D70 disc brakes - Great Lake Offroad?
Just seen that http://www.greatlakeoffroad.com/ makes Disc Brake Brackets for about $55 a pair. Then add about $220 in new parts (Rotors, Calipiers Pads) The complete swap looks pretty good.
Only thing I don't like is no e-brake.....
Anybody try them?
Anybody try them?
The Caddy brake calipers have a cable e-brake provision. Anyone who wants to do the rear disk conversion should visit ramchargercentral, there are more than one disk conversion How-To's on that site. Some of the bracket suppliers have questionable quality and some are acceptional, Buyer Beware.
http://www.ramchargercentral.com/index.php?action=howto
I looked into this a bunch and am getting ready to order those from GL Offroad also. They are correct about the Eldarado calipers working. When I added it all up, I think I was at about $230 total. I don't think that included the brake lines though.
So are you telling me they use the Metric GM calipiers with this kit....(Monte Carlo/Eldorado).... Heck I run those on the rear on my Toyota!
Now granted I have the proportioned WAY down to keep them from locking up.
I used their brackets and was very pleased! here is the link with a parts list
https://www.dieseltruckresource.com/...isc+conversion
BC847,
I believe that brake caliper in that photo is for the other side. The bleeder screw is on the bottom. The bleeder screw MUST be at the 12 o clock position to get the air out when you bleed the system.
1st Generation Admin
It's common in these installs to mount things as such. I noticed in the earlier pic up above, his is mounted the same (however I notice his has the bleeding port installed up top, different application? P/N?). In my case, you have to remove the caliper from its mount to bleed it effectively. Having done so, it works quite well.
BC847, That makes sense.....I was afraid you didn't realize it was upside down and I didn't want to see you bolt everything up and not be able to get a good pedal and rack your brain trying to figure it out..........Like I did once along time ago. It is obvious you know what you are doing....sorry about that...
