated. I remember reading some dealer confusion on how to enable the high idler. Something about dificulty on how to save it once entered? Working from memory so.....
Anyone else?
It is definately a cool addition. Only seen it kick in once down here (that was on 'Aggie Justins' CTD).
Never would high idle on mine? But should be a daily item for you! .
RJ
__________________
02, 2500, QCLB, 4x4, Auto, 3.55 Power-Lok LSD - DTT/Billet - Smarty/Pulsed Adrenaline - Mach 6's - BD Twins - Snow's H2O/Meth - O-Ringed/12mm Studs - FASS - H-2 Cam
F-1 Valve Springs - HTT Manifold - LazarSmith Traction Bars - TC Lockup Switch - RAD - DSS - 3rd Gen Brakes - +2" Front CSS Springs - UTE Bullbar/Bumper - 315/70/17 Pro Comp Xtreme A/T's
Best Dyno - 628 HP/1266 ft-Lbs.
Best 1/4 Mile - 12.72/105.94 - (7460 lbs)
Old 11-05-2009, 09:32 AM
Wild4kst8's Avatar
Wild4kst8 Wild4kst8 is offline
check IAT... mine took 2-3 minutes to kick in (with Smarty)... if you don't get the high idle, i would say the dealer isn't doing something correctly
__________________
Rattlin 'n Gobblin
2006 DMax LLY 4x4 CCSB
SOLD! - 2001.5 2500 SLT QCSB 4x4 Silverline exhaust, cat MIA, silencing ring MIA, new relocated LP at 72k, fuel pressure gauge installed, home-made BHAF, Diablosport Power Puck, SMARTY, Alcoa Classic Series w/ Hankook RF10 285/70/17s
Old 11-05-2009, 11:00 AM
The high idle kicks in with the IAT at or below 32*. The 3 cyl idle kicks in when the IAT is below 15*.
The main thing to keep in mind is that with the grid heaters warming the initial intake air charge up, your IAT is always going to be somewhat warmer than the ambient temperature. Also, if you have any residual heat left in the engine from the last time it was run, that is also going to affect your readings.
__________________
Old 11-05-2009, 11:13 AM
13ALPHA's Avatar
Lots of good points. I am pretty sure all the conditions are being met, it may just be a temp sensing issue. I will give it some more time to work out. It's just when a dealership is rude each time, it sets me down that path of not trusting them. Know what I mean?
__________________
Scott
New VP at 120k
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
