Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 08-19-2010, 11:43 PM   #1
TrkEnvy
TrkEnvy's Avatar
What did the D60 front end come in??
I really wanna convert my 2wd to 4wd and I would like to know what the D60 came in other than our trucks, ie fords, chevys. I really wanna find one local so I dont have to sell my kidney to ship it.
__________________
'91.5 D250LE A518 auto, One 5" mitre stack, GDS 60mm/16cm housing, Homemade aluminum intake, Moog HD springs, Autometer Boost & Pyro, Maximus Train Horns. *in the process of being painted*
TrkEnvy is offline   Reply With Quote
Old 08-20-2010, 12:06 AM   #2
roxxx
Here is One of the better info sites i have found .......... This Guy knows Dana axles
http://www.pirate4x4.com/tech/billavista/60_front/
You need a T-case and tail housing for the t-case to tranny plus the gate and shifter. I don't know Autos but you may need a different cross member
this is a very good source for finding our old stuff in the bone yards
http://www.car-part.com/
Edit: I wish I could trade you folks some rolling 4x4 chassis for some of the mint bodys you have lol. I have 2 whole trucks and 2 rolling cummins 3/4 tonne chassis
__________________
1992 4x4 Reg cab LE 5 speed
Skyjacker 4 Inch lift
Bilsteins shocks 5125
Shiny new VE moderately molested
Dana 80 Mod
ultra wheel rims Type 164
ASA Modified pipe BHAF 19037
Outerwears prefilter
Advanced adapter nv4500 & Bell housing
South bend Flywheel and clutch 13125-OK
PIT Crew : Orange 3 leg cat
1996 Buell Lightning S 1
Race filter Vance hines Pipe Soon to be Big bore
2006 Buell Lightning XB12SCG
Rob Roxx Geekin Till it Hertz
roxxx is offline   Reply With Quote
Old 08-20-2010, 01:22 AM   #3
TrkEnvy
TrkEnvy's Avatar
Thanks.. I think im gonna score the d60 first and convert the front end. Then when funds allow do the tranny and trans case making it functional.
Gotta love the desert for giving rust free bodies.
Old 08-20-2010, 05:17 AM   #4
Jungle
Jungle's Avatar
The spring perches on the chevys are about 1" or 2" wider than the Dodges.
Jim
__________________
1992 CTD W250 I/C Low pressure lift pump, DDP 80 hp sticks, PS intercooler, 366 spring, 355 gears, 518.
Jungle is offline   Reply With Quote
Old 08-20-2010, 09:01 AM   #5
checkster
checkster's Avatar
im pretty sure my 96 f350 had a dana60 front end. so i would guess at least 93-97 f350 4x4........same body style
__________________
2007 Quad 2500 4x4 CTD 48RE. AFE Stg2, Wet Okole Max4 peoprene seat covers, Prodigy P3, Smarty Jr POD, ISSPRO fuel, trans, boost, and EGT, Pacbrake Airbigs, 2" hellbent level kit, 295/70-18 trailgrapplers on 18x9 incubus crushers
2006 Quad 2500 4x4 CTD 48re. all done up (totaled on 10/25/08......boohoo.....byebye baby girl)
2008 Wildwood 27SRVS toyhauler.....yeah baby
checkster is offline   Reply With Quote
Old 08-20-2010, 09:07 AM   #6
apwatson50
apwatson50's Avatar
Ford differential is on the wrong side, at least to use a factory 205 t-case. I suppose you could use a ford diff, but use a newer 241 drivers drop t-case.
__________________
92 Black W250 295K, getrag, valair 13" ceramic clutch, dana 80 3.54, HX40, DDP3 injectors, high pressure piston LP, custom IP, M&H M2 fuel pin, PS charge air cooler, 4 in exhaust w/ brake, gauges(and lots of them) Leece Neville power.
89 FUMMINS F350 4x4 crew cab, VE 12V, A518 trans, ford np205 t-case, PS cooler, hybrid HX35, low pressure piston LP
http://s218.photobucket.com/albums/c...Truck%20stuff/
apwatson50 is offline   Reply With Quote
Old 08-20-2010, 09:25 AM   #7
pwregan
d6o
trkenvy,
you might be better off buying a wrecked dodge and move all the parts you need from wrek to your truck- will save you a lot of running around for little parts that you didnt think about
__________________
pwregan:
1999 ram 2500,sport package,quad cab, metalic forrest green, dark grey leather interior- only mod is a 4 inch exhaust and a k&n air filte-ohh yes tranny went at 94k- stock rebuild- dealer " what tranny problems???"
pwregan is offline   Reply With Quote
Old 08-20-2010, 10:09 AM   #8
82F100SWB
82F100SWB's Avatar
The spring perches are within 1/2" between Chevy and Dodge, and a 78/9 Ford axle, you can move the springs enough on the bushings that it will work no problem. I have seen swaps done using the Ford axle, but, driveline packaging would be an issue.
__________________
92 W250 SLE Reg Cab, handshaker, loaded, Autometer guages, 35 BFG's, enough power to get out of it's own way, and a blowed up getrag...
One of each of the other brands in the driveway...
96 F250 PSD... Freebie...
08 2500 Dmax... Company Truck
82F100SWB is offline   Reply With Quote
Old 08-20-2010, 10:46 AM   #9
CaptainChrysler
CaptainChrysler's Avatar
The chevy's use a wider leaf up front 3" vs. 2-1/2", and have a wider track width. The 1st gen's have slightly different steering knuckles too. I would try to find a 1st gen front end.
__________________
Curt
Driver:
'93 W350 CC SRW Getrag:
3200, 370's, HX40, BHAF,HP Piston Pump, Big Lines, Pull Cable, Valet, 5" Straight Pipe, AM Tach, C2 Boost and Pyro Borgeson, 250K
To do: PS-IC, NV5600, Air ride
Puller:
'89 W350 RC SRW NV4500/NV273 HO72:
CaptainChrysler is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
