Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > General Diesel Discussion > Fuels / BioDiesel / Diesel Prices
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 10-03-2009, 08:07 PM   #1
D45
D45's Avatar
Diesel Fuel Additives
Anyone read the November 2009 issue of Diesel Power Magazine?
Pages 150-152 covers using three types of fuel additives, to help out with getting better mpg.
The test mule was a 1997 F-350 Crew Cab 4x4, with the
7.3L Powerstroke......auto trans, 4.10 gears, LT285 tires
No Additive:
Highway Average: 14.6
City Average: 13.7
Overall Average: 14.1
Two Stroke Pre Mix (TC-W3):
Best Highway: 16.3
Best City: 14.9
Highway Average: 15.6
City Average: 14.6
Opti-Lube XPD:
Best Highway: 17.4
Best City: 15.7
Highway Average: 16.1
City Average: 14.4
FPPF 8+ Cetane Improver:
Best Highway: 17.3
Best City: 15.0
City Average: 14.9
Fuel Mixing:
Two Stroke: 200:1
Opti-Lube: 256:1
FPPF: 256:1
I thought it was a good test that shows additives should be used all the time, with really good results!
__________________
-2004 QC/LB, 4WD, 305/555 CTD
-Fabtech 4.5" Lift Kit
-2.25" Dirt Logic Shocks
-Cooper STT 37x12.50s
-Silver Satin Hummer H2 Wheels
-MBRP 5" Turbo-Back Exhaust / 6" MBRP SS Tip
-CFM+, Air Dog 150, ARP Studs
-IceBox Intake w/ DPP Cool Hose
-DeeZee FX Running Boards, Swiss Cap
-Recon Line of Fire, PSC Steering Brace
-ATS Fender Flares, Line-X, 20% Window Tint
-Quadzilla Commander, SMARTY SR POD
-ATS Pulse Flow, BD Super B Single
-Custom Built 48RE Trans
D45 is online now   Reply With Quote
Old 10-12-2009, 10:04 AM   #2
CoastalDav
CoastalDav's Avatar
Send a message via AIM to CoastalDav
Thanks for posting that. I had not seen it.
I'll bet the Two Cycle oil was the cheapest per oz to use. Results are about what I've been seeing using it the past several years in my 2000 Cummins.
It does seem to run good in the 2006 at 256:1 or 1/2 oz per gallon. I'm seeing high 19's to low 20's for mileage on the hwy at 68 mph. My last two cummins trucks seemed to get into the fuel tank above 2000 rpm's. So I ran just under 2000. This 06 does not seem to be much differant.
Dave
__________________
2006 Dodge 3500 SLT, Cummins, 48RFE, 3:73's, 70 Gallon Transfer Flow Bed Tank with Trax II Monitor System, Racor Marine Centrifigal Water Seperator/10 Micron Filter in the system. Edge Insight w/pyro, Headache Rack, Turbo Wing, Rhino Bed Linner, Nasta Rails, Recon Lights and Strip Lights, Sirius Sat Radio, Net Weight 7,520 lbs with 34 gallons fuel Tagged at 13,500lbs GVW. Towing 35ft Carriage ,Triple Slide 5fer, GVW 14030.
04 Hemi Durango AWD "Grannys Hemi Kid Getter"
CoastalDav is offline   Reply With Quote
Old 11-10-2009, 11:30 PM   #3
turfguy
turfguy's Avatar
I read the best for lubricity was good old B-20. 1 qt or so per tankful (could always use more), & it increased mpg too & quieted it down. At 3.50 a gal. it would be .88 a qt. :-) (cheaper than 2 stroke mix)
__________________
94 cummins 2WD reg cab :-( / K&N air intake / 3" straight pipe-made into duals / 215 hp pump / ATS converter w. DTT box / KDP tabbed (LONG night) / timing @ 13.5 / GM rear wheel cyl's / gauge pillar done! #10 plate / Best of 27mpg hwy :-)
95 cummins 4wd reg cab stock
'95 Ram 2500 4x4 gasser ext cab- gas hog!
'88 GMC 1 ton dumper- 454 big block
'87 Silverado 5/8 ton 4x4- work horse (retired)
'90 7up 5.0 Mustang vert 5 spd :-)
'77 Datsun 280z 2+2- turbo project
turfguy is offline   Reply With Quote
Old 11-11-2009, 08:11 AM   #4
MikeyB
MikeyB's Avatar
I have just started using Opti-Lube summer blend, and I like it much better than the Power Service Diesel Klean. Engine is quieter and smoother. No mileage numbers yet, but appears to be about the same as before.
MikeyB
__________________
2003 2500 2wd SWB Quad Cab Laramie, 305/555, NV5600, 3.73LS, Line-X, Westach boost/EGT combo gauge, Fogzilla mod, PML diff cover, Airbox mod w/Amsoil Ea, Hurst 6spd Shift knob, Adjustable boost elbow, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake Horn, Headlight wiring upgrade
SMARTY/Van Aaken C3.2
2005 Dodge Magnum RT (Wife's ride)
2008 Dodge Caliber RT (Daughter's ride)
1990 HD FXSTS
MikeyB is offline   Reply With Quote
Old 11-16-2009, 11:53 PM   #5
mudwisr2
mudwisr2's Avatar
Thanks for the info. I have not been using any additive for the past couple of months and need to start back. I normally run 2 stroke at 1 oz per gallon. Sometimes Power Services. I've never noticed much of an increase in mileage.
__________________
'00 3500 6spd Single Cab Flat bed 4x4
Juice w/Attitude VP44 not tapped
Valair Clutch : BHAF
05 3500 SRW 4x4 6spd stock 111k miles
(Ad removed signature violation)
mudwisr2 is offline   Reply With Quote
Old 11-18-2009, 04:37 PM   #6
D45
D45's Avatar
I just got a container of the FPPF 8+ Cetane Improver in the mail
After the current tank, with Power Service, runs out......I will add the FPPF and see how it does
Old 11-24-2009, 03:56 PM   #7
parklane
I'm using 1/2oz per gal of the wally world stuff, but haven't noticed diff in noise or mpg.
__________________
if you don't like the way I drive, stay off the sidewalk
Pearl black 2006 QC 5.9,auto,4x4, homemade CAI, juice with attitude, polished 80 gal saddle tank in box.
parklane is offline   Reply With Quote
Old 11-25-2009, 01:55 PM   #8
DBLR
DBLR's Avatar
I just started to use 5.25 oz of Howe's at every fill up to see if it makes a difference.
__________________
2006 Ram 2500, Big Horn Edition SLT, Mineral Gray, Auto, 5.9L HO CTD, Quad Cab, 4x4, Short Box, 3.73's, Nasta Nerf Bars, Window Shades.
DBLR is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
