Go Back   Dodge Diesel - Diesel Truck Resource Forums > Specialty Forums > Cummins Conversions
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 03-04-2009, 09:36 PM   #1
pengyou
Cummins in an 84 ram 350 4wd
I am considering buying an 84 Dodge ram 350 that presently has a 360 with auto tranny in it. Would it be easy to put a cummins 4bt in this? Would it have enough power to cruise on the freeway at 70 mph? Any guesstimates about how many mpg it would produce? Would an nv 4500 be a good tranny to connect to it? I heard that a few years later the ram 350 had a 5.9 diesel as an option.
I don't want to do any booneycrashing with it but want to be able to go camping down dirt roads pulling a tent trailer. I also want the 4wd for better traction control in adverse weather.
Any suggestions?
pengyou is offline   Reply With Quote
Old 03-05-2009, 06:20 PM   #2
wannadiesel
If you get the mounts from a '89 - '93 Cummins powered Dodge it will pretty much bolt in there.
4.10's and down would be OK gearing choices with the NV4500 if you want to cruise at 70. If you plan to tow with it run the 4.10's, go lower for better mileage.
I'd expect mid 20's for mileage.
__________________
Faith
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner.
390 HP/800 TQ on #2 only, 413 HP/852 TQ w/ water/meth - needs more air!
Dead KDP's = 72
wannadiesel@dieseltruckresource.com
wannadiesel is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
