Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-27-2008, 02:19 AM   #61
CrashCade
Send a message via Yahoo to CrashCade
Quote:
Originally Posted by mpracehemi View Post
Sounds like I'll be in good shape then. I talked to Shane (Wickd) and have his stage III on the way along with DDP 90's.
With 90hp injectors you should be more than sufficient.
Quote:
Looks pretty simple to install but the top assembly is mighty heavy to be lining up. I'm gonna use my engine lift for that.
It really isn't all that bad. I removed my headlight, inner fender well, and the fender. It made things a lot easier to get at. I think you will find that you can get one end started first, then line up one of the middle holes and start a bolt. Doing it this way makes it so you don't have to lift the weight of the entire assembly. I think once you get everything removed from the truck to do the install you will see what will be easier for you. The one thing I cannot stress enough is to double check your oil line to make sure everything is tight.
I am telling you guys that are sitting on the wall, Jump in they are great!
__________________
2005 Dodge Ram 2500 4x4 Laramie
Floor It Stg 3 CP3, Turbos, Billet Suncoast
120hp Injectors, FASS 150, Head Work
12" Lift on 40"s!
CrashCade is offline   Reply With Quote
Old 11-27-2008, 02:46 AM   #62
White97GTVert
What was your best run of the day?
__________________
'05 2500 QC 4x4 - Cummins Power Baby! - Smarty b4.2 - AFE Intake - 5" Turbo back Exhaust - HTS Full Billet 48re - PPE Dual Fueler - A little pressure from the EZ - Airdog 150 - HTT 64/71/13ss - F1 Springs - Flux 3's --- I need more Turbo.. -- BD Exhaust Brake + Towloc -
'05 2500 QC 4x4 - Smarty TNT - AFE Intake - 4" Turbo back - HTS Full Billet trans - Floor It stage 3 pump, Flux 2's - F1 Springs - ARP Studs - RP 150 + GDP 2mk Filters - Small twins 62/3b - BD Exhaust Brake + Towloc - Tow rig
White97GTVert is offline   Reply With Quote
Old 11-27-2008, 03:12 AM   #63
mpracehemi
mpracehemi's Avatar
On wickd's cp3, set up is for me to grow into it more. I'm always wanting more power. I needed a better than stock cp3, so since I'm buying might as well go for it.
dps is working with wickd to provide a cp3 in the turbo kit in the future, the stage is the cust. wants/needs.
__________________
05 RAM 2500 SLT QCSB- 2-wd. 5" t.b.-6"black aussie's-AFE- INGLEWOOD/GOEREND rebuilt ATS trans./conv.-SFI fp-AMlite gauges- TURBOTIMER-MP-8,-QDRPgauge-2mc ff-HAMILTON SPR./pr's-ARPs-DDP 90's-HOLLEY HP 140 FP 1/2'' line w/5m W.sep filt.-CP3 STG. III-TWIN TURBO'S (dps)-heatr grid delete-delete ff plate-SMARTY POD TNT-R
'71 DODGE CHALLENGER "572"HEMI,(needs to go on 'glass diet) 9.72 @ 140mph
Can't afford to pay labor-more $$ for parts.
1st DIESEL TRUCK-3/9/08
mpracehemi is offline   Reply With Quote
Old 11-30-2008, 10:27 AM   #64
Hintz
Hintz's Avatar
TTT-for some numbers
__________________
06 2500 Quad Cab SLT
6speed
Straight piped
315/70/17 BFG's AT
Isspro Gauges
Smarty PoD
SBC DD
Airdog 150
Extrude Honed Injectors
SAC#213
Hamilton Springs
ARP's
BD Super B/s475 Twins
552HP/1058TQ...old numbers...and in need of a CP3(s)
Hintz is offline   Reply With Quote
Old 12-18-2008, 04:54 PM   #65
mpracehemi
mpracehemi's Avatar
Well , I went to see when/if I could put my truck on the dyno and the dyno is GONE!!!! Shoot!! I don't think there is anyone else close to me. I'm starting my changes tomorrow so I won't find out where I'm at.
Old 01-16-2009, 01:21 AM   #66
CrashCade
Well as bad as it sounds, especially after I said they are cast in house as I was told. They are cast in China. The exhaust manifold says right on it made in China as well as one other place, I believe it was on the top turbo.
I don't know if you guys have read my other thread about low boost out of the HT3b, but would it be possible to swap in a S400 of some sort to help with the boost problems?
Old 01-16-2009, 01:35 AM   #67
mpracehemi
mpracehemi's Avatar
On my set, both turbos are bocsh......ex.man. has china. I'm getting closer to having the brkt/brace fabbed for supporting the bottom turbo, it's kinda time consuming as to I've changed my designs 3 diff. times after I've built them......I guess i should just stop re-designing and just go with the present one and be done with it. I'm itching to fire this beast up and drive it!!
Crash, what exactly happened to yours??
Old 01-16-2009, 10:49 AM   #68
Diesel- Dummy
Sounds like thay would be good for a towing twins setup like B D makes . I dont think the cast parts will last from China . a buddy of mine works at a big diesel shop thay have all kinds of trouble with parts from China the ex manafolds crack in 6 mons or less thats for big semis. So hope that turbo houseing from China holds up . There are lots of people makeing twins some are very good for towing some are knowen for power . My twins are Bulleyes power twins Thay sell complete kits from towing to over 1000hp. Thay Are the one and only place that makes the real race cover for the S400 type turbos NOT THE MPI RACE COVER ITS A JOHN DEAR TRACTOR COVER .In the end make sure you buy a set that does the job you wont . My first set was aBD towing setup . Then I wonted more, did some looking around at ALL THE TWIN MAKERS and got the bullseye twins setup thay can grow with me . I dont need to get new pipes made I will need to change turbo wheel sizeing right now mines good to 850hp now i only make 650 ish so a stock S475 would work for the low 700s with a 62 65 14 , one more thing when i went from a 62 65 14 cast ex to my HTT62 65 13ss The hot pipe is made so it fits both the exhaust housings the hot pipe is not beat from a round pipe into a rectangle with a hammer like every outher one I have seen . The flange is cnc'd from round to a t-6 its the best kit I have seen . Thay are made in the USA and use Borg Warner turbos like all the big turbo diesel shops.
__________________
02 DodgeQcbSB 4x4 Hot Juice 200hp inj Htt 62/65/13ss & S480 H.T.S Full billetTrans 89%
Diesel- Dummy is offline   Reply With Quote
Old 01-16-2009, 11:42 AM   #69
soulezoo
DTR 1st Sergeant
soulezoo's Avatar
No... the 3b you have is a reverse drive turbo... meaning it is built and spins in the opposite direction of an s400... a mirror image if you will.
__________________
2004 3500 QCSB Laramie SRW 4x4, CA emissions SO 235hp, 3.73 posi, Peak Performance BB Twins, engine by Diesel Nut, Almost stock
DTR "Twins" Club Member #1
11.89 @ 119.2 mph
1/8 mile= 7.76@94.94 mph
900.86 rwhp/1689.76 tq @ Left Coast Diesel 21 AUG 09
TNT member #2
SAC member #9
soulezoo is online now   Reply With Quote
Old 02-27-2009, 12:05 PM   #70
CrashCade
Well, I received an email from DPS about an upgrade they have available. It is an upgrade for the top turbo. I guess it helps even the boost between the two turbos as well as lowers DP and egt's. I am going to give this a shot and see how it works. the only thing I am not happy about is about having to pay $110 + shipping for a resolution to the problems i have had with these turbos.
I will post back after I get this upgrade installed.
Old 07-17-2009, 09:09 PM   #71
firemanram
firemanram's Avatar
CrashCade, what is up with your twins now? Anymore info for us?
__________________
2004.5 3500 Dodge Dually 4x4 Laramie, AEM air filter w/homemade air box, Monster exhaust, Kitty ran away
2005 Jayco Eagle 32.5 BHS, HTS trans, Smarty Sr
IAFF Local 706
firemanram is offline   Reply With Quote
Old 11-15-2009, 07:33 PM   #72
Jason_K
Jason_K's Avatar
bump,
how are these twins working out?
__________________
2005 CTD 2500 4X4 QC, SB NV5600 3.73
Smarty TNT/R PoD
Industrial Injection Silver Bullet
Wicked Diesels Stage 3 CP3
FASS 150 HPFP
Extrude Hone 90hp Sticks
Hamilton Springs
ARP Studs
Valair FE
Quadzilla Boost Fooler & RP Guage
Isspro EGT/FP/Boost
DIY 2 Micron Fuel Filter Kit
Jason_K is online now   Reply With Quote
Old 11-16-2009, 02:23 AM   #73
mpracehemi
mpracehemi's Avatar
I've had these on for 7 months now and like 'em but I haven't had anything to compare them to either. I do know that one of the valves for the wg broke off and luckily got caught wedging the other valve open instead of falling into the bottom turbo. The warranty covered everything so can't really complain except for my time of replacing it. Have to say was a kinda fluke thing from manufact. which is borg warner.
I'm seeing 50-55#'s boost with 45-50#'s drive press when I do push that high. Norm. is 30-40#'s with 1:1 dp. Now that's the way I have my wg set, not the way it was shipped from dps which I was advised not to change from a couple other sources...but with my one yr. almost over (bought/shipped in late Nov.'08), I figured try and see what happens...dps never told me not to adj. and you're supposed to tune turbos dp anyway.
A friend just bought a diff. set of twins and should be installing them t-day wknd, that's when I want to compare between the two myself. Both trucks will be the same except for turbos...
Old 11-16-2009, 03:57 PM   #74
Jason_K
Jason_K's Avatar
If by chance that my friends truck delivers more power, I'll be installing another new set and the dps twins will be up for sale. I'm sure I'll find someone that wants to save some money and isn't looking for the most power avail. to help in towing. I'm not saying that the dps twins doesn't give power, they do, it's just I want more out of running twins.
Thanks for the update, let us know how your buddy's truck runs in comparison
Old 11-16-2009, 04:18 PM   #75
mpracehemi
mpracehemi's Avatar
Will do...but I know how long it takes to do all the mods.(springs, stix, turbos, exh., and fuel system) at once when a person has a full time job and family...priorities. If I can ( might be painting a vehicle same wknd ), I might be over to help....kinda in a hurry to compare, I don't have very good patients. haha
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
