Thread Tools | Search this Thread | Display Modes |
#1 | ||
dead peddle
#2 |
Sounds like you may have low fuel pressure. Possibly an overflow valve or the lift pump is starting to fail. It would be helpful if you could get a fuel pressure reading and a boost pressure reading. Also what are the specs on your truck?
__________________
Red 95, Ram 3500, SLT, 4x4, Std cab, 8 ft box, Dually, 5 speed, Pac Brake, Jasper reman Long block, original inj syst, Timing adv 17, Guages, modified fuel plate, 3000 GSK, Stock exh with failed empty converter, 4.11 ratio w/rear locker |
#3 |
Its a2002 . I will take it to the dealer .I put addtive in before when it did this and it worked but not so good this time.thanks for advice.
#4 |
sounds like an APPS problem... check the tech facts for the reset procedure.
__________________
P-pumped 2002 2500 QC short bed 4x4 Dodge Makes it, Cummins Shakes it... "Politicians never accuse you of 'greed' for wanting other people's money --- only for wanting to keep your own money." |
#5 |
Mine did the same thing and it was a crankshaft position sensor
__________________
2002 3500 6spd Cab and Chassis J&L flatbed six inch turnout stacks hypertech programmer K&N |
#6 |
the dealer replaced the injection pump today. they said it was fixed.Iwill know tomorrow because it would run strange when cold or warm or not for .5 hour.It still could be the crank shaft position sensor. but i hope not thanks for the help.
| Display Modes | |
