Cylinder head problem help
I just swapped out my cylinder head on my 89 w250, everything went smooth until I started it, ran real rough. I think the problem may be when I set the gap between the rocker and the valve spring, the thread I was reading said to set the gaps but didn't say anything about top dead center, so basically all the valves would be set closed right? im not sure what to do from here
ive never tried a job this size before and im a little overwhelmed. any help would be great.
The easiest way to get it right is to rotate the engine so each cylinder is at TDC between the compression and power strokes. The interesting thing is that at TDC between the exhaust and intake strokes, both valves are slightly open. We can use that to our advantage.
Firing order is 1 5 3 6 2 4. When both valves of #6 are moving, #1 is very near TDC, lined up for adjustment. Set the valves, then rotate the engine so #2 has both valves moving, (It will be exactly 1/3 of a rotation) and adjust #5, etc till you've set the valves on all 6
hope it helps.
hope it helps.
Gen414
05-07-2009 11:08 AM
cgmorgan06
11-15-2007 04:02 PM
Journier
11-22-2004 02:56 PM
