Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 02-11-2008, 08:17 PM   #1
Texaschevelle
Texaschevelle's Avatar
What is a "CZ" pump?
I see that when VP's are discussed. Whatever a CZ is, it is not considered good.
So what is "CZ" fellas?
__________________
2002 Dodge 3/4 ton QC 4x4 6-speed...71K miles. Edge Juice with Attitude, dual 3 inch exhaust. Walbro 392...20psi @idle, 16 psi WOT!! Rotella 15-40, baldwin oil and fuel filter. Lucas fuel additive w/fill up, homeade VP-44 cooler tube.
Texaschevelle is offline   Reply With Quote
Old 02-11-2008, 09:20 PM   #2
dozer12216
Reman in a former soviet state is the general impression I have been given. Generally are painted/dyed blue/black. May be just as good as USA rebuild. Has same warranty through repair facility.
__________________
2008 1/2 3500 dually that is stock except for 2 micro inline filter for fuel. Infero red extended cab, long box made for highway towing.
dozer12216 is offline   Reply With Quote
Old 02-12-2008, 09:23 AM   #3
JSPulliam21
JSPulliam21's Avatar
Made in Czechoslovakia. Not the best quality as I understand.
__________________
98.5 Dodge 3500 CTD QC LB NV4500 4x4 3.55 SRW, DiPricol Gauges, BHAF, 4" Silverline, FBD 150's, Edge Comp, Valair 3800 DD, Draw Straw, 1/2" Filter to IP Line, FASS 95 HPFP, 2" Leveling Kit, DSS, 35" Toyo M/T's, KDP Killed. 403HP/899TQ http://www.dieseltruckresource.com/pics/showgallery.php?ppuser=50100&cat=500
JSPulliam21 is offline   Reply With Quote
Old 02-16-2008, 04:00 PM   #4
smokesalott
the mfg part numbers from china start with a CZ
http://www.chinahanji.com/injectionpump/VP44.asp
__________________
2001 dodge 2WD auto DDII HX40 drag comp
smokesalott is offline   Reply With Quote
Old 02-17-2008, 12:32 PM   #5
SIXSLUG
SIXSLUG's Avatar
CZ sounds like seized to me! Thats how I remeber not to buy one. Kurt
__________________
Kurt
2001.5 2500 QC LB 4WD H.O. 6-SPD SLT Plus
3.54's, Camper/Tow/Plow, A.R.E. Canopy w/ SS Vanguard rack, Southbend clutch and hyd.,TIMBO APPS, BHAF/Heatshield, MBRP 4" TBE, FP Gauge, Femco E-Z Drainplug, DSS, Thuren Trac Bar, 2" leveling kit, P/H Tow Mirrors, PBR, 128K miles. FASS LP
"When I was younger I could remember anything, whether it happened or not." Mark Twain
Support Our Troops!
NRA, MSBL, BYO, GSP, BOLTS, Southpaw, CDC*
*Cracked Dash Club
SIXSLUG is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
