Thread Tools | Search this Thread | Display Modes |
#1 | ||
#2 |
i use the same thing
__________________
99 quad cab long bed 4x4 4:10 nv4500hd k&m cold air kit edge drag comp 4in exaust 305/70-16 on STOCK rims |
#3 |
I saw that trick on that show "Trucks" awhile back. I tried it on my Jeep that I used to "wheel" quite often and it worked like a champ. Aside from looking better it truely does keep the mud and grime from sticking. Tire shine also works really well on keeping the plastic trim on the front bumper, rear bumper, tailgate, and door handles looking new too. Door handles are slippery though I wouldn't do those.
#4 |
I do the same thing, I also use it on my front springs, trailing arms.
__________________
99 2500 SB/QC 4x4: 1/8-7.1@88mph 1/4=12.1@109 on #2 only. 95 2500 Reg. Cab 2wd 12v stock for now. http://www.youtube.com/watch?v=fF8ePxWlf3w |
#5 |
Oh yeah it works on just about everything under the truck as well. It will wash off road grime from everything under the body. Shines everything up real nice, good if you were gonna show it or something, just make sure you take some degreaser and a pressure washer down there first so you don't try and shine dirt!
**** crankcase vent covers our babies with grime no matter how much you clean. |
#6 |
I knew I wasen't the only one doing this! But maybe we have told some people who didn't know and thats the great part of this site. Teaching and learning is the BOMB, together we can make just about anything easier and or better.
If you have I good idea let everyone know, just because you might think its simple and you think everyone else knows it that might not be true. Let us know your ideas it will help everyone.Thanks-for your input. CRIS |
#7 |
One good product to spray on the truck before going in the mud is good ole wd-40 we use it on our motocross bikes and works good the mud doesnt even stick
__________________
94 dodge 2500 5spd BHAF 4 " str8ts fuel plate fully forward star wheel spun Kdp-Mia-by-KGB-backed-by-CIA-funded-by-Me BHAF and 265s that seem to have tread just peeling off for no apparent reason?? 99 kawasaki kx 125 01 suzuki jr 80 funnest bike i own! 87 z28 305 tpi 98 kawasaki kx 125 |
#8 |
Hey guys
Thats what I'm talking about, These little ideas may not help all of us but the people it does thats great. There has got to be more people out there with little ideas that can help us. No idea is to small, post them they may just help someone. Thanks mx261, I've seen that before but some may not have. CRIS |
#9 |
I use amsoil silicon spray on my plastic and amsoil metal protectant spray on my motor and other metal on my MX bikes. Unless I let it sit a week after a race the mud and grime will rinse right off. I'm sure WD40 does the same but I get the amsoil stuff pretty cheap. Also will make your motor on your dodge look like new. degrease and rinse the motor and spray on the previous sprays on the metal of the motor and the plastic and wiring and it shines like new. It lasts quite awhile too.
#10 |
Good idea
Does that metal protectant make everything under the hood shine? I'd like to get my under hood to shine. But doesn't the silicon spray end up cracking after a short time with the heat under the hood? I've seen some cars that had some type of silicon sprayed on them at a used car lot that started to crack and chip off, maybe some cheap stuff. Keep them coming. CRIS |
#11 |
I just finished using phosphoric acid on all the rusted manifold and turbo pieces. Puts a hard black shell on any rusty iron. Looks a lot better than the rust. This acid is contained in Rust Cure or like products at any auto parts store. An old trick but worth repeating. Watch out for paint surfaces, it WILL stain permanantly. This shell is also, paintable.
__________________
Retired US Navy Chief, 95 2500 auto, peeling white (junk paint), BHAF, #5 plate, EGR brakes, KDP dead, EGT, Boost and Tran temp gauges. Billet TC, upgraded valve body.Three position TC lockup switch. Timing at 15.5 |
#12 |
A bit off topic but a good page on Rust Converters. I got really interested in this, and CarlJensens suggestions brought it back to memory. http://www.corrosion-doctors.org/Met...converter.htm.
As for the inner fenders, I usually use armor all, its about the only place I do use it though, as its nasty stuff when it comes in contact with anything.
__________________
1994 Dodge 3/4 Ton Diesel Looking Pretty for a work truck Fully Done Transmission, Intake, Exhaust, 215 Nozzles & Pump, 191 DVs, #10 Plate, AFC modified, Big cow catcher on the front |
#13 |
Carl
I always use phosphoric acid on the sheetmetal of my cars during restoration, that is the most importain step to keep the paint on the car. I do the whole car after its been striped even if its not rusty. Its a good idea to use it over all your bare metal. CRIS |
#14 |
Just want to put my 2 cents in...I am an auto detailer for a ford dealership up here in CO, and just want to warn you a few things regarding the tire shine. It will work great on any plastic or vinyl surface but make sure you do NOT get it on your paint, and if you do, immediatly wash it off with soap and re-wax the area that was hit. I don't know the exact chemical that is in the spray can but it can eat through some paint rather quickly(few hrs). There is a reason why the professional detail shops will not use products such as that and that is one reason. Also, if left on chrome for extended periods of time you will get "permanent" spotting. By permanent i mean that most say you can't get it off but with the proper chemicals you can fix almost anything. If anyone has any questions about stain removal or fixing exterior damage just let me know and id be glad to help.
__________________
10 2500 Laramie 6.7, 4x4, Black Maxx w/ Overdrive-DPF/EGR Deletes, AFE Stage 2, BOD Intake, MBRP Boost Tube, Bags w/ On Board Inflation, Carli 2.0 w/ 18" XD Hoss Wheels, DDM HID's, Frontier Front and Rear Replacements LineX'd to Match Trim Color 98 2500 12V Quad Cab 4x4 Auto, 0 Plate, DDP 4's, 4K GSK, Pusher Intake, Snow Stage 3, Timing @18.5, HX35/40-HT3B TWINS, ATS Manifold, 60lb Valve Springs, O-Ringed, Marine Head Gasket, ARP Studs, 4" to Single Stack TCI Tripple Disc |
#15 |
The amsoil silicon spray is simply that, a spray. It makes plastic and rubber look almost wet. It does not leave anykind of hard shell that can crack. The most noticeable is the parts will be a little slick until they dry fully. The metal protectant acheives a similar result. The metal looks wet, but after touching you will only feel a slight film, which eventually will go away. Both great products.
About the tire shine, I've seen it eat paint before as well. Most people use so much it reallt looks bad when it's thrown all over the side of your freshly washed truck. I think it's Meguires that has a product called hot tires or something like that and it will not fling! Really great stuff, wouldn't use it under the body though expensive |
| Display Modes | |
