Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 05-07-2008, 08:31 AM   #1
taterfarm
died and won't start
My brother just bought a '93 W250, the guy said he was driving down the interstate and the truck died, he coasted to a stop then it restarted and he made it a few hundren feet and it died again.
the guy took the truck to VIP and they put on a new lift pump and filter. still no start. they said it was the injection pump. Now we dont know how long the truck has been setting.
So my brother checks the tank...empty, maybe the guy took the fuel out, don't know. Anyways, add fuel, pump lift pump, bleed at the filter on both inlet and outlet, bleed all injectors, everything gets fuel. still no start.
will run on either
shutoff has power
fuel at all points
truck will cough sometimes other than that it just cranks
So..
1. can the injector pump die on the spot and cause this?
2. can an air leak in the supply line cause this? (the injectors do get fuel)
3. will the pump off his 89 swap to the 93 without changing anything else?
4. should he go and bleed some more?
__________________
'92 D250, getrag, 3.50, 18cm....out of service
'93 D350, DRW, A518 auto, 3.50, ext cab, BHAF, pump mods, 4" straight pipe
'93 W350, DRW, A518 auto, 4.10, ext cab, stock....plow truck
taterfarm is online now   Reply With Quote
Old 05-07-2008, 08:47 AM   #2
C/PRD/
C/PRD/'s Avatar
I have seen stranger things, but I have never seen an IP just QUIT.
Yes, Air can suck in and not let the pump build pressure.
No, you have to change the delivery valves otherwise, yes.
I would completely remove the fuel shutoff selinoid and gut it just to be sure it's not letting enough fuel out to see but not to start. Then bleed some more. Once you're sure the IP is bleed well, Bleed the first four injectors, leave the last two or any two lines unhooked and it should start. The time it takes to reattach the other lines allows any additional air to get out. Just my $.02
__________________
07.5 MC 6.7 SmartyME wDeletes AT DRW 225k
C/PRD/ is offline   Reply With Quote
Old 05-07-2008, 09:12 AM   #3
Confedpirate
Confedpirate's Avatar
look for the fuel shut off solnoid it has two wires on it chk to see if one of the wires is broken that could cause the IP to quit working
__________________
91.5 I/C CTD 4x4, Old Smokey fuel pin. 1.5 turns on the pump, 4 in quiet exhaust , A518 just rebuilt, with 3.55. stock tires, w/ open air filter 366 spring and 16cm housing other then that its stock. Saving money for Injectors getting them built buy Red Oak Diesel in Iowa.
Confedpirate is offline   Reply With Quote
Old 05-07-2008, 11:04 AM   #4
Alwaysworking
alwaysonDTR
Alwaysworking's Avatar
i vote for the shut off solinoid, mine was like that went out one morning and it didn't start, replaced the solinoid and it started.
__________________
yellow 82 crew 350,4x4,getrag,SB3600DD, swapted in a 91 cummins,compounds, studs,60lb.springs, intercooler,3" tubes,twin ram intake,366 clipped,fuel screw in M&H fuel pin(M2) and timeing spacer,piston LP,bypass regulator,big fuel lines,gauges,4inch exhaust,muffler
http://www.youtube.com/user/91ctddc
blue- 91 cummins,250,xxx getrag, 4x4,250,M&H fuel pin M2, 4inch strait pipe, gauges custom made intercooler, 3in. tubes,HX35/14
DTRgoofball club member #11
93 club cab 4x4 5speed 250k
Alwaysworking is offline   Reply With Quote
Old 05-07-2008, 06:55 PM   #5
taterfarm
Got it
Thanks for the help, should have ripped the shutoff solenoid apart at first.
that fixxed it.
So the guy thought he had a $550 repair with the injection pump.... turned out to be $10..... Again thanks for all the info over the past year and half.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
